Can someone create the necessary STL files to convert the 40mm metric pvc to fit imperial (USA) pipe? (Believe it’s 1 1/4")
Nobody has made any imperial versions since 3.0, they were left out of 3.0.1 and 3.1.
Im wanting the 3.1 parts that has the mechanical endstops, etc.
Hey, take a look here in last comment. But if you found a cheap imperial axis, we could change the parts, axis_gear_as5601, axis_gear_flange and axis_spacer in v3.1. Also it is necessary to design an adapter for axis ball bearings.
