some days ago I did an update of my client through satnogs-setup. After this update I have problem that the client seams to crasch after observation of satellite 43857 - Da Vinci mode
BPSK 2320000
see SatNOGS Network - Observation 6357946
Only solution is to hard reset (power off/on) the Raspberry PI. See log below “Satellite not supported”:
Any solutions for this? As now, my station can not be used.
regards
Lars SM0TGU
aug 21 04:07:12 SM0TGUSATNOGS satnogs-client[369]: gr-satellites: Observation: 6357947, Norad: 43857, Name: 0_DAVINCI, Script: satnogs_bpsk.py
aug 21 04:07:12 SM0TGUSATNOGS satnogs-client[369]: gr-satellites: Satellite not supported
aug 21 04:07:15 SM0TGUSATNOGS satnogs-client[369]: [INFO] Using format CF32.
aug 21 04:07:15 SM0TGUSATNOGS satnogs-client[369]: gr::log 2022-08-21 04:07:15,196 :INFO: satnogs.doppler_compensation: Output sampling rate should be less or equal the device sampling rate
aug 21 04:07:15 SM0TGUSATNOGS satnogs-client[369]: Traceback (most recent call last):
aug 21 04:07:15 SM0TGUSATNOGS satnogs-client[369]: File “/usr/bin/satnogs_bpsk.py”, line 583, in
aug 21 04:07:15 SM0TGUSATNOGS satnogs-client[369]: main()
aug 21 04:07:15 SM0TGUSATNOGS satnogs-client[369]: File “/usr/bin/satnogs_bpsk.py”, line 566, in main
aug 21 04:07:15 SM0TGUSATNOGS satnogs-client[369]: tb = top_block_cls(antenna=options.antenna, baudrate=options.baudrate, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path
aug 21 04:07:15 SM0TGUSATNOGS satnogs-client[369]: File “/usr/bin/satnogs_bpsk.py”, line 144, in init
aug 21 04:07:15 SM0TGUSATNOGS satnogs-client[369]: self.satnogs_doppler_compensation_0 = satnogs.doppler_compensation(samp_rate_rx, rx_freq, lo_offset, baudrate*decimation, 1, 0)
aug 21 04:07:15 SM0TGUSATNOGS satnogs-client[369]: File “/usr/lib/python3/dist-packages/satnogs/doppler_compensation.py”, line 91, in init
aug 21 04:07:15 SM0TGUSATNOGS satnogs-client[369]: raise AttributeError
aug 21 04:07:15 SM0TGUSATNOGS satnogs-client[369]: AttributeError
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: gr-satellites: Observation: 6357947, Norad: 43857, Name: 0_DAVINCI, Script: satnogs_bpsk.py
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: apscheduler.executors.default - ERROR - Job “spawn_observer (trigger: date[2022-08-21 02:07:12 UTC], next run at: 2022-08-21 02:07:12 UTC)” raised an exception
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: Traceback (most recent call last):
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: File “/var/lib/satnogs/lib/python3.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: retval = job.func(*job.args, **job.kwargs)
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/scheduler/tasks.py”, line 65, in spawn_observer
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: observer.observe()
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/observer/observer.py”, line 209, in observe
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: waterfall = Waterfall(self.observation_waterfall_file)
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/waterfall.py”, line 105, in init
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: self.data = _get_waterfall(datafile_path)
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/waterfall.py”, line 80, in _get_waterfall
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: waterfall = _read_waterfall(datafile_path)
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/waterfall.py”, line 36, in _read_waterfall
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: ‘timestamp’: np.fromfile(datafile, dtype=‘|S32’, count=1)[0],
aug 21 04:07:18 SM0TGUSATNOGS satnogs-client[369]: IndexError: index 0 is out of bounds for axis 0 with size 0
aug 21 04:49:01 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 05:13:11 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 05:26:18 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 06:00:21 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 06:23:17 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 07:17:09 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 07:25:34 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 07:37:52 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 08:12:27 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 08:35:28 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 08:50:31 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 09:26:23 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 09:40:22 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
aug 21 10:15:15 SM0TGUSATNOGS satnogs-client[369]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Support information:
“versions”: {
“satnogs-client”: “1.6”,
“satnogs-client-ansible”: “202205101826”,
“gr-satnogs”: “2.3.1.1-1”,
“gr-soapy”: “2.1.3.1-1”,
“gnuradio”: “3.8.2.0-14satnogs2”,
“satnogs-config”: “0.12”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2022-08-21T08:29:06.065949+00:00”,
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: true,
“platform”: {
“system”: “Linux”,
“node”: “SM0TGUSATNOGS”,
“release”: “5.10.103-v7+”,
“version”: “#1529 SMP Tue Mar 8 12:21:37 GMT 2022”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 968052736,
“available”: 755314688,
“percent”: 22.0,
“used”: 151207936,
“free”: 432898048,
“active”: 147927040,
“inactive”: 335581184,
“buffers”: 29384704,
“cached”: 354562048,
“shared”: 6496256,
“slab”: 32251904
“disk”: {
“total”: 31090814976,
“used”: 3764711424,
“free”: 26015645696,
“percent”: 12.6
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_gain_mode”: “Settings Field”,
“satnogs_other_settings”: “LNA=10,MIX=10,VGA=10”,
“satnogs_post_observation_script”: “/usr/local/bin/satnogs-post {{ID}} {{FREQ}} {{TLE}} {{TIMESTAMP}} {{BAUD}} {{SCRIPT_NAME}}”,
“satnogs_pre_observation_script”: “/usr/local/bin/satnogs-pre {{ID}} {{FREQ}} {{TLE}} {{TIMESTAMP}} {{BAUD}} {{SCRIPT_NAME}}”,
“satnogs_rf_gain”: “36.4”,
“satnogs_rx_samp_rate”: “3e6”,
“satnogs_soapy_rx_device”: “driver=airspy”,
“satnogs_station_elev”: “5”,
“satnogs_station_id”: “858”,
“satnogs_station_lat”: “59.453”,
“satnogs_station_lon”: “17.890”,
“satnogs_waterfall_min_value”: “-90”,
“udp_dump_host”: “127.0.0.1”
