I have loaded everything i could when done i ran journalctl -u satnogs-client.service and the results is below. I also got in using the 192.168.1.105:500000 and the results are below. I also added the config info on the from the client device. It will not run and i cant see myself in testing. Please some one help me in getting my software to work. I am still working on my rotor hardware. My other problem is how to connect the Pi3 to my board using the UART pins on the pi pin 8 and 10.
Apr 07 22:15:50 KA5TTZ systemd[1]: Started SatNOGS client.
Apr 07 22:15:52 KA5TTZ systemd[1]: Stopping SatNOGS client…
Apr 07 22:15:52 KA5TTZ systemd[1]: Stopped SatNOGS client.
Apr 07 22:15:52 KA5TTZ systemd[1]: Started SatNOGS client.
Apr 07 22:16:11 KA5TTZ satnogs-client[18005]: linux; GNU C++ version 6.2.0 20161
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: 2018-04-07 22:16:17,844 - satnogsc
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: 2018-04-07 22:16:17,846 - satnogsc
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: 2018-04-07 22:16:17,848 - satnogsc
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: 2018-04-07 22:16:17,849 - satnogsc
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: 2018-04-07 22:16:17,850 - satnogsc
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: 2018-04-07 22:16:17,851 - satnogsc
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: 2018-04-07 22:16:17,852 - satnogsc
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: 2018-04-07 22:16:17,853 - satnogsc
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: 2018-04-07 22:16:17,854 - satnogsc
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: 2018-04-07 22:16:17,861 - satnogsc
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: WebSocket transport not available.
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: * Running on http://0.0.0.0:5000/
Apr 07 22:16:17 KA5TTZ satnogs-client[18005]: linux; GNU C++ version 6.2.0 20161
Apr 07 22:16:18 KA5TTZ satnogs-client[18005]: 2018-04-07 22:16:18,035 - satnogsults
192.168.1.104:5000
18:27:07[INFO]: Status view initiated
18:27:07[INFO]: Received mode change: {“custom_cmd”:{“mode”:“network”}}
18:27:47[INFO]: Get jobs started
18:27:47[DEBUG]: URL: https://network.satnogs.org/api/jobs/
18:27:47[DEBUG]: Params: {‘ground_station’: 249}
18:27:47[DEBUG]: Headers: {‘Authorization’: ‘Token fe14a7b00d911d6a95fdc7e97a0ae513c876f1b1’}
18:27:47[INFO]: Trying to GET observation jobs from the network
18:28:47[INFO]: Get jobs started
18:28:47[DEBUG]: URL: https://network.satnogs.org/api/jobs/
18:28:47[DEBUG]: Params: {‘ground_station’: 249}
18:28:47[DEBUG]: Headers: {‘Authorization’: ‘Token fe14a7b00d911d6a95fdc7e97a0ae513c876f1b1’}
18:28:47[INFO]: Post data started
18:28:47[INFO]: Trying to GET observation jobs from the network
Configuration
Key
Value
BACKEND_FEEDER_PORT
5023
BACKEND_LISTENER_PORT
5022
CLIENT_LISTENER_UDP_PORT
5015
CURRENT_PASS_TCP_PORT
5005
DEFAULT_LOGGING
{‘loggers’: {‘apscheduler.executors.default’: {‘level’: ‘INFO’, ‘handlers’: [‘console’]}, ‘satnogsclient’: {‘level’: ‘INFO’, ‘handlers’: [‘console’]}}, ‘version’: 1, ‘formatters’: {‘clientFormatter’: {‘format’: ‘%(asctime)s - %(name)s - %(levelname)s - %(message)s’}}, ‘handlers’: {‘console’: {‘formatter’: ‘clientFormatter’, ‘class’: ‘logging.StreamHandler’}}}
DEFAULT_SQLITE_PATH
/tmp/.satnogs/jobs.sqlite
DISABLE_DECODED_DATA
False
ECSS_FEEDER_UDP_PORT
5031
ENABLE_IQ_DUMP
False
GNURADIO_AMSAT_DUV_SCRIPT_FILENAME
satnogs_amsat_fox_duv_decoder.py
GNURADIO_APT_SCRIPT_FILENAME
satnogs_noaa_apt_decoder.py
GNURADIO_BPSK_SCRIPT_FILENAME
satnogs_bpsk_demod.py
GNURADIO_CW_SCRIPT_FILENAME
satnogs_cw_decoder.py
GNURADIO_FM_SCRIPT_FILENAME
satnogs_fm_demod.py
GNURADIO_FSK1K2_SCRIPT_FILENAME
satnogs_afsk1200_ax25.py
GNURADIO_FSK9K6_SCRIPT_FILENAME
satnogs_fsk9600_g3ruh_ax25.py
GNURADIO_IP
127.0.0.1
GNURADIO_SCRIPT_FILENAME
satnogs_fm_demod.py
GNURADIO_SCRIPT_PATH
[’/usr/bin’, ‘/usr/local/bin’]
GNURADIO_UDP_PORT
16886
IQ_DUMP_FILENAME
None
LD_DOWNLINK_LISTEN_PORT
5033
LD_DOWNLINK_RETRIES_LIM
5
LD_DOWNLINK_SMALL_TIMEOUT
2
LD_DOWNLINK_TIMEOUT
5
LD_UPLINK_LISTEN_PORT
5021
LD_UPLINK_TIMEOUT
2.5
RF_SW_CMD_OFF_CHAR_SEQ
None
RF_SW_CMD_OFF_INT
None
RF_SW_CMD_ON_CHAR_SEQ
None
RF_SW_CMD_ON_INT
None
RIG_FILE
RIG_MODEL
RIG_PTT_FILE
RIG_PTT_TYPE
RIG_SERIAL_SPEED
SATNOGS_ANTENNA
None
SATNOGS_API_TOKEN
SATNOGS_APP_PATH
/tmp/.satnogs
SATNOGS_BB_GAIN
None
SATNOGS_COMPLETE_OUTPUT_PATH
SATNOGS_DEV_ARGS
None
SATNOGS_DOPPLER_CORR_PER_SEC
None
SATNOGS_IF_GAIN
None
SATNOGS_INCOMPLETE_OUTPUT_PATH
/tmp/.satnogs/data/incomplete
SATNOGS_LO_OFFSET
None
SATNOGS_NETWORK_API_POST_INTERVAL
2
SATNOGS_NETWORK_API_QUERY_INTERVAL
1
SATNOGS_NETWORK_API_URL
SATNOGS_OUTPUT_PATH
/tmp/.satnogs/data
SATNOGS_POST_OBSERVATION_SCRIPT
None
SATNOGS_PPM_ERROR
None
SATNOGS_PRE_OBSERVATION_SCRIPT
None
SATNOGS_REMOVE_RAW_FILES
True
SATNOGS_RF_GAIN
0.0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6
SATNOGS_RIG_IP
127.0.0.1
SATNOGS_RIG_PORT
4532
SATNOGS_ROT_IP
127.0.0.1
SATNOGS_ROT_PORT
4533
SATNOGS_ROT_THRESHOLD
4
SATNOGS_RX_DEVICE
rtlsdr
SATNOGS_SERIAL_PORT
None
SATNOGS_SQLITE_URL
sqlite:////tmp/.satnogs/jobs.sqlite
SATNOGS_STATION_ELEV
64.0
SATNOGS_STATION_ID
249
SATNOGS_STATION_LAT
30.585
SATNOGS_STATION_LON
-90.498
SATNOGS_VERIFY_SSL
True
STATUS_LISTENER_PORT
5032
TASK_FEEDER_TCP_PORT
5011
WOD_UDP_PORT
5023
