After some research this looks like an issue with your envs gcc version. Specifically -fstack-protector-strong was introduced after gcc 4.9.x and prior versions couldn’t recognize this flag.
That’s odd. When I wrote the docs I did an update too, I’ll have to check it and try again. They should not be mismatched like that, must be a problem in raspbian
I think I know what happened. When I first installed the rtl_sdr I was having issues with seg faults running rtl_tcp whenever I closed the connection in the client. Updating the libusb-1.0 from deb http://archive.raspbian.org/raspbian jessie main fixed the issue, but this also is the repository that was used when I installed the packages from your instructions. I forgot to remove it. Fun stuff. I may push the rest of the OS to jessie and see how it runs before I re-image it back. Thanks
coincidentally I have a second raspi2 I’m working on using for satnogs running jessie… (mostly because I’m testing a gnuradio+funcube dongle setup as a replacement for rtl_fm+rtl_sdr, and that will be much easier in jessie)
So far everything satnogs-wise works in jessie, the only issue being that jessie is a bit more advanced to get running. If you choose to do that I’d recommend starting with this image from this post rather than trying to bring raspbian up to jessie.
I figured I’d play with jessie on another pi. I think I have another one laying around that’s not already doing something. I re-imaged and everything installed just fine, although the segfaults are back with rtl_tcp. Maybe I’ll try the libusb from jessie again since it fixed it before.
I never installed the original rtl software in this build. I walked down the install doc. I’ve seen other posts about the same issue, which is how I found the fix for the segfaults. I’ll play around with it later.
Ok I’ll try to reproduce… @oe6rke just recently installed the same and I don’t believe he had this issue (highlighting him here to see if that was the case?)
I’m using one of the newer R820T2 dongles from NooElec. I’ll try to reproduce it with one of the older ones. I haven’t dug that far into the Satnogs software, so I don’t know if rtl_tcp is relied upon. If it isn’t then most likely the problem wouldn’t be encountered.
Switching to the jessie libusb would require also updating far too many of of the critical libraries, like libc and libc6. There’s a higher chance of other things breaking. At that point I might as well move to jessie. I’ll pickup another SD and try jessie while I do some searching on alternative fixes for wheezy.
i had no issues compiling the RTL_fm a fews days ago. Os were ubuntu 64 bits 14 lts Server version.
just with multimon i had some negotions, but with
sudo apt-get install qtcreator i met the baseline für qt4-make
