Adding TinyGS TLE
I have tried to add the list of TinyGS satellites to Gpredict with no luck. The URL that I added was " https://api.tinygs.com/v1/tinygs_supported.txt" After updating the list of TinyGS satellites were not added to the list when I try to create a new module. Looking in the log shows a bad or incorrect URL. The instructions I followed came from the tinyGS wiki. TLE · G4lile0/tinyGS Wiki · GitHub
I am using Gpredict version 2.3-72-gc596101-3 running on a Raspberry Pi 4b.
Thank you,
Larry
FWIW I was able to use the URL in question without issue with SDR Console Satellite Tracker. As for Gpredict, I was able to import the TinyGS text file into Gpredict and it works fine using that method.
Larry
