Greetings,
I’m seeking help with the ansible/footloose/docker satnogs-client installation using this guide.
I’d like to run multiple containers on the same computer (i7/16 GB RAM/1TB HDD running Debian Buster) instead of just one but I don’t quite understand the Ansible file syntax enough to get it working despite my many many failed attempts.
I do have a single container working running as ‘satnogs-node0’ for ground station 2134.
Here’s the part of the guide I focusing on:
Optionally: Configure
footloose.yaml
andproduction/inventory/footloose
for multiple SatNOGS containers
So footloose.yaml looks like
cluster:
privateKey: satnogs-key
machines:
- count: 2
spec:
backend: docker
image: quay.io/footloose/debian10
portMappings:
- containerPort: 22
privileged: true
volumes:
- type: bind
source: /sbin/modprobe
destination: /sbin/modprobe
- type: bind
source: /lib/modules/
destination: /lib/modules/
running
footloose create
works and generate two containers but I think I am not editing the 2nd file correctly
The file production/inventory/footloose
reads:
--- all: hosts: satnogs: ansible_connection: docker ansible_python_interpreter: "/usr/bin/env python3" ansible_host: 'satnogs-node0' ansible_user: 'root' ansible_ssh_private_key_file: 'satnogs-key' ansible_ssh_pipelining: true satnogs-setups: hosts: satnogs: satnogs-radios: hosts: satnogs: hamlib-utils: hosts: satnogs: satnogs-clients: hosts: satnogs: snmpds: hosts: satnogs: gpsds: hosts: satnogs:
What do I add/change to this yml code to allow 2 (3 ,4 5 …) containers to properly generated?
I’ve tried changing this to
ansible_host: ‘satnogs-node2’
and
ansible_host: ‘satnogs-node%d’
No joy. Thanks for any help you can offer.
