Hey @fredy, thanks for the TLEs! We calculated our own TLE which is only around 3.5 minutes off from the one you posted. Also, very exciting to see all of the observations scheduled! Thank you for putting those into the system.
Watching the observations roll in – looks like we caught CSIM (who is still beaconing at our same frequency) on SatNOGS Network - Observation 6161893 since there was a moment when they overlapped in the sky:
Updated to the new TLE set and re-scheduled some of the observations. The new TLE set fit the signals on several observations at the bottom left corner. In other observations that there is signal at center or the top right is another satellite, usually CSIM.
To be fair you are beaconing at CSIM’s frequency. You don’t follow your IARU coordinated frequency which is 437.325MHz but you transmit at 437.250MHz. Is there a reason behind that? Is IARU informed about this change on the coordinated frequency?
Fair correction! I talk about our frequency on this other thread – Unfortunately the radio we intended to use (transmission at 437.325 MHz) does not function with the power system of our cubesat – we ended up having to use a flight spare that transmits at 437.25 MHz. the radio that we have (Spacequest TRX-U) is delivered with a frequency set. There is a command available enabling a force-feed of the transceiver registers (enabling a frequency change), but there are a few issues with changing our frequency now:
the command is not persistent through a radio power cycle, and we have observed many spacecraft resets on orbit for our other cubesats on orbit. To have this command issued automatically on a spacecraft reboot would require a flight software change (program management is opposed to this)
the command is not recommended for anything but diagnostics or experiments, which I would argue being on-orbit doesn’t qualify as one of those two use cases
the issue with the power board and intended flight radio was discovered somewhat late in the game. At this point the spacecraft is being delivered to the launch provider on Friday and no further testing is possible.
This gives me no joy, especially when we are already out of alignment with the amateur community with our AX.25 header issues. We have someone working on contacting the IARU to have a discussion with them, but that aspect of the mission is out of my hands, personally.
I have mesured the top row of the signal, and therefore there is a 5kHz offset shown. If I identify the first observation only, I get 52945 as best fit. For the second and third only I get 52944 as best fit. And when I identify them all 3 at once, I get:
There are only 3 TLEs released at this moment, and there are 7 satellites deployed. It can of course be that the CTIM TLE is not yet published. For now I think we are good with the current TLE (99402) and when it starts to deviate, we can try 52944, or just look again
Hey folks! Thanks for the TLE updates and all of the awesome data going into the dashboard (side note – if there’s other data you’re interested in seeing on the dashboard let me know and I’ll get it on there!).
We successfully made contact with CTIM last night from our ground station and got our first sets of commands up! The spacecraft looks to be behaving nominally, which is very exciting.
Thank you @fredy and @satcolintel5 for that TLE information and calculation!
We have been using 52950 for our ground station operations and have been having good success so far. On the dashboard you can see the temperatures increase when we turned the payload and payload heaters on:
