Having just rebuilt my station I’m not receiving waterfall data from scheduled passes, showing ‘Failed’ and as expected No Data. Whereas previously it performed quite well.
The UHF station comprises Turnstile antenna, Nooelec LaNA Wideband filter, Airspy R2, RPi 3B.
All connections have been double checked, feeds and cables checked, and the SatNOGS client showing no errors before startup.
I have given below the results from various logs. NB: A RunTime error showing device_id missing??
Any thoughts/suggestions please on what the cause could be?
Support Report:
"versions": {
"satnogs-client": "1.8.1",
"satnogs-client-ansible": "202209101521",
"gr-satnogs": "2.3.5.0-1",
"gr-soapy": "2.1.3.1-1",
"gnuradio": "3.8.2.0-14",
"satnogs-config": "0.13.2"
"state": {
"is-applied": true,
"pending-tags": null
"system": {
"date": "2024-03-04T16:55:48.028343+00:00",
"distribution": {
"DESCRIPTION": "Raspbian GNU/Linux 11 (bullseye)",
"RELEASE": "11",
"CODENAME": "bullseye",
"ID": "Raspbian"
"pending-updates": false,
"platform": {
"system": "Linux",
"node": "snogs2122",
"release": "6.1.21-v7+",
"version": "#1642 SMP Mon Apr 3 17:20:52 BST 2023",
"machine": "armv7l"
"memory": {
"total": 779665408,
"available": 608632832,
"percent": 21.9,
"used": 114413568,
"free": 257769472,
"active": 189964288,
"inactive": 273932288,
"buffers": 25812992,
"cached": 381669376,
"shared": 749568,
"slab": 35364864
"disk": {
"total": 15129337856,
"used": 3896750080,
"free": 10563592192,
"percent": 26.9
"configuration": {
"satnogs_antenna": "RX",
"satnogs_gain_mode": "Settings Field",
"satnogs_other_settings": "LNA=9,MIX=6,VGA=11",
"satnogs_rf_gain": "43",
"satnogs_rx_samp_rate": "2.5e6",
"satnogs_soapy_rx_device": "driver=airspy,biastee=true",
"satnogs_station_elev": "140",
"satnogs_station_id": "2122",
"satnogs_station_lat": "53.0668",
"satnogs_station_lon": "-2.7432"
"configuration": {
"satnogs_station_id": "",
MetaData
* [radio](https://network.satnogs.org/observations/9142911/): {
* name: "gr-satnogs",
* version: "v2.3-compat-xxx-v2.3.5.0",
* [parameters](https://network.satnogs.org/observations/9142911/): {
* soapy-rx-device: "driver=airspy,biastee=true",
* samp-rate-rx: "2.5e6",
* rx-freq: "435950000",
* file-path: "/tmp/.satnogs/data/receiving_satnogs_9142911_2024-03-04T15-12-38.out",
* waterfall-file-path: "/tmp/.satnogs/data/receiving_waterfall_9142911_2024-03-04T15-12-38.dat",
* decoded-data-file-path: "/tmp/.satnogs/data/data_9142911",
* doppler-correction-per-sec: null,
* lo-offset: null,
* ppm: null,
* rigctl-port: "4532",
* gain-mode: "Settings Field",
* gain: "43",
* antenna: "RX",
* dev-args: null,
* stream-args: null,
* tune-args: null,
* other-settings: "LNA=9,MIX=6,VGA=11",
* dc-removal: null,
* bb-freq: null,
* bw: null,
* enable-iq-dump: "0",
* iq-file-path: null,
* udp-dump-host: null,
* udp-dump-port: 57356,
* wpm: null,
* baudrate: "9600",
* framing: "ax25"
* latitude: 53.0668,
* longitude: -2.7432,
* elevation: 140,
* frequency: 435950000
**$** journalctl -f -u satnogs-client.service
-- Journal begins at Tue 2023-11-14 21:44:27 GMT. --
Mar 04 15:12:43 snogs2122 satnogs-client[1127]: main()
Mar 04 15:12:43 snogs2122 satnogs-client[1127]: File "/usr/bin/satnogs_fsk.py", line 527, in main
Mar 04 15:12:43 snogs2122 satnogs-client[1127]: tb = top_block_cls(antenna=options.antenna, baudrate=options.baudrate, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, framing=options.framing, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_dump_host=options.udp_dump_host, udp_dump_port=options.udp_dump_port, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path)
Mar 04 15:12:43 snogs2122 satnogs-client[1127]: File "/usr/bin/satnogs_fsk.py", line 97, in __init__
Mar 04 15:12:43 snogs2122 satnogs-client[1127]: self.soapy_source_0_0 = soapy.source(1, dev, dev_args, stream_args,
Mar 04 15:12:43 snogs2122 satnogs-client[1127]: File "/usr/lib/python3/dist-packages/soapy/soapy_swig.py", line 131, in make
Mar 04 15:12:43 snogs2122 satnogs-client[1127]: return _soapy_swig.source_make(nchan, device, dev_args, stream_args, tune_args, other_settings, sampling_rate, type)
Mar 04 15:12:43 snogs2122 satnogs-client[1127]: RuntimeError: device_id missing.
Mar 04 15:12:45 snogs2122 satnogs-client[1040]: netrigctl_close: done status=Command completed successfully
Mar 04 15:12:47 snogs2122 satnogs-client[1040]: satnogsclient.observer.observer - ERROR - No waterfall data file found
**$** lsusb
Bus 001 Device 004: ID 1d50:60a1 OpenMoko, Inc. Airspy
Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
ls -l /etc/udev/rules.d/
total 8
-rw-r--r-- 1 root root 459 Mar 3 13:10 64-limesuite.rules
-rw-r--r-- 1 root root 1883 May 10 2023 99-com.rules
**$** sudo journalctl -f -u satnogs-client -n 512
Mar 04 14:50:40 snogs2122 satnogs-client[413]: apscheduler.executors.default - WARNING - Run time of job "get_jobs (trigger: interval[0:01:00], next run at: 2024-03-04 14:50:56 UTC)" was missed by 0:00:44.049736
Mar 04 14:50:40 snogs2122 satnogs-client[413]: apscheduler.executors.default - WARNING - Run time of job "post_data (trigger: interval[0:03:00], next run at: 2024-03-04 09:59:56 UTC)" was missed by 0:02:43.733015
Mar 04 15:03:38 snogs2122 systemd[1]: Stopping SatNOGS client...
Mar 04 15:03:38 snogs2122 systemd[1]: satnogs-client.service: Succeeded.
Mar 04 15:03:38 snogs2122 systemd[1]: Stopped SatNOGS client.
Mar 04 15:03:38 snogs2122 systemd[1]: **satnogs-client.service: Consumed 9.992s CPU time.**
Mar 04 15:03:38 snogs2122 systemd[1]: Started SatNOGS client.
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: rot_init called
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: initrots4_dummy: _init called
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: rot_register (1)
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: rot_register (2)
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: dummy_rot_init called
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: rot_open called
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: dummy_rot_open called
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: rot_get_position called
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: dummy_rot_get_position called
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: rot_get_position: got az=0.00, el=0.00
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: rot_set_position called az=18.70 el=0.44
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: rot_set_position: south_zero=0
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: dummy_rot_set_position called: 18.70 0.44
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: rig_init: rig does not have rx_range!!
Mar 04 15:12:38 snogs2122 satnogs-client[1040]: network_open: hoststr=127.0.0.1, portstr=4532
Mar 04 15:12:43 snogs2122 satnogs-client[1127]: Traceback (most recent call last):
Mar 04 15:12:43 snogs2122 satnogs-client[1127]: File "/usr/bin/satnogs_fsk.py", line 544, in <module>
Mar 04 15:12:47 snogs2122 satnogs-client[1040]: satnogsclient.observer.observer – ERROR – No waterfall data file
