:rocket: ArcticSat satellite starts transmitting SSTV images in honor of the “White June” festival - a multi-format city festival, the program of which unites many cultural areas!
:satellite_antenna: Frequency: 435.890 MHz (ArcticSat-1, RS74S)
Broadcasting territory: worldwide
Protocol: SSTV Robot 36
Broadcast start: June 27, 2025 21:00 UTC - has already begun!
Scheduled end of broadcast: June 28, 2025 21:00 UTC
Only 1 image, 150 second interval
Transmission may be interrupted without prior notice (due to temperature increase, battery discharge, etc.)
07:45UTC
Jomjom79
Got the same image 3 times a few minutes earlier (0740+) over the uk.
Me too.
2025-06-28 07:42
Got my QSL card.
Yes, mine arrived this afternoon too. Thanks to the team for the activation and qsl.
:double_exclamation_mark: The ArcticSat-1 (RS74S) is transmitting only one image in SSTV RB-36 in worldwide. From what I can tell, the transmission interval is approximately 3 minutes.
Freq: 435.890 MHz
There is no specific date for the end of transmissions.
Note: The transmission lasts a little longer than standard transmissions in Robot-36 and this causes my decoding software to start a second image.
See below the original image in a higher resolution :
@pu4elt Thanks for heads-up :slightly_smiling_face: Managed to catch this on the 075xUTC pass over UK.
ArcticSat-1 (RS74S) 11-Aug-25 0754UTC
250813_06.45UTC_ArcticSat1(RS74S) approx. 10° height.
:double_exclamation_mark: A new image is being transmitted by the ArcticSat-1 (RS74S) !!
Transmission interval is approximately 5 minutes.
This is the Octo-Pax (a 3D-printed octopus) inside ArcticSat-1 in orbit.
See below the same image transmitted in SSTV, but in a higher resolution :slight_smile:
@pu4elt Thanks again for heads-up on this new image. Managed to grab it on the 073xUTC pass over UK. A little more noise that your capture but with the 5min gap between transmission only got the one shot at reception.
ArcticSat-1 (RS74S) 0740Z 19-Aug-25
new image! 2025-08-26 23:30
APPARENTLY the ArcticSat-1 (RS74S) should transmit SSTV continuously :smiley:
I see that the interval between images remains at 5 minutes. Tonight here in Brazil, I’ll try to receive the new image :zany_face:
2025-08-26_08.00.51 UTC
This is the best I’ve had as the passes here are not that high.
Had a good 48° pass over Norway here now. Lots of telemetry but no SSTV.
Jomjom79
