[Announcement] SatNOGS station software upgrades are available
2026-10-02
Manifest
Software component Version
SatNOGS Ansible 202610021327
SatNOGS Config 1.2-284
SatNOGS Client 2.1.4-694
SatNOGS Flowgraphs 2.7-1
gr-satnogs 3.1.0.1-1
GNU Radio 3.10.5.1-satnogs
Hamlib 4.5.4-39
Ansible 9.13.0
Changelog
SatNOGS Ansible
  • 202610021327
    • Bump ‘satnogs-client’ Docker image version
    • Add AI policy to contribution guide
SatNOGS Client
  • 2.1.4-694
    • gitlab-ci: Bump GitLab CI templates
  • 2.1.3
    • gitlab-ci: Create additional tags which include build number
SatNOGS Flowgraphs
  • 2.7-1
    • Add flowgraph for SIDLOC
  • 2.6.2-1
    • Add audio sink for FSK QUBIK
  • 2.6.1-1
    • Fix FSK QUBIK frame size
  • 2.6-1
    • Add support for QUBIK transmissions
  • 2.5.6-1
    • Add decoder name in decoded frame
  • 2.5.5-1
    • Add gr-satellites to build dependencies
  • 2.5.4-1
    • Reenable AX.100 Mode 5 flowgraph
  • 2.5.3-1
    • Disable AX.100 Mode 5 flowgraph
Update instructions
Instructions on how to update can be found under wiki section Updating SatNOGS Client Software.
Note: During an update from versions <202601141228, the initial run of satnogs-setup will fail with an error. This is expected due to limitations in the previous version of the script. If you encounter this error, simply re-run satnogs-setup and it should then proceed normally.
