Autonomous ground station
Hi everyone,
I visited your booth at Fosdem.
I was just curious about how much is expensive to have the most simple ground station (like on my balcony) and if I can build it with just solar panels.
The wifi is already there but get also electricity will require more work.
From the wiki isn’t clear so much SatNOGS Wiki also if there is a kit that I can buy just to have an idea.
Also to understand if it is kind of a project that high schools can be interested to join.
Hi @mte90,
A simple ground station could be around 200-300 euros depending on the setup. The necessary parts are an RPi (or other supported platform) with an sd-card, an SDR (rtl-sdr should work fine) and an antenna, plus any cables for power/connection and casing needed.
I don’t think that solar panels will be the best or the cheapest solution but you can always experiment if it is easier for you.
Setting up a station could be a high school project with some guidance. Even better operating the station could be a good introduction in satellites for school students.
Thanks for the information because it isn’t find this kind of information in the wiki.
Some cost and component information is available at No rotator - SatNOGS Wiki
I see, it is missing like a prebuilt-kit.
