Additional Info about BeliefSat-0.
IARU Coordination is available at IARU Sat Coordinator
| NORAD ID |
Satellite |
Frequency |
Notes |
| 99999 |
BeliefSat-0 |
145.980 MHz |
IARU Coordinated |
The TLE set for PS4 Orbital Platform is:
OP3
1 99999U 24072A 24001.29055815 .00023156 00000-0 15779-3 0 1230
2 99999 9.6665 101.0916 0008549 316.1617 206.6505 15.73891625 32
dl7ndr
2
9.6° inclination means, the satellite will have its footprint closely above and below the equator.
SA2KNG
3
yep, looks like only 10 satnogs stations has it above the horizon and less than half of those getting it at more than 10deg above horizon.
PE0SAT
4
This seems to have received a pretty good signal but only the LO/ppm is way of.
https://network.satnogs.org/observations/8811467/
SA2KNG
5
the one at +10kHz ? that follows terrestrial pattern and is also much too wide.
PE0SAT
6
With the help of Nitin [VU3TYG], created the following gr-satellites yml file:
norad: 58595
&tlm Telemetry:
telemetry: ax25
1k2 AFSK telemetry downlink:
frequency: 145.980e+6
modulation: AFSK
baudrate: 1200
af_carrier: 1700
deviation: 500
framing: AX.25
- *tlm
Decoding example:
-> Packet from 1k2 AFSK telemetry downlink
Container:
header = Container:
addresses = ListContainer:
Container:
callsign = u'APUVU1' (total 6)
ssid = Container:
ch = False
ssid = 0
extension = False
Container:
callsign = u'VU3CDI' (total 6)
ssid = Container:
ch = False
ssid = 11
extension = False
Container:
callsign = u'WIDE1' (total 5)
ssid = Container:
ch = False
ssid = 1
extension = False
Container:
callsign = u'WIDE2' (total 5)
ssid = Container:
ch = False
ssid = 2
extension = True
control = 0x03
pid = 0xF0
info = b': :t#67,0,255,255,-9.13,-9.00,xxxxxxBeliefSat-{354' (total 58)
