fredy
December 6, 2024, 5:32pm
1
Latest Update 2024-12-09 07:55 UTC
Temporary NORAD ID
Satellite
Frequency
Notes
Deployed
AMATEUR VHF
98736
YOMOGI
145.825 MHz
APRS Digipeater IARU Coordinated
Kibo ISS (JAXA)
AMATEUR UHF
98738
LignoSat
435.820 MHz
IARU Coordinated
Kibo ISS (JAXA)
98736
YOMOGI
437.375 MHz
IARU Coordinated
Kibo ISS (JAXA)
OTHER FREQUENCIES (UHF, L-Band, S-Band)
98735
YODAKA
922.000 MHz
frequency from ITU entry
Kibo ISS (JAXA)
98734
DENDEN-01
922.000 MHz
Kibo ISS (JAXA)
98733
ONGLAISAT
922.000 MHz
Kibo ISS (JAXA)
98735
YODAKA
2277.300 MHz
Kibo ISS (JAXA)
98734
DENDEN-01
2277.300 MHz
Kibo ISS (JAXA)
98733
ONGLAISAT
2277.300 MHz
Kibo ISS (JAXA)
OTHER FREQUENCIES (X-Band)
98735
YODAKA
8160.000 MHz
Kibo ISS (JAXA)
98733
ONGLAISAT
8160.000 MHz
Kibo ISS (JAXA)
JAXA announcement :
The deployment event for those satellites by J-SSOD#30 will be broadcast via YouTube JAXA Channel.
December 9, 2024 (Monday)
PS More details about the satellites and their frequencies will be added in the next days
fredy
December 9, 2024, 7:57am
2
I’ve updated the first post with the necessary frequency info for the satellites.
I’m going to schedule observations for LignoSat and YOMOGI for the first 24h, I’m not going further in time as the initial TLE will be those of ISS during the deployment and we will need soon to update them.
To station owners, If you are going to schedule passes, please make sure you are going to leave some passes for ISS, as the satellites will share similar orbit with ISS for the first days.
Edit: APRS digipeater of YOMOGI will be inactive during the first orbits, if you schedule it you may only receive APRS messages from ISS.
fredy
December 9, 2024, 12:12pm
3
It looks like YOMOGI CW signal is received in SatNOGS Network - Observation 10736922 around 300s and 400s.
yo4dft
December 9, 2024, 2:44pm
6
It wasnt the proper pass for the direction of my antenna, but it seems I received the signal.
https://network.satnogs.org/observations/10738781/
YO4DFT -Cristian
N6RFM
December 9, 2024, 5:56pm
7
YOMOGI CW N6RFM/5 EM12 2024-12-09T15:40:41Z
yomogi js1ymx si7f7b 9df7e0025D
I was QRV for a low ISS pass. The interval between TX was ~ 1 min. Mostly something like - yomogi js1ymx si7f7b. However it appeared that the telemetry info at the end was not sent every time. yomogi js1ymx si7f7b 9df7e0025D. The “D” may be incorrect. Need better passes to verify.
Good hunting all.
Bob
N6RFM
HS318
December 9, 2024, 6:29pm
8
fredy
December 10, 2024, 10:19am
9
TLE update for YOMOGI and LignoSat(based on YOMOGI TLE), sets are not fully accurate but better than the initial from ISS:
YOMOGI
1 98736U 24345.40000000 .00000000 00000-0 34741-3 0 00
2 98736 51.6375 162.4936 0008367 294.8288 347.2202 15.51348604 05
LignoSat
1 98738U 24345.40000000 .00000000 00000-0 34741-3 0 02
2 98738 51.6375 162.4936 0008367 294.8288 347.2202 15.51348604 07
yomogi_345_v1.dat (1.8 KB)
sites.txt (9.8 KB)
deckbsd
December 10, 2024, 12:15pm
10
Nice TLE update
Good YOMOGI observation over Belgium :
2024-12-10 11:51:16 UTC
yomogi js1ymx si7bbe 10F7E0885C
fredy
December 13, 2024, 7:51am
11
We have TLE sets from space-track.org , still in TBA (To Be Assigned) status:
0 TBA - TO BE ASSIGNED
1 62295U 98067XB 24347.66850216 .00099641 00000-0 16295-2 0 9992
2 62295 51.6360 151.0994 0010083 328.5836 31.4551 15.51664672 533
1 62296U 98067XC 24347.66830773 .00071724 00000-0 11781-2 0 9996
2 62296 51.6361 151.0985 0010634 322.1103 37.9137 15.51684922 513
1 62297U 98067XD 24347.66833339 .00084920 00000-0 13907-2 0 9992
2 62297 51.6363 151.0986 0010681 322.0879 37.9358 15.51693335 511
1 62298U 98067XE 24347.66836448 .00072976 00000-0 11994-2 0 9999
2 62298 51.6362 151.0990 0010547 322.5881 37.4374 15.51661144 511
1 62299U 98067XF 24347.66889013 .00084617 00000-0 13985-2 0 9993
2 62299 51.6366 151.1023 0009152 321.6204 38.4133 15.51454837 493
deckbsd
December 13, 2024, 11:58am
13
For YOMOGI based on my observation here
62298 (followed one) better alignment :
62297 off :
62296 off :
62295 completely off :
62299 out of the scope, no way to align it.
deckbsd
December 15, 2024, 4:37pm
14
New TLEs from Space-track :
1 62295U 98067XB 24350.11544937 .00132324 00000-0 21106-2 0 9999
2 62295 51.6359 138.9411 0010588 339.0703 20.9852 15.52209185 913
1 62296U 98067XC 24350.43727482 .00093526 00000-0 15049-2 0 9992
2 62296 51.6361 137.3406 0011123 333.6792 26.3632 15.52134871 946
1 62297U 98067XD 24350.43717079 .00121322 00000-0 19332-2 0 9999
2 62297 51.6362 137.3401 0011306 333.9418 26.1002 15.52275496 942
1 62298U 98067XE 24350.43737039 .00093542 00000-0 15063-2 0 9997
2 62298 51.6359 137.3413 0011022 334.1863 25.8575 15.52114962 945
1 62299U 98067XF 24350.11622597 .00126589 00000-0 20411-2 0 9996
2 62299 51.6366 138.9465 0009531 332.4811 27.5673 15.51943607 879
deckbsd
December 15, 2024, 5:06pm
15
YOMOGI using the new TLE and this observation from today :
**62298 ** still a good candidate:
62295 Still a good candidate:
62296 off :
62297 off :
62299 off :
deckbsd
December 18, 2024, 12:39pm
16
1 62295U 98067XB 24353.07619197 .00141499 00000-0 21860-2 0 9998
2 62295 51.6367 124.2141 0011446 351.2870 8.7920 15.53046891 1370
1 62296U 98067XC 24352.88355667 .00093202 00000-0 14757-2 0 9991
2 62296 51.6369 125.1778 0011499 343.7978 16.2643 15.52580139 1320
1 62297U 98067XD 24353.07620560 .00124803 00000-0 19435-2 0 9991
2 62297 51.6369 124.2148 0011858 345.0122 15.0515 15.52890852 1351
1 62298U 98067XE 24352.81931341 .00092564 00000-0 14674-2 0 9993
2 62298 51.6369 125.4985 0011399 344.0910 15.9721 15.52550563 1314
1 62299U 98067XF 24352.94890036 .00124304 00000-0 19558-2 0 9997
2 62299 51.6375 124.8645 0010123 344.9612 15.1075 15.52628115 1313
deckbsd
December 18, 2024, 1:07pm
17
62298 the only good one left :
62295 off :
62296 off :
62297 off :
62299 off :
Since TLE for 62298 is the only good one left @fredy can we make the assumption that 62298 is YOMOGI ?
fredy
December 18, 2024, 1:21pm
18
Yes, you have identified it! I’ll perform the change in DB and Network in the next hour.
EDIT: Identification done in Network and DB
