Hello. I have just upgraded to client 1.8.1 by re-installing everything from the beginning (new RPI install). I have used Airspy Mini before without any problem. Now soapy can not find the Airspy device.
Running SoapySDRUtil --probe it can not be found. I have tested several USB ports and also on a Windows PC. The Airspy Mini can be found on the PC without any problem.
I have switched to a RTL-SDR v3 and it it is working without any issues.
Help needed please. Below is the support info.
//Lars SM0TGU
“versions”: {
“satnogs-client”: “1.8.1”,
“gr-satnogs”: “2.3.3.0-1”,
“gr-soapy”: “2.1.3.1-1”,
“gnuradio”: “3.8.2.0-14”,
“satnogs-config”: “0.13.2”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2022-11-28T08:11:11.597570+00:00”,
“distribution”: {
“RELEASE”: “11”,
“CODENAME”: “bullseye”,
“ID”: “Raspbian”
“pending-updates”: false,
“platform”: {
“system”: “Linux”,
“node”: “SATNOGSSM0TGU”,
“release”: “5.15.76-v7+”,
“version”: “#1597 SMP Fri Nov 4 12:13:17 GMT 2022”,
“machine”: “armv7l”
“memory”: {
“total”: 966930432,
“available”: 794521600,
“percent”: 17.8,
“used”: 118054912,
“free”: 635592704,
“active”: 120991744,
“inactive”: 147861504,
“buffers”: 20787200,
“cached”: 192495616,
“shared”: 737280,
“slab”: 30384128
“disk”: {
“total”: 31068966912,
“used”: 3880697856,
“free”: 25870929920,
“percent”: 13.0
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_gain_mode”: “Settings Field”,
“satnogs_other_settings”: “LNA=10,MIX=8,VGA=10”,
“satnogs_rf_gain”: “32.8”,
“satnogs_rx_samp_rate”: “3e6”,
“satnogs_soapy_rx_device”: “driver=airspy”,
“satnogs_station_elev”: “5”,
“satnogs_station_id”: “858”,
“satnogs_station_lat”: “59.453”,
“satnogs_station_lon”: “17.890”,
“satnogs_waterfall_min_value”: “-90”,
“udp_dump_host”: “127.0.0.1”
