Apr-2026: Anything change w/ SIDS upload?
Hello! Sometime around 1-Apr-2026, my long-time scripts that upload Arduino LoRa decodes to the SatNogs database stopped working. Specifically, instead of receiving a -201 return code (of a successful upload), I’m not seeing any return at all and when I cross-check the recent uploads to the object in question, my upload is not there.
Has anything recently changed in how one needs to interact w/ db.satnogs.org when posting a SIDS upload?
Thanks very much!
Seeing the following on some POSTMAN testing - so perhaps some authentication fields need to be added to my upload. Glad to do so! Appreciate a pointer to the format if someone has a chance to reply before I (hopefully) find it.
“detail”: “Authentication credentials were not provided.”
As far as I know no change happened to the chain. Let me send you a pm to find out what’s going on.
