I am trying to put my 2m station back in service. This station uses an RTL-SDR and a two element turnstyle antenna. It very successfully decoded a year or two ago before I rearranged some things around here. I followed the instructions to flash the SD card and configure the parameters with satnogs-setup. Attached is a screenshot of some console messages and I have others available. Can anyone suggest how I can get this working properly? Thanks in advance.
I just tried again to schedule an observation and the attached error message resulted: “No waterfall data file found”. How do I fix that?
The unbound message is an indication of no network connection.
Can you share the output off the following command:
sudo satnog-setup → Advanced → Support and share the output of the support information.
Hi @kc4le-2m,
The satnogs_soapy_rx_setting should be:
driver=rtlsdr
So drop the - that you have in there now and see if that helps
Scott
WoW! I usually pride myself on DETAILS like this. I have scheduled a few observations to see if that ONE character corrects the problem. I will respond to confirm.
And THANKS to satcolintel5 - I bet that tweak works…
I am still getting some questionable results. The observation shown in the attached photo was apparently auto-vetted, but there is no signal evident in the waterfall.
The console messages are now looking much more normal, although I can interpret very little of it. In the attached photo, I notice the message “UnboundLocalError: local variable “response” referenced before assignment”. I was also getting that error before I corrected the satnogs_soapy_rx_setting. I wonder if that is an error in the code or in my configuration?
I looked up your observation and I think you have not set the gain.
Can you set the gain to a value, like 49.6.
AHHH! I set the gain figure. I will schedule some observations and see what we get - I will post the results here.
Thank you, EelkeVisser
