In below observation, I can see it decoded in AX.25 frame, but the frame structure is not visible in data the ground station decoded. How does it getting data in AX.25 frame?
The HDLC address field is extended beyond one octet by assigning the least-significant bit of each octet to be an “extension bit”. The extension bit of each octet is set to zero, to indicate the next octet contains more address information, or one, to indicate this is the last octet of the HDLC address field. To make room for this extension bit, the amateur Radio call sign information is shifted one bit left.
While in decoding sequence, found out that DESTINATION SSID is 6 and extension bit is 0000. But in the decoded data, it the DESTINATION SSID is set to 0. Do you think it’s wrong? I appreciate your help.
