After the latest updates from OOV-Cube, here is the current status (based on RF or optical observations only):
| Temporary NORAD ID | Satellite | NORAD ID to follow | Other NORAD IDs | Identified | Deployed | Last Update |
| RECEIVED AND DEMODULATED | ||||||
| 98877 | ISTSAT-1 | 60238 | 60236(unlikely), 60237, 60241(unlikely) | NO | YES | Continue to follow 60238, other possible 60236(unlikely), 60237, 60241(unlikely) |
| 98882 | GRBBeta | 60237 | 60236, 60238(unlikely) | NO | YES | Received and Decoded, continue to follow 60237, other possible 60236, 60238(unlikely) |
| - | ROBUSTA-3A | 60243 | - | YES | YES | Identified, here are the ikhnos results |
| - | OOV-Cube | 60240 | - | YES | YES | Identified, here are the ikhnos results |
| RECEIVED | ||||||
| 98878 | 3CAT-4 | 60236 | 60237, 60238, 60241 | NO | YES | Received, changed to follow 60236, other possible 60237, 60238, 60239(unlikely), 60241 - last reception at 2024-07-10 18:05:36 |
| - | Ariane 6 - Upper Stage | 60239 | - | YES | YES | Identified, confirmation by optical observation, extra one with this tweet by s2a_systems and also confirmed by space-track.org “RCS_SIZE” value which is the only object of this launch being “LARGE” |
| - | Curium One | 60242 | - | YES | YES | Identified, here are the ikhnos results |
| NOT RECEIVED | ||||||
| 98875 | Replicator (ORBIT-3D) | 60235 | All (except identified) | NO | YES | Not Received, randomly assinged to follow 60235, other possible All (except identified) |
| 98879 | CURIE | 60241 | All (except identified) | NO | YES | Not Received, randomly assinged to follow 60241, other possible All (except identified) |
| NOT IN DB | ||||||
| SpaceCase SC-X01 | - | NO | NO | |||
| NyxBikini | NO | NO |
Here is the updated RCA SIZE values table, based on satellite sizes and with addition of notes based on RF observations:
| OBJECT | RCS_SIZE | POSSIBLE OBJECTS | NOTES |
| 60235 | SMALL | ISTAT-1(1U)(unlikely), GRBBeta(2U)(unlikely), 3CAT-4(1U)(unlikely), Replicator(3U) |
| 60236 | SMALL | ISTAT-1(1U)(unlikely), GRBBeta(2U), 3CAT-4(1U), Replicator(3U) |
| 60237 | MEDIUM | CURIE(6U) |
Given its position/orbit and RF data from observations this could be a small satellite |
| 60238 | SMALL | ISTAT-1(1U), GRBBeta(2U)(unlikely), 3CAT-4(1U), Replicator(3U) |
| 60239 | LARGE | ARIANE - UPPER STAGE |
Identified |
| 60240 | MEDIUM | OOV-CUBE(25x25x25cm) |
Identified |
| 60241 | MEDIUM | CURIE(6U), |
| 60242 | MEDIUM | CURIUM ONE(12U) |
Identified |
| 60243 | SMALL | ROBUSTA-3A(3U) |
Identified |
