my station can’t run auto-scheduling and it always gets a message like this
2021-11-16 10:56:27,126 - auto_scheduler.satnogs_client - INFO - Requesting information for ground station 2394
2021-11-16 10:56:28,601 - auto_scheduler.satnogs_client - INFO - Ground station information retrieved!
2021-11-16 10:56:28,602 - root - INFO - Updating transmitters and TLEs for station
2021-11-16 10:56:28,606 - auto_scheduler.satnogs_client - INFO - Fetching transmitter information from DB.
2021-11-16 10:56:36,019 - auto_scheduler.satnogs_client - INFO - Transmitters received!
2021-11-16 10:56:36,076 - auto_scheduler.satnogs_client - INFO - Transmitters filtered based on ground station capability.
2021-11-16 10:56:36,077 - auto_scheduler.satnogs_client - INFO - Fetching transmitter information from DB.
2021-11-16 10:56:43,500 - auto_scheduler.satnogs_client - INFO - Transmitters received!
2021-11-16 10:56:43,563 - auto_scheduler.satnogs_client - INFO - Transmitters filtered based on ground station capability.
2021-11-16 10:56:43,567 - auto_scheduler.satnogs_client - INFO - Fetching satellite information from DB.
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/urllib3/connection.py", line 175, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/urllib3/util/connection.py", line 96, in create_connection
raise err
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/urllib3/util/connection.py", line 86, in create_connection
sock.connect(sa)
OSError: [Errno 101] Network is unreachable
During handling of the above exception, another exception occurred:
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/urllib3/connectionpool.py", line 706, in urlopen
chunked=chunked,
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/urllib3/connectionpool.py", line 382, in _make_request
self._validate_conn(conn)
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/urllib3/connectionpool.py", line 1010, in _validate_conn
conn.connect()
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/urllib3/connection.py", line 358, in connect
conn = self._new_conn()
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/urllib3/connection.py", line 187, in _new_conn
self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0xb5881af0>: Failed to establish a new connection: [Errno 101] Network is unreachable
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/urllib3/connectionpool.py", line 756, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/urllib3/util/retry.py", line 574, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='db.satnogs.org', port=443): Max retries exceeded with url: /api/satellites (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb5881af0>: Failed to establish a new connection: [Errno 101] Network is unreachable'))
File "./schedule_single_station.py", line 340, in <module>
main()
File "./schedule_single_station.py", line 187, in main
cache.update()
File "/home/pi/satnogs-auto-scheduler/auto_scheduler/cache.py", line 72, in update
alive_norad_cat_ids = get_satellite_info()
File "/home/pi/satnogs-auto-scheduler/auto_scheduler/satnogs_client.py", line 32, in get_satellite_info
r = requests.get('{}/api/satellites'.format(settings.DB_BASE_URL))
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/requests/api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/home/pi/satnogs-auto-scheduler/env/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='db.satnogs.org', port=443): Max retries exceeded with url: /api/satellites (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb5881af0>: Failed to establish a new connection: [Errno 101] Network is unreachable'))
How to solve it, thank you
