I have installed gpredict and XQuartz via macports and the following error when trying to run gpredict:
(gpredict:4739): Gtk-WARNING **: 22:06:19.185: cannot open display: :0
I’ve tried following the guidance here but it has made no difference. Any advice?
So did you tried to change ssh configuration? Are you ssh’ing? Does any other X app works for you? Please help us to help you by being more specific on what you have done.
Solved. Solution is to open XQuartz first.
