ZL4VBJ
June 3, 2018, 10:39am
#1
Hi
I’ve built a complete V1.2 controller and powering with a V1 power supply, and a good 12v supply for steppers.
when i power up…motors do not move, although when i touch the step pin on the stepper driver or the arduino step pin the motor rotates? i’m a bit confused … board is complete. what am i missing?
thanks i advance.
Brennan
ka4jwb
June 5, 2018, 2:13pm
#2
Are you talking about the v2 board that has the arduino pro mini?
Https://wiki.satnogs.org/SatNOGS_Rotator_Controller
If so according to wiki, requires 19v-60v
akef
June 6, 2018, 6:28pm
#4
Have you connected the photo interrupters ?
ZL4VBJ
June 6, 2018, 10:40pm
#5
hi
yes and the led turns on and off when triggered, i connected them to +5v , gnd and sw_el | sw_az
thanks
akef
June 7, 2018, 7:31am
#6
Verify that you have loaded the correct sketch on arduino and that the :
#define DEFAULT_HOME_STATE HIGH /*Change to LOW according to Home sensor*/
is set correct for your interrupter
ZL4VBJ
June 8, 2018, 11:03am
#7
Hi akef
I checked this and its fine, i did disconnect the LED from the photointerupters because i was only getting 3v on high, now good 5v then triggered.
Still seem to have the same issue, not really sure why?
Thanks for your help
akef
June 8, 2018, 8:08pm
#8
What do you mean with:
ZL4VBJ:
when i touch
How do you power up the arduino?
ZL4VBJ
June 11, 2018, 1:47am
#9
The arduino is powered via the v1 power supply board output 5v to the Vcc an GND pins, stepper power is 12v via separate power supply connected to GND and VMOT
ZL4VBJ
June 12, 2018, 1:00am
#10
what i mean by “when i touch” i mean with my finger, only starts steping when touched
ka4jwb
June 12, 2018, 9:04pm
#11
That kind of sounds like a grounding issue to me?
ZL4VBJ
June 12, 2018, 9:31pm
#12
i have checked all my grounds, and the two supply’s are connected at the board.
i will have another look later to make sure all connected
