When trying update or reset i get this error message:
starting Ansible Pull at 2023-04-02 14:40:05
/usr/bin/ansible-pull -d /root/.satnogs/ansible -U librespacefoundation / SatNOGS / satnogs-client-ansible · GitLab -C stable -t satnogs-setup
[WARNING]: Could not match supplied host pattern, ignoring: satnog
localhost | SUCCESS => {
- “after”: “e6b68d6755a085f79c6c4697d75b055d3699b36a”, *
- “before”: “e6b68d6755a085f79c6c4697d75b055d3699b36a”, *
- “changed”: false, *
- “remote_url_changed”: false*
ERROR! couldn’t resolve module/action ‘ansible.posix.mount’. This often indicates a misspelling, missing collection, or incorrect module path.
The error appears to be in ‘/root/.satnogs/ansible/roles/satnogs_client/tasks/main.yml’: line 138, column 3, but may
be elsewhere in the file depending on the exact syntax problem.
The offending line appears to be:
- Restart satnogs-client service*
- name: Use tmpfs for state directory
- ^ here*
Press enter to continue…
Is Ansible out of date? Is it best to re-flash, or is there a simpler fix?
