PVCC appears to be Object K, giving me by far the best results.
Which pipeline in SatDump gives you that âBPSK Demodulatorâ? I donât see that listed.
And is this signal the S-Band or X-Band downlink?
The pipeline for PVCC was added yesterday, so you need to download the latest version to get it. Itâs in proba.json, called âpvcc_s_dumpâ. Thatâs the S-Band signal.
@crosswalkersam1 was that at 2221.000 MHz?
There are several changes and identifications since the last status update. For PVCC and N3SS we have some identifications but no clear evidence, if someone has any please provide them to fully identify them.
Status update:
| Temporary NORAD ID | Satellite | NORAD ID to follow | Other NORAD IDs | Identified | Deployed | Last Update |
| RECEIVED AND DEMODULATED | ||||||
| CSC-1 | 58022 | - | YES | YES | Identified, here are the ikhnos results | |
| CSC-2 | 58021 | - | YES | YES | Identified, here are the ikhnos results | |
| RECEIVED | ||||||
| 99042 | ANSER FOLLOWER 2 | 58018 | 58019 | NO | YES | Changed to follow 58018 but without demodulation/decoding maybe it is 58019 |
| 99043 | ANSER FOLLOWER 1 | 58019 | 58018 | NO | YES | Changed to follow 58019 but without demodulation/decoding maybe it is 58018 |
| THEOS-2 | 58016 | - | YES | YES | Identified, evidence by @K4KDR here and by @pe2bz here | |
| 99038 | PVCC | 58025 | - | NO | YES | Changed to 58025, based on @crosswalkersam1 here and space-track.org |
| 99033 | Unknown Satellite from VV23 | 58024 | - | NO | YES | Last Reception at 2023-10-14 19:32 UTC |
| NOT RECEIVED WITH FREQUENCY | ||||||
| TRITON | 58017 | - | YES | YES | Identified, Remaining from the two possible (58016 and 58017) as 58016 is identified | |
| 99041 | PRETTY | 58023 | all except the identified ones | NO | YES | Changed to 58023 based on satellite team suggestion |
| NOT RECEIVED WITHOUT FREQUENCY | ||||||
| 99036 | N3SS | 58020 | all except the identified ones | NO | YES | Changed to follow 58020 based on space-track.org |
| 99037 | MACSAT | 58024 | all except the identified ones | NO | YES | Changed to 58024 as it may be the one that is received but unknown |
| LAUNCHED BUT NOT DEPLOYED | ||||||
| 99044 | ANSER LEADER | - | - | NO | NO | Launched but not deployed |
| 99045 | ESTCube-2 | - | - | NO | NO | Launched but not deployed |
Yes, 2221Mhz. Usually PROBA satellites are on 2235MHz, but PVCC seems to be different for whatever reason.
PVCC was received and demodulated aswell, S-Band and X-Band are both active now.
We still missing:
- Evidence for N3SS(NESS) being object 58020
- Evidence that MACSAT is the unknown satellite that transmits at 401.050 MHz
- Demodulated/Decoded data from ANSER FOLLOWERs that shows which one is 58018 and which 58019.
If anyone has contact with these teams or any evidence, please help to complete identifications of this launch.
Status update:
| PVCC | 58025 | - | YES | YES | Identified, evidence by @crosswalkersam1 here and here, by @pe2bz here and by space-track.org | |
| RECEIVED | ||||||
| PRETTY | 58023 | YES | YES | Identified, here are the ikhnos results | ||
