I included the CW transmitter suggestion for TTU100.
Could it be that the TLE was calculated with one point (from the pre-launch vector)? As much as I have seen with my limited experience then one point SGP4 calculations can get inaccurate relatively quickly.
But in any case, to put it all into perspective, it seems that the satellites are slowly drifting apart. Even two-body analyses with post-launch vectors give some perspective in this regard. The distance between the red and the blue is ~1000 km on ground track (might be ~20° pointing difference on ground) and ~1800 km between the greens:
For AmicalSat there are new TLE from R4UAB that fit pretty well the received signals as shown in the next images (Observation 2791859 and Observation 2791861):
Unfortunately I don’t know that, maybe someone else.
That’s true, but usually this means couple of days for the altitude of these satellites, if the TLE are accurate. As we have preliminary TLEs I can not guarantee how fast they will get inaccurate.
Just to mention here that some individuals running another kind of observation with a tool named strf (GitHub - cbassa/strf: Radio Frequency Satellite Tracking). With this tools they scan (create a kind of waterfall) for a wide frequency range and for a long period (that covers before and after the expected pass) that would be enough to locate satellites that have transmitted even if the TLE are not so accurate. Here is an example of such observation.
PS we are very active in our matrix/irc channel about this deployment, feel free to join us.
This TLE is determined by propagating the pre-launch 74002 TLE to today, and then using Doppler measurements to fit the mean anomaly, RA of the ascending node and the mean motion.
TLE seems correct from SatNOGS observations with object 2020-061E. AMSAT says 061F, which I think it is wrong from our own obervations. The dopler changes at high attitudes passes shows better close control with object 061E
Also an update for TLM decoding software:
V1.3 Date 07-09-2020
Fixed analog data table thanks to M.Rupprecht DK3WN and D. Estevez EA4GPZ
Thanks for sharing those @ea4bpn ! If your team is interested you can create a custom dashboard in dashboard.satnogs.org that will be automatically updated with SatNOGS demodulated and decoded telemetry. Let us know or drop by #satnogs to help you with the process.
I’m sure they are aware of what they are doing and I’m afraid I’m not the right person to talk to them about violating radio spectrum use. I’ve contacted them already as a ham just to ask them for a decoding schema.
The only thing I can do (and I’m willing to do), is helping to prepare a custom dashboard in dashboard.satnogs.org as a SatNOGS volunteer, when/if I get their decoding schema.
I’m interested in TRISAT because I’m from the same country as satellite is, and I’m not from their university team.
