Hi all!
During this summer I have been working with new hardware for station 858 located in Sollentuna (Stockholm) Sweden. As this station is popular I would like to support the community with better possibility to decode UHF satellites.
The new antenna is a 5 element DK7ZB style yagi pointed to zenit (90 degree elevation). The antenna is designed for 435 MHz but works OK down to VHF, so it is open from 140 MHz.
I also had some problem with lost samples using a Airspy Mini with Raspberry PI 3, so I upgraded to Raspberry PI 4.
The addon “satnogs_gr-satellites” is installed so for example Funcube-1 can be decoded. I also doing some tests with new Airspy driver.
In the near future I will also try to add a LNA and maybe make the Yagi to a 5 element circular polarisation.
Feel free to use station 858! https://network.satnogs.org/stations/858/
