What could be Client 1.6+7.g537d804 after update…?
VE2DSK
You have edits or experimental client enabled. Can you post the results of Advanced >> Support here?
Hi, if it’s help…
“versions”: {
“satnogs-client”: “1.6+7.g537d804”,
“satnogs-client-ansible”: “202109022142”,
“gr-satnogs”: “2.3.1.1-1”,
“gr-soapy”: “2.1.3.1-1”,
“gnuradio”: “3.8.2.0-14satnogs2”,
“satnogs-config”: “0.12+2.ga40a9e9”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2021-10-26T12:12:10.508902+00:00”,
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: true,
“platform”: {
“system”: “Linux”,
“node”: “raspberrypi”,
“release”: “5.10.63-v7l+”,
“version”: “#1459 SMP Wed Oct 6 16:41:57 BST 2021”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 1963110400,
“available”: 1441447936,
“percent”: 26.6,
“used”: 426287104,
“free”: 1131958272,
“active”: 168878080,
“inactive”: 593666048,
“buffers”: 38158336,
“cached”: 366706688,
“shared”: 8851456,
“slab”: 38162432
“disk”: {
“total”: 7489372160,
“used”: 3437363200,
“free”: 3700199424,
“percent”: 48.2
“configuration”: {
“experimental”: true,
“hamlib_utils_rot_enabled”: true,
“hamlib_utils_rot_opts”: “-m 601 -r /dev/ttyUSB0 -s 9600 -T 0.0.0.0”,
“satnogs_antenna”: “RX”,
“satnogs_post_observation_script”: “/home/pi/postob.sh --id {{ID}} --tle {{TLE}}”,
“satnogs_ppm_error”: “0”,
“satnogs_rf_gain”: “43.9”,
“satnogs_rot_baud”: “9600”,
“satnogs_rot_model”: “ROT_MODEL_GS232B”,
“satnogs_station_elev”: “50”,
“satnogs_station_id”: “1461”,
“satnogs_station_lat”: “45.651”,
“satnogs_station_lon”: “-73.564”
What is your question? Do you have a problem with station 1461 since the latest update? If yes, can you please describe it in a few words?
The version string for satnogs-client follows the following scheme: {release_version}+{some_number}.g{short_commit_id}
. On your station 537d804 is installed, the latest commit in satnogs-client master branch. Thus after trying to update the station using satnogs-setup there will not be a change in version number.
Sincerely,
Fabian
No running correctly, just asking.
Many Thanks…
