Using Simple AZ-only TV rotators: This topic is coverd in the remainder of this page.
For almost all of the Low Earth Orbiting (LEO) amateur satellites a modest beam antenna fixed at 15 degrees elevation is more than adequate to bring in signals from the digital packet and voice FM downlinks to your dual band FM radio. A simple TV rotator and modest beam is all that is required. This is a bargain compared to the typical AZ/EL OSCAR class satellite tracking station. And it also serves perfectly well for terrestrial VHF/UHF work as well.
In general there have been reports of some people getting āresultsā with not particularly directional antennas being used with an Az rotator at around 30 degrees (or sometimes lower). I have a vague memory that it was with either an eggbeater or dual moxon antenna rather than a yagi though (i.e. not overly directional)
An egg beater does not need to be rotated. And, yes, a Moxon could be rotated.
The idea would be to adapt the control protocol to just turn the array as the pass comes overhead. Since TV rotors canāt go around 360 degrees, there may be some challenges for some passes that would have to go through the dead spot.
There was a different article @WA4OSH. I canāt find it. one day itāll turn up and Iāll post it here. I found it whilst looking at antennas funnily enough
One thing we could do is to add a āmax elevationā to a ground station. We already support a āminimum elevationā so this shouldnāt be too difficult to accomplish.
The rotator interface typically knows the limitations of the rotator it is configured for (such as with the K3NG arduino code) and if the rotator hits the overlap point it will reverse to go around and meet up with it on the other side.
I take it that you lose 10-15 seconds during a overlap point turn-around? Which direction do people prefer to make the overlap point (assuming coverage is equally good in all directions)?
The Yaesu G-5500 has hardware end stops at 0 degrees and 90 degrees (after an overlap)⦠so now that I think about this more I might want to change the interface settings a bit so that meridian flip happens at 0 and 450 rather than 0 and 360⦠hmmmā¦
