Can you use 2x RTL-SDRs with Satnogs?
Hello all!
We have just finished building our ground station and wanted to reach out for some extra help
Our current antenna setup includes 1 VHF and 1 UHF Yagi. There are 2 feed lines, one for each antenna. I was wondering if Satnogs supports using 2 RTL SDRs, one for each antenna in order to decode VHF and UHF downlinks.
I do it with 2 separate Raspberry Pis, makes life simpler. Stations 568 and 724. LNAs at the mastheads. QFH antennas.
Since you are using yagis that are presumably on a common rotator (?) then I would suggest using a diplexer to connect the two yagis into one RTLSDR.
If you have LNAs at the antennas, then you may need separate bias-tees to power them, as the RTLSDR will not be able to provide a bias voltage via a diplexer.
I guess this is the station ?
Depends on what you mean (:
Running two stations on one host is possible, both with the systemd/ansible and under docker.
Using two SDR on one station client does not, I recommend using coax relays or a diplexer as vk5qi said.
As this is a common rotator, I’d say running it on one station, single SDR.
Driving a relay is not too hard, I have used the RPi gpio but now mostly use the usb mcp2221 and a script that is executed in the pre-/post script that runs on each observation.
Diplexer would be the simplest solution thou.
And this is my solution for running multiple stations and SDR receivers on single hardware Using a second SDR | Amateur Radio – PEØSAT
And it all comes down to what you want to achieve
Thank you for all your responses everyone! The PE0SAT approach seems the best for our situation, and will try it out once we finish testing our station.
