Add Station Problem
He is some screen shots of the issue we are having when adding a station to https://network-dev.satnogs.org/.
The problem ended up being the “m” in altitude. I’ve added this issue to https://github.com/satnogs/satnogs-network/issues/186
Not sure if this is related but can’t update antennas or rig fields.
These are both predefined lists. Do you want to add an antenna that doesn’t exist on the list?
No, the fields were greyedout and there was no drop down option or ability to change in the edit boxes, same for rig
