jga@raspberrypi:~ $ journalctl -f -u satnogs-client.service
-- Journal begins at Sat 2022-09-10 19:10:32 CEST. --
Mär 02 09:19:33 raspberrypi satnogs-client[31086]: main()
Mär 02 09:19:33 raspberrypi satnogs-client[31086]: File "/usr/bin/satnogs_amsat_fox_duv_decoder.py", line 498, in mainMär 02 09:19:33 raspberrypi satnogs-client[31086]: tb = top_block_cls(antenna=options.antenna, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_dump_host=options.udp_dump_host, udp_dump_port=options.udp_dump_port, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path)
Mär 02 09:19:33 raspberrypi satnogs-client[31086]: File "/usr/bin/satnogs_amsat_fox_duv_decoder.py", line 92, in __init__
Mär 02 09:19:33 raspberrypi satnogs-client[31086]: self.soapy_source_0_0 = soapy.source(1, dev, dev_args, stream_args,
Mär 02 09:19:33 raspberrypi satnogs-client[31086]: File "/usr/lib/python3/dist-packages/soapy/soapy_swig.py", line 131, in make
Mär 02 09:19:33 raspberrypi satnogs-client[31086]: return _soapy_swig.source_make(nchan, device, dev_args, stream_args, tune_args, other_settings, sampling_rate, type)
Mär 02 09:19:33 raspberrypi satnogs-client[31086]: RuntimeError: device_id missing.
Mär 02 09:19:34 raspberrypi satnogs-client[7163]: netrigctl_close: done status=Command completed successfully
Mär 02 09:19:37 raspberrypi satnogs-client[7163]: satnogsclient.observer.observer - ERROR - No waterfall data file found
Generating support report. Please wait...
"versions": {
"satnogs-client": "1.8.1",
"satnogs-client-ansible": "202209101521",
"gr-satnogs": "2.3.3.0-1",
"gr-soapy": "2.1.3.1-1",
"gnuradio": "3.8.2.0-14",
"satnogs-config": "0.13.2"
"state": {
"is-applied": true,
"pending-tags": null
"system": {
"date": "2023-03-02T09:47:14.157608+00:00",
"distribution": {
"DESCRIPTION": "Raspbian GNU/Linux 11 (bullseye)",
"RELEASE": "11",
"CODENAME": "bullseye",
"ID": "Raspbian"
"pending-updates": true,
"platform": {
"system": "Linux",
"node": "raspberrypi",
"release": "5.15.84-v7l+",
"version": "#1613 SMP Thu Jan 5 12:01:26 GMT 2023",
"machine": "armv7l"
"memory": {
"total": 1963307008,
"available": 1734193152,
"percent": 11.7,
"used": 142430208,
"free": 1389641728,
"active": 235225088,
"inactive": 248397824,
"buffers": 32043008,
"cached": 399192064,
"shared": 950272,
"slab": 39772160
"disk": {
"total": 31068966912,
"used": 4171014144,
"free": 25580613632,
"percent": 14.0
"configuration": {
"satnogs_antenna": "RX",
"satnogs_gain_mode": "Settings Field",
"satnogs_other_settings": "LNA=10,Mix=7,VGA=11",
"satnogs_rx_samp_rate": "2.5e6",
"satnogs_soapy_rx_device": "driver=airspy,biastee=true",
"satnogs_station_elev": "170",
"satnogs_station_id": "1875",
"satnogs_station_lat": "48.3734",
"satnogs_station_lon": "7.8836"
