We changed the sample rate to 2.048e6 and tried again today, but encountered these:
May 16 20:49:39 raspberrypi satnogs-client[433]: return session.request(method=method, url=url, **kwargs)
May 16 20:49:39 raspberrypi satnogs-client[433]: File “/var/lib/satnogs/lib/python3.9/site-packages/requests/sessions.py”, line 587, in request
May 16 20:49:39 raspberrypi satnogs-client[433]: resp = self.send(prep, **send_kwargs)
May 16 20:49:39 raspberrypi satnogs-client[433]: File “/var/lib/satnogs/lib/python3.9/site-packages/requests/sessions.py”, line 701, in send
May 16 20:49:39 raspberrypi satnogs-client[433]: r = adapter.send(request, **kwargs)
May 16 20:49:39 raspberrypi satnogs-client[433]: File “/var/lib/satnogs/lib/python3.9/site-packages/requests/adapters.py”, line 565, in send
May 16 20:49:39 raspberrypi satnogs-client[433]: raise ConnectionError(e, request=request)
May 16 20:49:39 raspberrypi satnogs-client[433]: requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘network.satnogs.org’, port=443): Max retries exceeded with url: /api/jobs/?ground_station=3575&lat=19.131&lon=72.918&alt=66 (Caused by NewConnectionError(‘<urllib3.connection.HTTPSConnection object at 0xf2c208b0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’))
May 16 21:02:23 raspberrypi satnogs-client[433]: apscheduler.executors.default - WARNING - Run time of job “get_jobs (trigger: interval[0:01:00], next run at: 2024-05-16 15:32:38 UTC)” was missed by 0:00:44.342848
May 16 21:02:23 raspberrypi satnogs-client[433]: apscheduler.executors.default - WARNING - Run time of job “post_data (trigger: interval[0:03:00], next run at: 2024-05-16 15:22:39 UTC)” was missed by 0:00:44.203261
May 16 21:05:32 raspberrypi satnogs-client[433]: rot_init called
May 16 21:05:32 raspberrypi satnogs-client[433]: initrots4_dummy: _init called
May 16 21:05:32 raspberrypi satnogs-client[433]: rot_register (1)
May 16 21:05:32 raspberrypi satnogs-client[433]: rot_register (2)
May 16 21:05:32 raspberrypi satnogs-client[433]: dummy_rot_init called
May 16 21:05:32 raspberrypi satnogs-client[433]: rot_open called
May 16 21:05:32 raspberrypi satnogs-client[433]: dummy_rot_open called
May 16 21:05:32 raspberrypi satnogs-client[433]: rot_get_position called
May 16 21:05:32 raspberrypi satnogs-client[433]: dummy_rot_get_position called
May 16 21:05:32 raspberrypi satnogs-client[433]: rot_get_position: got az=0.00, el=0.00
May 16 21:05:32 raspberrypi satnogs-client[433]: rot_set_position called az=145.15 el=10.05
May 16 21:05:32 raspberrypi satnogs-client[433]: rot_set_position: south_zero=0
May 16 21:05:32 raspberrypi satnogs-client[433]: dummy_rot_set_position called: 145.15 10.05
May 16 21:05:32 raspberrypi satnogs-client[433]: rig_init: rig does not have rx_range!!
May 16 21:05:32 raspberrypi satnogs-client[433]: network_open: hoststr=127.0.0.1, portstr=4532
May 16 21:05:32 raspberrypi satnogs-client[433]: connect to 127.0.0.1:4532 failed, (trying next interface): Network error 111: Connection refused
May 16 21:05:32 raspberrypi satnogs-client[433]: network_open: failed to connect to 127.0.0.1:4532
May 16 21:05:32 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:33 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:34 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:35 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:36 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:36 raspberrypi satnogs-client[759]: Found Rafael Micro R820T tuner
May 16 21:05:36 raspberrypi satnogs-client[759]: [INFO] Opening Generic RTL2832U OEM :: 00000001…
May 16 21:05:36 raspberrypi satnogs-client[759]: [R82XX] PLL not locked!
May 16 21:05:36 raspberrypi satnogs-client[759]: [INFO] Using format CF32.
May 16 21:05:37 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:38 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:39 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:40 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:41 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:42 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:43 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:44 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:45 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:46 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:47 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:48 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:48 raspberrypi satnogs-client[759]: [ERROR] ./lib/tcp_rigctl_msg_source_impl.cc:147: Could not connect at rigctl server 127.0.0.1
May 16 21:05:48 raspberrypi satnogs-client[759]: Traceback (most recent call last):
May 16 21:05:48 raspberrypi satnogs-client[759]: File “/usr/bin/satnogs_noaa_apt_decoder.py”, line 484, in
May 16 21:05:48 raspberrypi satnogs-client[759]: main()
May 16 21:05:48 raspberrypi satnogs-client[759]: File “/usr/bin/satnogs_noaa_apt_decoder.py”, line 467, in main
May 16 21:05:48 raspberrypi satnogs-client[759]: tb = top_block_cls(antenna=options.antenna, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, flip_images=options.flip_images, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, sync=options.sync, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_dump_host=options.udp_dump_host, udp_dump_port=options.udp_dump_port, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path)
May 16 21:05:48 raspberrypi satnogs-client[759]: File “/usr/bin/satnogs_noaa_apt_decoder.py”, line 129, in init
May 16 21:05:48 raspberrypi satnogs-client[759]: self.satnogs_doppler_compensation_0 = satnogs.doppler_compensation(samp_rate_rx, rx_freq, lo_offset, 441604, 1, 0)
May 16 21:05:48 raspberrypi satnogs-client[759]: File “/usr/lib/python3/dist-packages/satnogs/doppler_compensation.py”, line 112, in init
May 16 21:05:48 raspberrypi satnogs-client[759]: self.dec = filter.freq_xlating_fft_filter_ccc(decimation,
May 16 21:05:48 raspberrypi satnogs-client[759]: File “/usr/lib/python3/dist-packages/gnuradio/filter/freq_xlating_fft_filter.py”, line 53, in init
May 16 21:05:48 raspberrypi satnogs-client[759]: self._filter = fft_filter_ccc(decim, taps)
May 16 21:05:48 raspberrypi satnogs-client[759]: File “/usr/lib/python3/dist-packages/gnuradio/filter/filter_swig.py”, line 744, in make
May 16 21:05:48 raspberrypi satnogs-client[759]: return _filter_swig.fft_filter_ccc_make(decimation, taps, nthreads)
May 16 21:05:48 raspberrypi satnogs-client[759]: RuntimeError: boost: mutex lock failed in pthread_mutex_lock: Invalid argument
May 16 21:05:49 raspberrypi satnogs-client[433]: rig_get_vfo: no rig and/or vfo? rig=0xefa00668, vfo=0xf03fe310
May 16 21:05:50 raspberrypi satnogs-client[433]: apscheduler.executors.default - ERROR - Job “spawn_observer (trigger: date[2024-05-16 15:35:32 UTC], next run at: 2024-05-16 15:35:32 UTC)” raised an exception
May 16 21:05:50 raspberrypi satnogs-client[433]: Traceback (most recent call last):
May 16 21:05:50 raspberrypi satnogs-client[433]: File “/var/lib/satnogs/lib/python3.9/site-packages/apscheduler/executors/base.py”, line 125, in run_job
May 16 21:05:50 raspberrypi satnogs-client[433]: retval = job.func(*job.args, **job.kwargs)
May 16 21:05:50 raspberrypi satnogs-client[433]: File “/var/lib/satnogs/lib/python3.9/site-packages/satnogsclient/scheduler/tasks.py”, line 64, in spawn_observer
May 16 21:05:50 raspberrypi satnogs-client[433]: observer.observe()
May 16 21:05:50 raspberrypi satnogs-client[433]: File “/var/lib/satnogs/lib/python3.9/site-packages/satnogsclient/observer/observer.py”, line 266, in observe
May 16 21:05:50 raspberrypi satnogs-client[433]: waterfall = Waterfall(self.observation_waterfall_file)
May 16 21:05:50 raspberrypi satnogs-client[433]: File “/var/lib/satnogs/lib/python3.9/site-packages/satnogsclient/waterfall.py”, line 99, in init
May 16 21:05:50 raspberrypi satnogs-client[433]: self.data = _get_waterfall(datafile_path)
May 16 21:05:50 raspberrypi satnogs-client[433]: File “/var/lib/satnogs/lib/python3.9/site-packages/satnogsclient/waterfall.py”, line 76, in _get_waterfall
May 16 21:05:50 raspberrypi satnogs-client[433]: waterfall = _read_waterfall(datafile_path)
May 16 21:05:50 raspberrypi satnogs-client[433]: File “/var/lib/satnogs/lib/python3.9/site-packages/satnogsclient/waterfall.py”, line 34, in _read_waterfall
May 16 21:05:50 raspberrypi satnogs-client[433]: ‘timestamp’: np.fromfile(datafile, dtype=‘|S32’, count=1)[0],
May 16 21:05:50 raspberrypi satnogs-client[433]: IndexError: index 0 is out of bounds for axis 0 with size 0
