i copy paste here, from #satnogs:matrix.org,
fredy
Tbh I thought that there would be hardware limits to avoid any damage in stations, but this doesn’t seem to be the case. So, now we will have a soft and hard limits on both min horizon (elevation where the tracking of pass starts and ends) and min culmination (the min maximum elevation of the pass), I have some examples in the issue to make it more understandable how it will work.
me
can you give example . thank you
fredy
Ok let’s say we have 2 passes, all of them LEOP, so they start from 0 degrees, to max elevation and end up to 0 degrees:Max elevation 10 degrees
Max elevation 40 degrees
Station with min horizon set to 5 and min culmination set to 15a) Hard limits on both settings
pass 1 is not going to be scheduled (10 max elevation < 15 min culmination )
pass 2 is going to be scheduled, it will start from 5 degrees, to the max 40 degrees and back to 5 degrees (40 max elevation > 15 min culmination, the observation starts from/ends to hard min horizon 5)b) Soft limits on both settings, observer set them to 0 (if not overwitten by observer see “a)”)
pass 1 is going to be scheduled, it will start from 0 degrees, to the max 10 degrees and back to 0 degrees (10 max elevation > 0 overwritten min culmination, the observation starts from/ends to overwritten min horizon 0)
pass 2 is going to be scheduled, it will start from 0 degrees, to the max 40 degrees and back to 0 degrees (40 max elevation > 0 overwritten min culmination, the observation starts from/ends to overwritten min horizon 0)c) Hard limit on min horizon, soft limit on min culmination, observer set min culmination to 5 (if not overwitten by observer see “a)”)
pass 1 is going to be scheduled, it will start from 5 degrees, to the max 10 degrees and back to 5 degrees (10 max elevation > 5 overwritten min culmination, the observation starts from/ends to hard min horizon 5)
pass 2 is going to be scheduled, it will start from 5 degrees, to the max 40 degrees and back to 5 degrees (40 max elevation > 5 overwritten min culmination, the observation starts from/ends to hard min horizon 5)d) Soft limit on min horizon, hard limit on min culmination, observer set min horizon to 2 (if not overwitten by observer see “a)”)
pass 2 is going to be scheduled, it will start from 2 degrees, to the max 40 degrees and back to 2 degrees (40 max elevation > 15 min culmination, the observation starts from/ends to overwritten min horizon 2)Two notes:
Note 1: Min culmination doesn’t make a lot of sense to be under min horizon as a value
Note 2: In case the pass based on the set parameters isn’t long enough (currently >2min) it will not be available for scheduling even if satisfies the limits
me
give me 24 hour. i should read it very slowly.
btw is it work for all station? or only latest satnogs-client ?
fredy
the limits are set and used in Network and not related with the satnogs-client
hm… we need to make sure what happens in case of hard limits and TLE changes, maybe we have a bug there, I’ll check it and come back. Maybe we should not update TLE in observations in case the station has hard limits set.
