Ashbury College Junior School, Ottawa, ON, Canada, telebridge via VK5ZAI
The ISS callsign is presently scheduled to be NA1SS
The scheduled astronaut is David St-Jacques KG5FYI
Contact is go for: Wed 2019-01-23 19:51:36 UTC 22 deg
Several stations were able to receive parts of the contact:
- SatNOGS Network - Observation 427484 - Station: 162 - ZL1WJQ
- SatNOGS Network - Observation 427481 - Station: 56 - ZL4VBJ VHF
- SatNOGS Network - Observation 427483 - Station: 96 - sam210723 VHF
- SatNOGS Network - Observation 427482 - Station: 65 - QG62
- SatNOGS Network - Observation 427485 - Station: 334 - CyberOps III
- SatNOGS Network - Observation 426540 - Station: 15 - VK5QI-2M
- SatNOGS Network - Observation 426541 - Station: 305 - VK5KJP-VHF
- SatNOGS Network - Observation 427486 - Station: 232 - VK5QI-AZ/EL
Map of the ground track, the above mentioned SatNOGS ground stations and the contact site:
Congratulations and 73 to all!
More details about the contact from AMSAT-BB:
Click here for the details
An International Space Station school contact has been planned with participants at Ashbury College Junior School, Ottawa, ON, Canada
on 23 Jan. The event is scheduled to begin at approximately 19:51 UTC. It is recommended that you start listening approximately 10 minutes before this time. The duration of the contact is approximately 9 minutes and 30 seconds. The contact will be a telebridge between NA1SS and VK5ZAI. The contact should be audible over Australia and adjacent areas. Interested parties are invited to listen in on the 145.80 MHz downlink. The contact is expected to be conducted in English.
The Ashbury College Junior School is a co-ed independent school with 180 students from grades 4-8 in Ottawa. Our school’s motto, Honesty, Courage and Kindness, is lived every day by our students. Our students work hard in their academic courses and also participate in a wide variety of co-curricular programs and trips at the local, national and international levels.
Participants will ask as many of the following questions as time allows:
When you launched into space and during flight did the sound from the launch hurt your ears?
Sound travels to your ear on Earth by vibrating air molecules. Would you be able to communicate with another astronaut outside of the ISS without the use of a two-way radio?
Does light and sound travel at the same rate in space as it does on Earth?
What mental and physical training do you have to go through to prepare for life on the ISS?
How thick are the walls on the ISS?
How are the materials that are used to build structures in space changing?
How do you monitor space junk and meteors aboard the ISS to avoid collisions?
Every astronaut describes lift-off as having so much pressure on the body. Why don’t you suffer from the bends as the pressure is relieved once you are in space, as divers do?
What experiments are you currently doing in space? And how will they affect us on Earth?
How does the ISS maintain its temperature? What type of insulation does it use?
What temperature is it up in space, what is the coldest temperature you have witnessed?
Does the heat in space change dramatically when the ISS is near the sun?
Is space just really cold or does it have no temperature?
Does the lack of gravity on the ISS cause astronauts any pain?
How did the ISS get up to space and what is it made of?
How does your blood flow in space? Does your heart pump blood differently in space?
How do you maintain the carbon dioxide and oxygen levels in the ISS?
What happens when fluids collide aboard the ISS?
Can you see hurricanes or tsunamis from space?
How do you recycle the water? How long would you have, without water filtration, before you would need to be rescued?
How do you clean up floating liquids if they spill?
About ARISS:
Amateur Radio on the International Space Station (ARISS) is a cooperative venture of international amateur radio societies and the space agencies that support the International Space Station (ISS). In the United States, sponsors are the Radio Amateur Satellite Corporation (AMSAT), the American Radio Relay League (ARRL), the Center for the Advancement of Science in Space (CASIS) and National Aeronautics and Space Administration (NASA). The primary goal of ARISS is to promote exploration of science, technology, engineering, and mathematics (STEM) topics by organizing scheduled contacts via amateur radio between crew members aboard the ISS and students in classrooms or informal education venues. With the help of experienced amateur radio volunteers, ISS crews speak directly with large audiences in a variety of public forums. Before and during these radio contacts, students, teachers, parents, and communities learn about space, space technologies, and amateur radio. For more information, see www.ariss.org, www.amsat.org, and www.arrl.org.
Thank you & 73,
David - AA4KN
