Transporter-16 Rideshare: VSFB SLC-4E : 2026-03-29 xx:xx:xx UTC
As satellite teams have started add information about their satellites for this launch, I’m creating this thread to track the launch and start gathering information.
Sources:
nasaspaceflight related thread
LILIUM-4 acts as a spaceborne relay for the Amateur Radio Automatic Packet Reporting System (APRS). It is designed to be interoperable with existing ARISS (International Space Station) standards.
  • Downlink Frequency: 145.825 MHz
  • Protocol: AX.25
  • Data Rate: 1200 bps AFSK
  • Satellite Call Sign: BN0YCA
  • Supported Paths: ARISS, WIDE2-1
  • Digipeater Logic: * Responsive to both its unique call sign (BN0YCA) and the generic ARISS alias.
    • Config: PATH1=ARISS,1; PATH2=WIDE2,1.
2. UHF Telemetry & Secondary Digipeater
The UHF subsystem serves as the primary health-monitoring link and provides a backup digipeater capability during periods of low telemetry activity.
  • Center Frequency: 437.850 MHz
  • Protocol: AX.25
  • Modulation: 1k2 AFSK
  • Operational Note: When telemetry is not being actively transmitted, the UHF digipeater remains enabled for amateur use.
3. High-Speed S-Band Downlink
This link is used for high-bandwidth data transfer and as a high-speed telemetry backup.
  • Center Frequency: 2405 MHz (2.4 GHz ISM Band)
  • Modulation: GFSK
  • Initial Data Rate: 100 kbps
  • Variable Rates: Ground-commandable up to 1 Mbps or 2 Mbps depending on link margin and mission requirements.
SpaceX Transporter-16 Rideshare launch.
This topic will share information on the coming launch.
If you have information regarding this launch, please share it so we can have a complete list.
last update: 2026-03-07 22:18 UTC
AMATEUR UHF
98864 AEPEX 437.325 MHz IARU Coordinated SpaceVan
xxxxx DISCO-2 437.075 MHz IARU Coordinated Directly
xxxxx HADES-SA 436.875 MHz IARU Coordinated Directly
98391 LILIUM-4 437.850 MHz IARU Coordinated Directly
xxxxx SAL-E 436.965 MHz IARU Coordinated Directly
AMATEUR VHF
98391 LILIUM-4 145.825 MHz IARU Coordinated Directly
COMMERCIAL UHF
xxxxx COSMO 401.200 - Directly
xxxxx - - - Directly
Nasa Spaceflight forum topic.
SpaceX rideshare mission information.
@PE0SAT I’ve merged your new thread with the existing one, thanks for the additional info!
looks like the HADES-SA also will lunch by this mission
In a tweet from Exolaunch, they just announced that DISCO-2 would be on Transporter-16. The ITU freqs listed are somewhat generic, so I have to doubt that they represent exact downlinks to expect:
435 to 438
2400 to 2450
Perhaps we can narrow that down to exact freqs from other sources.
Ok, there is IARU coordination at IARU Sat Coordinator
Coordination has been provided for downlinks on 437.075 MHz and 2432.500 MHz
Two of ours / CU Boulder/ LASP , AEPEX will be a delayed deployment via SpaceVan (~ 2 weeks)
AMATEUR UHF
98864 AEPEX 437.325 MHz IARU coordinated Delayed
COMMERCIAL UHF
xxxxx COSMO 401.200 Mhz GFSK9k6 Directly
