But the status is Failed. I have set the debug level to DEBUG but I see no errors at all after the observation. So I’m kind of lost. Not sure where to start looking. I would be nice to see some error in the log…
The failed status comes from the difference between the audio artifact duration (10min 33s) and the scheduled duration (12min). When this difference is more than 1min, network automatically mark the observation as failed.
This difference usually happens when there are lost samples, samples that the cpu can not handle. The reason behind that tends to be a high sample rate or high cpu temperature that force cpu to run in lower frequency and lose samples or not good power supply which has the same effect as the high temperature on cpu.
Sorry I have the station connected to a disconne antenna so for UHF there will be very low signal levels. On VHF it performs very good. Several good Funcube passes with decodes since yesterday.
I have scheduled a couple of high passes on your station, lets see if we can get some better SNR
No. I switched to 13 element tracking yagi for that observation. But the “ringbuffer write timeout” should be present (or not present) regardless of what antenna to use, or?
I’m continuing this thread as I have this problem with many of my BPSK 1200 observations (and also some other decoders) - lost samples that results in failed status, but the waterfall is uploaded. I’m running a RPI 3 and Airspy Mini with 3.000 MSPS.
I have tried a lot, for example the following:
Switched power cable and supply for the RPI.
Changed USB ports
Tested the speed for the Airspy Mini with airspy_rx and it shows 3.000 MPPS without any problem
Removed the new soapy Airspy driver and satnogs_gr-satellites - result is the same (no improvement)
Has run the volk_profile
Has tried Airspy packing
I also checked the CPU load during an observation with htop and I see that one CPU core is always at 100% during an observation with satnogs_bpsk.py.
So I do not know what to do now. Should I changed my Raspberry PI v3 to a Raspberry PI v4 to get better performance?
Just would like to add one thing - the old RPI3 I put a RTL-SDR v3 with sample rate 2.048e6, same installation as before. Now it’s working perfect, for example this observation with Funcube-1 https://network.satnogs.org/observations/7932761/
