Hello all,
I’ve just finally got my first ground station up and configured, but unfortunately it seems the Waterfalls are not uploading to SatNogs. Everything seems to be in order. The client wakes up every minute before an observation, and during the observation you see it scrolling through info of what it is doing. I did notice a repeating pattern of the same frequencies showing up that never seemed to clear.
I have tried doing a second “update” to the client and it comes back with a already updated prompt.
I have also verified a correct install.
This is a section of the text showing during an observation. It will continually show names of satellites that have already finished their pass 15 minutes before.
Aug 19 07:39:14 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Satellite data: {‘tle0’: ‘UNISAT-6’, ‘tle1’: ‘1 40012U 14033C 20231.85248342 .00000133 00000-0 26988-4 0 9996’, ‘tle2’: ‘2 40012 97.7050 83.7069 0058709 157.2757 203.1071 14.74142007331611’}
Aug 19 07:39:14 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -1.3654447793960571, ‘az’: 5.684629440307617, ‘rng’: 13124758.0, ‘rng_vlct’: 1379.7890625, ‘ok’: True}
Aug 19 07:39:14 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Initial frequency: 437421500
Aug 19 07:39:14 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437419486
Aug 19 07:39:14 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Observer data: {‘lon’: -104.997, ‘lat’: 39.748, ‘elev’: 1700}
Aug 19 07:39:14 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Satellite data: {‘tle0’: ‘Aeneas’, ‘tle1’: ‘1 38760U 12048C 20231.38943303 +.00000690 +00000+0 +53485-4 0 758’, ‘tle2’: ‘2 38760 64.6589 271.9136 0098396 104.8021 256.4024 15.07031727174103’}
Aug 19 07:39:14 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -1.239332914352417, ‘az’: 2.5339629650115967, ‘rng’: 12696915.0, ‘rng_vlct’: 2175.164794921875, ‘ok’: True}
Aug 19 07:39:14 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Initial frequency: 437600000
Aug 19 07:39:14 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437596824
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Observer data: {‘lon’: -104.997, ‘lat’: 39.748, ‘elev’: 1700}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Satellite data: {‘tle0’: ‘0 SARAL’, ‘tle1’: ‘1 39086U 13009A 20231.85155594 -.00000015 00000-0 10780-4 0 9996’, ‘tle2’: ‘2 39086 98.5446 56.4618 0002093 81.1687 278.9734 14.32031225390936’}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -0.40516769886016846, ‘az’: 6.1374735832214355, ‘rng’: 6652991.0, ‘rng_vlct’: 5901.3486328125, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Initial frequency: 465988000
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 465978827
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Satellite data: {‘tle0’: ‘CUTE17AOD2’, ‘tle1’: ‘1 32785U 08021C 20231.84989433 +.00000147 +00000-0 +21430-4 0 9998’, ‘tle2’: ‘2 32785 097.5768 217.1350 0011531 289.2012 070.7957 14.88501286667156’}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -0.9775978922843933, ‘az’: 3.4518964290618896, ‘rng’: 11266400.0, ‘rng_vlct’: 3705.156005859375, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Initial frequency: 437274600
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437269195
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Satellite data: {‘tle0’: ‘0 XW-2C’, ‘tle1’: ‘1 40906U 15049H 20232.20592916 .00000398 00000-0 24052-4 0 9998’, ‘tle2’: ‘2 40906 97.4781 232.6355 0015278 150.4290 272.8140 15.16137914271762’}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -0.8873805403709412, ‘az’: 3.3822197914123535, ‘rng’: 10526366.0, ‘rng_vlct’: 4471.1328125, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Initial frequency: 145790315
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 145788140
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Satellite data: {‘tle0’: ‘UNISAT-6’, ‘tle1’: ‘1 40012U 14033C 20231.85248342 .00000133 00000-0 26988-4 0 9996’, ‘tle2’: ‘2 40012 97.7050 83.7069 0058709 157.2757 203.1071 14.74142007331611’}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -1.3655019998550415, ‘az’: 5.684548854827881, ‘rng’: 13124902.0, ‘rng_vlct’: 1379.384521484375, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Initial frequency: 437421500
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437419487
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Satellite data: {‘tle0’: ‘Aeneas’, ‘tle1’: ‘1 38760U 12048C 20231.38943303 +.00000690 +00000+0 +53485-4 0 758’, ‘tle2’: ‘2 38760 64.6589 271.9136 0098396 104.8021 256.4024 15.07031727174103’}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -1.2393895387649536, ‘az’: 2.533949136734009, ‘rng’: 12697140.0, ‘rng_vlct’: 2174.798583984375, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Initial frequency: 437600000
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437596825
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -0.40523383021354675, ‘az’: 6.137511253356934, ‘rng’: 6653615.5, ‘rng_vlct’: 5901.189453125, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -0.9776560068130493, ‘az’: 3.451856851577759, ‘rng’: 11266790.0, ‘rng_vlct’: 3704.800537109375, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437269196
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -0.8874420523643494, ‘az’: 3.3822085857391357, ‘rng’: 10526835.0, ‘rng_vlct’: 4470.78857421875, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -1.3655591011047363, ‘az’: 5.6844682693481445, ‘rng’: 13125045.0, ‘rng_vlct’: 1378.9803466796875, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -1.2394462823867798, ‘az’: 2.533935308456421, ‘rng’: 12697366.0, ‘rng_vlct’: 2174.432373046875, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437596826
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -0.40530019998550415, ‘az’: 6.13754940032959, ‘rng’: 6654242.0, ‘rng_vlct’: 5901.029296875, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -0.9777138233184814, ‘az’: 3.451817512512207, ‘rng’: 11267178.0, ‘rng_vlct’: 3704.447021484375, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -0.8875036239624023, ‘az’: 3.382197618484497, ‘rng’: 10527304.0, ‘rng_vlct’: 4470.443359375, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 145788141
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -1.3656163215637207, ‘az’: 5.684387683868408, ‘rng’: 13125188.0, ‘rng_vlct’: 1378.5758056640625, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437419488
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -1.2395029067993164, ‘az’: 2.533921480178833, ‘rng’: 12697592.0, ‘rng_vlct’: 2174.066162109375, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -0.4053652286529541, ‘az’: 6.1375861167907715, ‘rng’: 6654856.5, ‘rng_vlct’: 5900.87255859375, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -0.977770984172821, ‘az’: 3.4517784118652344, ‘rng’: 11267561.0, ‘rng_vlct’: 3704.097412109375, ‘ok’: True}
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437269197
Aug 19 07:39:15 raspberrypi satnogs-client[848]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: -0.8875647783279419, ‘az’: 3.3821866512298584, ‘rng’: 10527770.0, ‘rng_vlct’: 4470.10107421875, ‘ok’: True}
