Auto vetting after client update from December 23, 2020
Hi!
After an update of SatNOGS a few days ago I get failed jobs every day.
Has the auto vetting algorithm or a setting changed?
The jobs listed below were shown as failed with good waterfall and audio. I looked at every waterfall and did set status to good manually.
73, Norbert
List of failed jobs, vetted good manually:
There are 2 reasons for an observation to be marked failed.
  1. No artifacts, when there is nothing uploaded from client for some time.
  2. When the audio is malformed or has duration that differs from the schedule one for more than 60 seconds.
For example in one of the observations above:
https://network.satnogs.org/observations/3405410/ the scheduled time is 15min 25s and the audio duration 14min 4s. For changing their status you can vet the waterfall.
Could you copy/paste here the result of “Advanced -> Support” from sudo satnogs-setup?
Other stations don’t have this issue, so I’m suspecting that maybe is something on the other settings or maybe something related with the sdr.
“versions”: {
“satnogs-client”: “1.4+6.g1020354”,
“satnogs-client-ansible”: “202012231828”,
“satnogs-flowgraphs”: “1.3-1”,
“gr-satnogs”: “2.2.0.0-1”,
“gr-soapy”: “2.1.3-1”,
“gnuradio”: “3.8.2.0-2”,
“satnogs-config”: “0.11+1.g8aee8ee”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2021-01-08T20:19:46.553743+00:00”,
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: true,
“platform”: {
“system”: “Linux”,
“node”: “satnogs”,
“release”: “5.4.79-v7+”,
“version”: “#1373 SMP Mon Nov 23 13:22:33 GMT 2020”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 969764864,
“available”: 603598848,
“percent”: 37.8,
“used”: 298414080,
“free”: 356990976,
“active”: 366538752,
“inactive”: 184651776,
“buffers”: 16412672,
“cached”: 297947136,
“shared”: 15331328,
“slab”: 31416320
“disk”: {
“total”: 31090814976,
“used”: 3824480256,
“free”: 25955876864,
“percent”: 12.8
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_dc_removal”: false,
“satnogs_rf_gain”: “43”,
“satnogs_rx_samp_rate”: “2.5e6”,
“satnogs_soapy_rx_device”: “driver=airspy”,
“satnogs_station_elev”: “35”,
“satnogs_station_id”: “1795”,
“satnogs_station_lat”: “53.835”,
“satnogs_station_lon”: “9.971”,
“satnogs_waterfall_max_value”: “-60”,
“satnogs_waterfall_min_value”: “-95”
