Looking at the terretrial/spurs on the lower one, they’re also modulated in the same way. So I’m guessing somehow a low frequency (few kHz) squarewave is finding it’s way into the rx path.
It will be useful to take in account the gain of two devices, RTL and HackRF. I am looking for something similar in UHF and lowering the gain solve sometimes some spurs, keeping the same SN ratio or obtaining a better one. This form of signal I have also in UHF, in both configuration. You can see some examples in attachement.
Cristian - YO4DFT HackRF vs RTL V4.pdf (688.3 KB)
Hi, thanks, I noticed that info and this reminds me I did not reply about my thoughts for the top 4 images I think I clearly notice an FM modulated signal, being corrected through your waterfall by doppler correction. Might there be a (mirrorred ?) FM modulated signal being around, narrow band, like a local repeater or something ?
For me, my observations are Pluto vs HackRF so not easy to compare, I might check my strf observations if I get a similar output if I am accidently scanning the same band part.
In this momment I am using RTL V4; I reduced the gain from 19.7 to 12.5, and the perturbation at 436.750 almost disapeard, but the perturbation from 437.505 is still there, same level…
You give me a good ideea, I shall try to listen the audio at 436.750 to see if is related of a broadcast emission.
