I fully created the os on raspberi 2 and made account but i dont know how to do a basic setup
Tell us more ![]()
The OS ? did you create an SD card image which contains the Satnogs setup, or is this a fresh OS install (if, which type) and do you need to install Satnogs manual. Is it a headless system with SSH access or do you have a desktop ?
Regards,
Ben
I made the sd with rasberi pi imgr, sudo apt updated and upgraded all and got to the config menu, i installed lighhtdm, but dunno how to run it in this setup, its headless for now
Have you followed the instructions in Raspberry Pi - SatNOGS Wiki and then in SatNOGS Setup - SatNOGS Wiki?
wow im blind, i couldnt see the api keyoption on my acc, now i see it
