gm
with my new installation i thought all ok…but no…
This is my log error…can you help me ?
73 Eric
Mar 16 07:01:30 raspberrypi systemd[1]: Started SatNOGS client.
Mar 16 08:24:18 raspberrypi satnogs-client[383]: rot_init called
Mar 16 08:24:18 raspberrypi satnogs-client[383]: dummy: _init called
Mar 16 08:24:18 raspberrypi satnogs-client[383]: rot_register (1)
Mar 16 08:24:18 raspberrypi satnogs-client[383]: rot_register (2)
Mar 16 08:24:18 raspberrypi satnogs-client[383]: dummy_rot_init called
Mar 16 08:24:18 raspberrypi satnogs-client[383]: rot_open called
Mar 16 08:24:18 raspberrypi satnogs-client[383]: dummy_rot_open called
Mar 16 08:24:18 raspberrypi satnogs-client[383]: rot_get_position called
Mar 16 08:24:18 raspberrypi satnogs-client[383]: dummy_rot_get_position called
Mar 16 08:24:18 raspberrypi satnogs-client[383]: rot_set_position called
Mar 16 08:24:22 raspberrypi satnogs-client[383]: [INFO] [UHD] linux; GNU C++ version 8.3.0; Boost_106700; UHD_3.15.0.0-2
Mar 16 08:24:22 raspberrypi satnogs-client[383]: Found Elonics E4000 tuner
Mar 16 08:24:22 raspberrypi satnogs-client[383]: Traceback (most recent call last):
Mar 16 08:24:22 raspberrypi satnogs-client[383]: File “/usr/bin/satnogs_fsk_ax25.py”, line 475, in
Mar 16 08:24:22 raspberrypi satnogs-client[383]: main()
Mar 16 08:24:22 raspberrypi satnogs-client[383]: File “/usr/bin/satnogs_fsk_ax25.py”, line 460, in main
Mar 16 08:24:22 raspberrypi satnogs-client[383]: tb = top_block_cls(antenna=options.antenna, baudrate=options.baudrate, bw=options.bw, decoded_data_file_path=options.decoded_data_file_path, dev_a
Mar 16 08:24:22 raspberrypi satnogs-client[383]: File “/usr/bin/satnogs_fsk_ax25.py”, line 79, in init
Mar 16 08:24:22 raspberrypi satnogs-client[383]: self.soapy_source_0 = soapy.source(1, dev, dev_args, samp_rate_rx, “fc32”)
Mar 16 08:24:22 raspberrypi satnogs-client[383]: File “/usr/lib/python3/dist-packages/soapy/soapy_swig.py”, line 160, in make
Mar 16 08:24:22 raspberrypi satnogs-client[383]: return _soapy_swig.source_make(nchan, device, args, sampling_rate, type)
Mar 16 08:24:22 raspberrypi satnogs-client[383]: RuntimeError: soapy::source: Unsupported sample rate. Rate must be between 8000.000000 and 96000.000000
Mar 16 08:24:27 raspberrypi satnogs-client[383]: 2020-03-16 08:24:27,015 - satnogsclient.observer.observer - ERROR - No waterfall data file found
Mar 16 08:31:53 raspberrypi satnogs-client[383]: [INFO] [UHD] linux; GNU C++ version 8.3.0; Boost_106700; UHD_3.15.0.0-2
Mar 16 08:31:53 raspberrypi satnogs-client[383]: Found Elonics E4000 tuner
Mar 16 08:31:53 raspberrypi satnogs-client[383]: Traceback (most recent call last):
Mar 16 08:31:53 raspberrypi satnogs-client[383]: File “/usr/bin/satnogs_fsk_ax25.py”, line 475, in
Mar 16 08:31:53 raspberrypi satnogs-client[383]: main()
Mar 16 08:31:53 raspberrypi satnogs-client[383]: File “/usr/bin/satnogs_fsk_ax25.py”, line 460, in main
Mar 16 08:31:53 raspberrypi satnogs-client[383]: tb = top_block_cls(antenna=options.antenna, baudrate=options.baudrate, bw=options.bw, decoded_data_file_path=options.decoded_data_file_path, dev_a
Mar 16 08:31:53 raspberrypi satnogs-client[383]: File “/usr/bin/satnogs_fsk_ax25.py”, line 79, in init
Mar 16 08:31:53 raspberrypi satnogs-client[383]: self.soapy_source_0 = soapy.source(1, dev, dev_args, samp_rate_rx, “fc32”)
Mar 16 08:31:53 raspberrypi satnogs-client[383]: File “/usr/lib/python3/dist-packages/soapy/soapy_swig.py”, line 160, in make
Mar 16 08:31:53 raspberrypi satnogs-client[383]: return _soapy_swig.source_make(nchan, device, args, sampling_rate, type)
Mar 16 08:31:53 raspberrypi satnogs-client[383]: RuntimeError: soapy::source: Unsupported sample rate. Rate must be between 8000.000000 and 96000.000000
Mar 16 08:31:57 raspberrypi satnogs-client[383]: 2020-03-16 08:31:57,011 - satnogsclient.observer.observer - ERROR - No waterfall data file found
