I installed satnogs client. Installation is good. The client connects to the server satnogs. Id stations is still red (https://network-dev.satnogs.org/stations/70/). On the home page, the map is marked Point Station (Dolní Vlkýš).
Also, if you are installing and running with supervisord, anytime you make a change to the configuration scripts for supervisord (like the station ID or API token) they do not take effect until you run a ‘sudo supervisorctl reload’. (then sudo supervisorctl restart satnogs)
I will do this every time, make a change to the config script and just restart the service, forgetting the reload.
