Cannot down load schedules
My satnog setup was working for a year and stopped a while ago. I started again from scratch and installed the latest image. Everything appears to be working, but my system has trouble downloading schedules. Connectivity is good to network.satnogs.org port 443 but there is still a problem connecting. See the error message below. Any ideas?
Thanks in advance for the help – Ken K9YO
Nov 29 23:32:15 raspberrypi satnogs-client[435]: raise ConnectionError(e, request=request)
Nov 29 23:32:15 raspberrypi satnogs-client[435]: requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘network.satnogs.org’, port=443): Max retries exceeded with url: /api/jobs/?ground_station=2579&lat=42.28&lon=-87.97&alt=200 (Caused by NewConnectionError(‘<urllib3.connection.HTTPSConnection object at 0xf30b1778>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’))
Nov 30 01:06:18 raspberrypi satnogs-client[435]: apscheduler.executors.default - WARNING - Run time of job “post_data (trigger: interval[0:03:00], next run at: 2024-11-29 23:35:15 UTC)” was missed by 0:01:03.046802
lines 275-297/297 (END)
The problem went away. Not sure why.
