BEESAT-1 is back - telemetry transmission today on its 15th anniversary
A few days ago students from TU Berlin finally managed to recover the 2009 launched and since 2013 ceased functioning BEESAT-1 (SatNOGS) back to life.
That is just right for its 15th anniversary in space, which is today on 23th.
To celebrate that, BEESAT-1 will today send telemetry over Europe on 435.950 MHz in 4k8 MOBITEX according the following schedule.
Times in UTC:
07:26 - 07:40
09:04 - 09:17
20:56 - 21:09
22:33 - 22:47
QSL cards could be possible.
edit
<< I was wrong, TechnoSat Modem won’t decode BEESAT-1 MOBITEX frames, sorry. >>
Try TechnoSat Modem from UZ7HO to decode.
Hopefully this satellite will also be activated for other regions (I’m in Thailand)
Hi all.
Congrats for the reactivation of the Beesat-1 satellite.
Which UZ7HO SoundModem should we use to decode it?
73 de David EA4SG
It seems there is none.
UZ7HO D-Star Soundmodem looks to be OK for Mobitex but it is only for 4800bd
You are right, it’s also Mobitex protocol and 4k8 is sufficient, but while UZ7HO’s Modem listens for a D-Star bit and frame sync of CCCC 5765 the attached sync marker on BEESAT-1 is 1ACFFC1D. This is already one point at which a D-Star modem will discard a BEESAT-1 frame.
Have a look at the standard hs-soundmodem, it has a BeeSAT option.
In the past it was able to also decode the blocks
Hi Jan,
UZ7HO’s High-Speed SoundModem is built to decode BEESAT-2 and -4.
Both satellites using Mobitex-NX, whereas BEESAT-1 uses the standard Mobitex format.
EA4GPZ pointed the difference between both formats out:
The only difference between the standard Mobitex protocol and the Mobitex-NX protocol is that a callsign is included after the frame header and before the data blocks.
This is why you can read Callsign: right before the blocks start.
And because BEESAT-1 doesn’t send a callsign, all the blocks cannot be decoded.
Would you mind asking UZ7HO to modify his SoundModem to decode BEESAT-1 frames as well?
Daniel
I will forward this post to UZ7HO.
Can someone add the telemetry structure to this post?
Jan
What a great person, he already created and share an updated hs_soundmodem version for BEESAT-1
http://uz7.ho.ua/beesat1.zip
Maybe consider to send him a donation UZ7HO Personal page - Packet-Radio - English version
Can one of the BeeSAT team members check and confirm the output.
Great!
I confirm the output. It’s valid according to the telemetry format.
Can someone please confirm the downlink frequency? Here it says 435.950 Mhz, but N2Y0 says 436.00 MHz. Thanks!
435.950.
Thanks. H ad a high pass over Thailand, but no TM received :frowning:
I also monitored it a few times over South America, but without success.
I got 22 packets fully decoded on the best elevation pass over Germany started at 08:30 UTC today.
Today, PistonMiner from TU Berlin gave a presentation on the 38C3 CCC (Chaos Communication Congress) about how they got BEESAT-1 back to life.
The video is online (starting at around 16:30): Hacking yourself a satellite - recovering BEESAT-1
It’s in English, it’s fast and definitely well worth seeing.
