Beacons are 15seconds apart. This observation looks like the right signals:
I’ve scheduled observations for the next 24h and not for 48h as it is expected to update some TLE sets later today.
A kind reminder to station owners that schedule observations, when you scheduling for a satellite in other stations make sure you leave enough free spots for the other satellites transmitting in the same frequency range. You can check the frequencies of the other satellites in the first post table which is ordered by frequency.
3UCubed-A transmits beacons every 60 seconds with housekeeping data in ~6 packets of 137 bytes and an interpacket gap of 500 ms at a frequency of 437.01 MHz. Of the 137 bytes, the first 15 bytes are preamble data that can be ignored; starting at the 16th byte is the start of an AX.25 frame ending at the 97th byte.
A couple of observations– Observation 12830962, Observation 12830945, and Observation 12830955, show the general ~60 seconds apart beacon structure; however, the signal seems to be too weak to be demodulated.
Any assistance searching for beacons and demodulation is highly appreciated.
I am looking at some SatNOGS observations of 3UCubed-A that have valid decodes. For instance SatNOGS Network - Observation 12831077. The decoded frames contain the AX.25 addresses MBSRC and PHI1, suggesting that these transmissions are from PHI-1 instead of 3UCubed-A. Indeed a comparison with PHI-1 observations (for instance SatNOGS Network - Observation 12830654) shows similar waterfall and frame contents.
Since PHI-1 is observed at 436.850 MHz and 3UCubed-A is observed at 437.010 MHz, which are far enough apart in frequency, the most likely conclusion is that PHI-1 is also transmitting close to 437.010 MHz and showing up in 3UCubed-A observations.
Good day Daniel,
I have been looking at my STRF runs and there I don’t see any signals on 437.010 MHz only 436.850 MHz. It is possible other frequency is used over other parts of the globe.
Here it would be great if we had some confirmation of a team member.
Hi, Is it possible to update SPiN-2 to the latest post launch TLE from celestrak?
1 71994C 25276V 25332.82003007 -.00016250 00000+0 -83956-3 0 09
2 71994 97.4429 44.8323 0006176 356.8754 351.0665 15.16360449 15
Source is here https://celestrak.org/NORAD/elements/supplemental/sup-gp.php?FILE=transporter-15&FORMAT=tle
On it, until then I’m adding here the whole list of the post launch celestrak TLE:
TORO2
1 71996C 25276A 25332.81865276 -.00018935 00000+0 -92912-3 0 08
2 71996 97.4471 44.8297 0002027 150.6290 189.7844 15.18183059 17
BRO-17
1 72008C 25276B 25332.81869789 -.00012350 00000+0 -63947-3 0 07
2 72008 97.4432 44.8311 0006464 350.6111 350.0578 15.16279094 19
IHI-SAT 2
1 71993C 25276C 25332.81877891 -.00009593 00000+0 -47116-3 0 07
2 71993 97.4471 44.8298 0001858 150.1005 191.0020 15.18146392 16
BRO-20
1 72009C 25276D 25332.81881479 -.00012206 00000+0 -63023-3 0 03
2 72009 97.4408 44.8320 0006123 355.8494 345.4627 15.16381467 17
PHI-1
1 71984C 25276E 25332.81888076 -.00015888 00000+0 -77895-3 0 05
2 71984 97.4379 44.8331 0002948 117.1032 224.5755 15.18210592 16
BLACK KITE-1
1 71981C 25276F 25332.81889581 -.00020335 00000+0 -10471-2 0 03
2 71981 97.4496 44.8291 0005481 340.0709 1.6638 15.16484256 13
TRYAD-2
1 71927C 25276G 25332.81894905 -.00015115 00000+0 -77900-3 0 00
2 71927 97.4427 44.8315 0005749 353.2232 348.8171 15.16448967 15
LEMUR-2-LAILA
1 71986C 25276H 25332.81903238 -.00011039 00000+0 -54043-3 0 09
2 71986 97.4415 44.8319 0002655 132.8392 209.6587 15.18260953 16
HUNITY (NMHH-1) SARI 1*)
1 71930C 25276J 25332.81911340 -.00015028 00000+0 -78160-3 0 09
2 71930 97.4349 44.8341 0007530 2.3039 340.6501 15.16118343 17
LEMUR-2-DEANANDMAEVE
1 71980C 25276K 25332.81913771 -.00010154 00000+0 -52340-3 0 01
2 71980 97.4450 44.8309 0005731 349.7173 353.3481 15.16440746 10
ORORATECH GENA-OT-1
1 71983C 25276L 25332.81921294 -.00005748 00000+0 -28165-3 0 04
2 71983 97.4453 44.8309 0002231 148.6394 194.8358 15.18230234 11
LEMUR-2-TEODOR
1 71954C 25276M 25332.81932868 -.00011375 00000+0 -55915-3 0 07
2 71954 97.4391 44.8328 0002322 119.6976 224.4219 15.18118367 14
LILIUM-2
1 71978C 25276N 25332.81938771 -.00019527 00000+0 -10050-2 0 09
2 71978 97.4409 44.8324 0005650 359.6083 344.8318 15.16498935 15
LUNA-1
1 72005C 25276P 25332.81954512 -.00020420 00000+0 -99940-3 0 02
2 72005 97.4509 44.8298 0002389 178.3550 166.9212 15.18273260 19
6GSTARLAB
1 71997C 25276Q 25332.81957058 -.00020149 00000+0 -10356-2 0 00
2 71997 97.4493 44.8302 0005240 344.1804 1.2397 15.16550460 13
ACCENTURE-1
1 72010C 25276R 25332.81958563 -.00019545 00000+0 -96373-3 0 01
2 72010 97.4409 44.8325 0001744 118.4135 227.1051 15.18014082 19
SPEQTRE
1 71948C 25276S 25332.81966086 -.00018488 00000+0 -91056-3 0 07
2 71948 97.4458 44.8313 0001413 150.6367 195.2822 15.18055214 10
OBSERVER-1B
1 71955C 25276T 25332.81978123 -.00007185 00000+0 -35311-3 0 04
2 71955 97.4483 44.8308 0001666 167.4583 179.1133 15.18126892 13
OTTER HCT-SAT2
1 71995C 25276U 25332.81984141 -.00016095 00000+0 -83108-3 0 02
2 71995 97.4467 44.8312 0006000 349.6404 357.2633 15.16382589 16
VEERY-0G SPIN-2
TRYAD-1
1 71928C 25276W 25332.82006016 -.00014061 00000+0 -69126-3 0 00
2 71928 97.4427 44.8324 0001837 139.3929 208.7124 15.18117529 17
PW-6U
1 71932C 25276X 25332.82018632 -.00000922 00000+0 -45419-4 0 03
2 71932 97.4459 44.8318 0001293 154.2539 194.5339 15.18038025 12
TMICROSAT-1
1 71982C 25276Y 25332.82020252 -.00017395 00000+0 -85874-3 0 09
2 71982 97.4396 44.8331 0001770 111.8688 237.0209 15.17971486 11
MICE-1
1 72002C 25276Z 25332.82022451 -.00006635 00000+0 -34088-3 0 02
2 72002 97.4521 44.8306 0005282 340.9975 7.9865 15.16561278 18
FLOCK 4H-10
1 71946C 25276AA 25332.82023840 -.00016235 00000+0 -83089-3 0 03
2 71946 97.4435 44.8324 0004686 358.8337 350.2440 15.16700593 13
CTC-1A
1 71935C 25276AB 25332.82035646 -.00022061 00000+0 -11295-2 0 01
2 71935 97.4461 44.8320 0004679 353.2251 356.4913 15.16690275 10
FLOCK 4H-25
1 71921C 25276AC 25332.82037035 -.00015084 00000+0 -74643-3 0 04
2 71921 97.4435 44.8325 0000995 116.4756 233.3227 15.17890018 16
LILIUM-3
1 71977C 25276AD 25332.82069789 -.00018848 00000+0 -92543-3 0 06
2 71977 97.4494 44.8319 0001814 183.3387 168.2348 15.18162024 19
PHASMA-LAMARR
1 72003C 25276AE 25332.82079396 -.00022853 00000+0 -11820-2 0 01
2 72003 97.4402 44.8333 0006419 2.8970 349.2191 15.16322100 12
PHASMA-DIRAC
1 72004C 25276AF 25332.82092127 -.00022928 00000+0 -11800-2 0 00
2 72004 97.4380 44.8337 0005751 8.8191 343.9968 15.16500202 15
FLOCK 4H-14
1 71908C 25276AG 25332.82095947 -.00015372 00000+0 -76074-3 0 05
2 71908 97.4454 44.8327 0000628 145.6814 207.3281 15.17887193 17
FLOCK 4H-13
1 71909C 25276AH 25332.82107984 -.00015426 00000+0 -76494-3 0 07
2 71909 97.4470 44.8327 0000255 174.9186 178.7448 15.17818537 11
AE5RC
1 71951C 25276AJ 25332.82116664 -.00009532 00000+0 -48850-3 0 05
2 71951 97.4416 44.8333 0004966 4.2336 349.9139 15.16648281 15
FLOCK 4H-5
1 71943C 25276AK 25332.82117822 -.00015788 00000+0 -78326-3 0 04
2 71943 97.4422 44.8333 0000819 96.5357 257.6743 15.17801585 18
WISDOM A-B
1 71926C 25276AL 25332.82126850 -.00015093 00000+0 -77194-3 0 07
2 71926 97.4468 44.8329 0004555 354.4443 0.2492 15.16724874 14
LEMUR-2-STAS-GORBUK
1 71979C 25276AM 25332.82148725 -.00011578 00000+0 -59359-3 0 07
2 71979 97.4496 44.8330 0004966 350.9194 4.9639 15.16637362 14
CTC-1B
1 71934C 25276AN 25332.82173840 -.00022041 00000+0 -10893-2 0 00
2 71934 97.4437 44.8337 0000920 142.7476 214.5183 15.17938223 17
FLOCK 4H-26
1 71920C 25276AP 25332.82186803 -.00017374 00000+0 -88848-3 0 07
2 71920 97.4436 44.8338 0004557 1.3539 356.6170 15.16730573 13
FLOCK 4H-28
1 71918C 25276AQ 25332.82200229 -.00017466 00000+0 -89152-3 0 04
2 71918 97.4425 44.8339 0004321 7.5737 351.1349 15.16795055 10
FLOCK 4H-23
1 71911C 25276AR 25332.82202660 -.00017405 00000+0 -88724-3 0 05
2 71911 97.4483 44.8338 0004080 352.4393 6.3891 15.16843846 11
CTC-1C
1 71933C 25276AS 25332.82216433 -.00022598 00000+0 -11210-2 0 06
2 71933 97.4485 44.8340 0000580 252.9749 106.6046 15.17805408 19
PIAST-M
1 71953C 25276AT 25332.82220368 -.00012090 00000+0 -60113-3 0 03
2 71953 97.4432 44.8341 0000402 59.5603 300.2445 15.17722730 18
FLOCK 4H-4
1 71936C 25276AU 25332.82245947 -.00017831 00000+0 -91260-3 0 09
2 71936 97.4472 44.8344 0004704 358.0355 3.1591 15.16699630 18
IRIDE PFM1
1 71972C 25276AV 25332.82251618 -.00011627 00000+0 -57809-3 0 09
2 71972 97.4441 44.8344 0000288 45.8341 315.6755 15.17722491 19
PIAST-S2
1 71952C 25276AW 25332.82253817 -.00011055 00000+0 -55091-3 0 06
2 71952 97.4464 44.8344 0000587 344.8783 16.7471 15.17641958 18
IRIDE FM5
1 71968C 25276AX 25332.82262729 -.00012662 00000+0 -64567-3 0 08
2 71968 97.4443 44.8345 0004135 5.1538 356.9627 15.16829168 13
MAUVE
1 71929C 25276AY 25332.82269095 -.00000085 00000+0 -42371-5 0 05
2 71929 97.4455 44.8346 0000213 353.2452 9.2162 15.17722715 12
FLOCK 4H-27
1 71919C 25276AZ 25332.82278586 -.00017230 00000+0 -85713-3 0 04
2 71919 97.4417 44.8345 0000649 67.3196 295.6672 15.17705167 18
IRIDE FM4
1 71969C 25276BA 25332.82297336 -.00012898 00000+0 -65661-3 0 08
2 71969 97.4430 44.8347 0003873 8.8305 355.1771 15.16890630 15
IRIDE FM3
1 71963C 25276BB 25332.82302891 -.00011926 00000+0 -59304-3 0 03
2 71963 97.4431 44.8348 0000450 64.5395 299.7723 15.17718796 10
IRIDE FM6
1 71966C 25276BC 25332.82315391 -.00012180 00000+0 -60532-3 0 03
2 71966 97.4462 44.8351 0000341 300.0411 64.9453 15.17737222 14
AE5RA
1 71950C 25276BD 25332.82355438 -.00011394 00000+0 -58430-3 0 02
2 71950 97.4456 44.8355 0005020 4.0627 3.1110 15.16627076 12
AE5RB
1 71949C 25276BE 25332.82390970 -.00011626 00000+0 -59440-3 0 00
2 71949 97.4404 44.8350 0004578 16.7449 352.3792 15.16734889 13
IRIDE FM8
1 71973C 25276BF 25332.82400461 -.00013815 00000+0 -70454-3 0 04
2 71973 97.4427 44.8355 0004146 13.7889 355.8501 15.16825962 15
FLOCK 4H-32
1 71914C 25276BG 25332.82426965 -.00019323 00000+0 -98801-3 0 02
2 71914 97.4470 44.8365 0004558 4.4425 6.6344 15.16735221 13
IRIDE FM7
1 71965C 25276BH 25332.82438771 -.00014083 00000+0 -71707-3 0 00
2 71965 97.4465 44.8366 0003893 6.3241 5.3994 15.16883295 14
FLOCK 4H-16
1 71906C 25276BJ 25332.82453470 -.00019478 00000+0 -99280-3 0 07
2 71906 97.4480 44.8371 0004125 359.9507 12.5695 15.16848108 15
IRIDE FM2
1 71964C 25276BK 25332.82455669 -.00014210 00000+0 -72253-3 0 03
2 71964 97.4428 44.8360 0003652 13.1421 359.5087 15.16933477 10
FLOCK 4H-31
1 71915C 25276BL 25332.82478354 -.00019734 00000+0 -10044-2 0 00
2 71915 97.4410 44.8357 0003805 18.0673 355.8250 15.16899716 14
FLOCK 4H-3
1 71937C 25276BM 25332.82485299 -.00019700 00000+0 -10018-2 0 04
2 71937 97.4491 44.8378 0003861 356.0436 18.2113 15.16928499 13
3UCUBED-A
1 71931C 25276BN 25332.82504975 .00001682 00000+0 83855-4 0 00
2 71931 97.4423 44.8362 0000660 28.9081 346.4366 15.17617264 12
FLOCK 4H-35
1 71923C 25276BP 25332.82575229 -.00019272 00000+0 -95330-3 0 07
2 71923 97.4442 44.8374 0000701 219.9017 159.2750 15.17904719 15
FLOCK 4H-33
1 71925C 25276BQ 25332.82593863 -.00019660 00000+0 -97358-3 0 06
2 71925 97.4465 44.8384 0000854 255.0326 125.1567 15.17866084 16
FLOCK 4H-34
1 71924C 25276BR 25332.82606016 -.00020060 00000+0 -99577-3 0 01
2 71924 97.4478 44.8391 0000971 283.3730 97.4769 15.17782053 18
FLOCK 4H-2
1 71938C 25276BS 25332.82617822 -.00020321 00000+0 -10117-2 0 05
2 71938 97.4409 44.8365 0000429 61.3110 320.1974 15.17677230 16
FLOCK 4H-36
1 71922C 25276BT 25332.82619674 -.00020322 00000+0 -10129-2 0 09
2 71922 97.4490 44.8397 0001304 314.2521 67.3409 15.17637715 10
FLOCK 4H-30
1 71916C 25276BU 25332.82677660 -.00021629 00000+0 -11037-2 0 01
2 71916 97.4476 44.8399 0004253 10.2592 14.5018 15.16808453 14
FLOCK 4H-15
1 71907C 25276BV 25332.82727891 -.00022190 00000+0 -11349-2 0 03
2 71907 97.4462 44.8399 0004547 16.0147 11.4911 15.16724901 18
FLOCK 4H-29
1 71917C 25276BW 25332.82739697 -.00022244 00000+0 -11316-2 0 05
2 71917 97.4411 44.8373 0003606 29.3551 358.8063 15.16917194 10
FLOCK 4H-18
1 71904C 25276BX 25332.82771988 -.00022625 00000+0 -11545-2 0 07
2 71904 97.4420 44.8380 0004066 27.5491 2.3729 15.16808173 14
FLOCK 4H-19
1 71903C 25276BY 25332.82857174 -.00022311 00000+0 -11059-2 0 00
2 71903 97.4425 44.8389 0000677 256.7300 137.8406 15.17832842 13
FLOCK 4H-20
1 71902C 25276BZ 25332.82893632 -.00022865 00000+0 -11327-2 0 00
2 71902 97.4463 44.8419 0001464 281.5308 115.0209 15.17852938 14
FLOCK 4H-17
1 71905C 25276CA 25332.82915623 -.00023314 00000+0 -11615-2 0 08
2 71905 97.4480 44.8436 0001766 315.3531 82.3948 15.17654287 17
FLOCK 4H-24
1 71910C 25276CB 25332.82975113 -.00024675 00000+0 -12547-2 0 00
2 71910 97.4479 44.8444 0003813 12.2036 28.7918 15.16933117 10
FLOCK 4H-22
1 71912C 25276CC 25332.83053586 -.00025614 00000+0 -13016-2 0 00
2 71912 97.4414 44.8391 0003174 37.1707 8.1248 15.16959165 12
FLOCK 4H-21
1 71913C 25276CD 25332.83118401 -.00025390 00000+0 -12598-2 0 04
2 71913 97.4425 44.8405 0001026 281.4116 127.4191 15.17798821 16
FLOCK 4H-1
1 71939C 25276CE 25332.83136572 -.00025993 00000+0 -12949-2 0 00
2 71939 97.4417 44.8397 0000649 316.9376 92.8870 15.17659225 10
FLOCK 4H-6
1 71942C 25276CF 25332.83222451 -.00026833 00000+0 -13381-2 0 01
2 71942 97.4470 44.8474 0002299 324.9588 89.5371 15.17621126 14
FLOCK 4H-8
1 71940C 25276CG 25332.83270252 -.00028068 00000+0 -14264-2 0 04
2 71940 97.4468 44.8480 0003709 17.9019 39.2035 15.16955224 18
FLOCK 4H-7
1 71941C 25276CH 25332.83353701 -.00029140 00000+0 -14800-2 0 04
2 71941 97.4422 44.8409 0002784 43.4554 18.2222 15.16978740 13
FLOCK 4H-12
1 71944C 25276CJ 25332.83405090 -.00029183 00000+0 -14556-2 0 01
2 71944 97.4423 44.8412 0000983 319.9166 104.5659 15.17618346 17
FLOCK 4H-9
1 71947C 25276CK 25332.83490623 -.00030110 00000+0 -15027-2 0 06
2 71947 97.4459 44.8506 0002681 332.9206 96.2132 15.17595469 13
FLOCK 4H-11
1 71945C 25276CL 25332.83534257 -.00031264 00000+0 -15875-2 0 08
2 71945 97.4457 44.8511 0003545 22.0598 49.4560 15.16987560 17
ICEYE-X61
1 72006C 25276CM 25332.83537382 -.00008866 00000+0 -44283-3 0 07
2 72006 97.4438 44.8453 0001664 333.9982 97.6995 15.17562166 10
ICEYE-X60
1 71991C 25276CN 25332.83551502 -.00010184 00000+0 -51666-3 0 08
2 71991 97.4440 44.8460 0002785 33.6422 38.8254 15.17011535 15
NEWSAT-52
1 71959C 25276CP 25332.83562498 -.00033502 00000+0 -16989-2 0 05
2 71959 97.4453 44.8502 0003248 22.0123 51.0472 15.17035862 13
IMPULSE-3 MIRA
1 71989C 25276CQ 25332.83573840 -.00020012 00000+0 -99904-3 0 02
2 71989 97.4431 44.8431 0001277 326.1551 107.5377 15.17583777 10
AC1-003
1 72000C 25276CR 25332.83576965 -.00036690 00000+0 -18600-2 0 00
2 72000 97.4447 44.8487 0002976 25.2861 48.5664 15.17046294 12
ICEYE-X58
1 71956C 25276CS 25332.83591086 -.00031955 00000+0 -15977-2 0 03
2 71956 97.4446 44.8484 0002168 339.5556 95.0686 15.17532405 17
HYDROGNSS-1
1 71970C 25276CT 25332.83594095 -.00034278 00000+0 -17362-2 0 03
2 71970 97.4441 44.8465 0002564 29.3038 45.4876 15.17078327 14
PIAST-S1
1 71961C 25276CU 25332.83603354 -.00024797 00000+0 -12401-2 0 06
2 71961 97.4434 44.8438 0001379 337.8199 97.4819 15.17524552 14
NAHLA
1 71974C 25276CV 25332.83634488 -.00037114 00000+0 -18579-2 0 01
2 71974 97.4439 44.8458 0001705 343.8633 93.1347 15.17491267 13
YAM-9
1 71971C 25276CW 25332.83643053 -.00033020 00000+0 -16717-2 0 00
2 71971 97.4445 44.8488 0002742 24.0769 53.3833 15.17094355 15
UMBRA-11
1 71975C 25276CX 25332.83653238 -.00033053 00000+0 -16556-2 0 07
2 71975 97.4439 44.8460 0001711 346.7538 91.2678 15.17470774 16
PELICAN-6
1 71985C 25276CY 25332.83655901 -.00037699 00000+0 -19070-2 0 01
2 71985 97.4440 44.8464 0002293 28.2477 49.9187 15.17125056 18
PELICAN-5
1 71976C 25276CZ 25332.83661225 -.00037421 00000+0 -18762-2 0 07
2 71976 97.4446 44.8495 0002334 350.7411 87.7097 15.17437498 11
NEWSAT-47
1 71957C 25276DA 25332.83676965 -.00034975 00000+0 -17684-2 0 06
2 71957 97.4435 44.8440 0001912 35.1294 44.1915 15.17140025 15
AC1-001
1 71999C 25276DB 25332.83686572 -.00037976 00000+0 -19187-2 0 01
2 71999 97.4447 44.8504 0002753 16.4894 63.3438 15.17166546 16
MERCURY ONE (M1)
1 72001C 25276DC 25332.83702660 -.00030109 00000+0 -15101-2 0 06
2 72001 97.4436 44.8443 0001393 353.7651 86.9579 15.17423804 18
FGN TUG S01
1 71962C 25276DD 25332.83711109 -.00038048 00000+0 -19098-2 0 08
2 71962 97.4445 44.8501 0002384 355.4751 85.6986 15.17396129 16
ICEYE-X62
1 72007C 25276DE 25332.83718863 -.00011938 00000+0 -60264-3 0 04
2 72007 97.4439 44.8458 0001960 24.6550 56.9499 15.17190253 12
ION SCV-022
1 71987C 25276DF 25332.83757289 -.00034667 00000+0 -17413-2 0 06
2 71987 97.4440 44.8467 0001762 0.0645 83.6370 15.17371690 14
HYDROGNSS-2
1 71967C 25276DG 25332.83767706 -.00036314 00000+0 -18328-2 0 06
2 71967 97.4445 44.8508 0002628 14.6413 69.6212 15.17203231 13
AC1-002
1 71998C 25276DH 25332.83812498 -.00039587 00000+0 -19966-2 0 03
2 71998 97.4441 44.8466 0001831 19.3111 67.4049 15.17230783 14
NEWSAT-51
1 71958C 25276DJ 25332.83815507 -.00036411 00000+0 -18305-2 0 02
2 71958 97.4445 44.8536 0002912 1.1191 85.7482 15.17340365 12
ION SCV-021
1 71988C 25276DK 25332.83867706 -.00036221 00000+0 -18257-2 0 08
2 71988 97.4442 44.8477 0001886 15.3011 74.4274 15.17249798 15
W-SERIES 5
1 71990C 25276DL 25332.83944674 -.00037840 00000+0 -19039-2 0 08
2 71990 97.4444 44.8487 0001896 5.8692 88.0600 15.17313643 16
ICEYE-X59
1 71992C 25276DM 25332.84014002 -.00015376 00000+0 -77422-3 0 05
2 71992 97.4443 44.8562 0002353 7.0131 90.6957 15.17280554 10
FORMOSAT-8A
1 71901C 25276DN 25332.87727544 -.00078999 00000+0 -63407-2 0 07
2 71901 97.6544 45.0499 0003201 288.2551 11.6208 15.00193341 19
Thank you @fredy !
From https://www.dorbit.space/mission-updates the booklets from the two ION deployers:
- 5 deployable satellites in ION SCV Stellar Stephanus (ION SCV-021)
Ride With Me Mission Bookletpdf.pdf (1.9 MB)- LEMUR-2-STARLIGHT
- LEMUR-2-TARTIFLETTE
- Lacuna-3
- Lacuna-4
- Foresail-1 prime
- 3 deployable satellites in ION SCV Galactic Georgius (ION SCV-022)
We Need More Space Mission Bookletpdf.pdf (3.1 MB)- LEMUR-2-HOTSPUR-TOM
- Lacuna-5
- Lacuna-6
Celestrak post-launch TLE changed to follow temporary NORAD ID in DB:
TORO2
1 98495C 25276A 25332.81865276 -.00018935 00000+0 -92912-3 0 01
2 98495 97.4471 44.8297 0002027 150.6290 189.7844 15.18183059 10
BRO-17
1 98499C 25276B 25332.81869789 -.00012350 00000+0 -63947-3 0 09
2 98499 97.4432 44.8311 0006464 350.6111 350.0578 15.16279094 11
IHI-SAT 2
1 98479C 25276C 25332.81877891 -.00009593 00000+0 -47116-3 0 05
2 98479 97.4471 44.8298 0001858 150.1005 191.0020 15.18146392 14
BRO-20
1 98498C 25276D 25332.81881479 -.00012206 00000+0 -63023-3 0 03
2 98498 97.4408 44.8320 0006123 355.8494 345.4627 15.16381467 17
PHI-1
1 98512C 25276E 25332.81888076 -.00015888 00000+0 -77895-3 0 01
2 98512 97.4379 44.8331 0002948 117.1032 224.5755 15.18210592 12
BLACK KITE-1
1 98527C 25276F 25332.81889581 -.00020335 00000+0 -10471-2 0 08
2 98527 97.4496 44.8291 0005481 340.0709 1.6638 15.16484256 18
TRYAD-2
1 98472C 25276G 25332.81894905 -.00015115 00000+0 -77900-3 0 04
2 98472 97.4427 44.8315 0005749 353.2232 348.8171 15.16448967 19
1 98537C 25276J 25332.81911340 -.00015028 00000+0 -78160-3 0 01
2 98537 97.4349 44.8341 0007530 2.3039 340.6501 15.16118343 19
LILIUM-2
1 98478C 25276N 25332.81938771 -.00019527 00000+0 -10050-2 0 03
2 98478 97.4409 44.8324 0005650 359.6083 344.8318 15.16498935 19
LUNA-1
1 98509C 25276P 25332.81954512 -.00020420 00000+0 -99940-3 0 09
2 98509 97.4509 44.8298 0002389 178.3550 166.9212 15.18273260 16
6GSTARLAB
1 98500C 25276Q 25332.81957058 -.00020149 00000+0 -10356-2 0 09
2 98500 97.4493 44.8302 0005240 344.1804 1.2397 15.16550460 12
OBSERVER-1B
1 98476C 25276T 25332.81978123 -.00007185 00000+0 -35311-3 0 01
2 98476 97.4483 44.8308 0001666 167.4583 179.1133 15.18126892 10
OTTER HCT-SAT2
1 98470C 25276U 25332.81984141 -.00016095 00000+0 -83108-3 0 09
2 98470 97.4467 44.8312 0006000 349.6404 357.2633 15.16382589 13
OTTER HCT-SAT2
1 98466C 25276U 25332.81984141 -.00016095 00000+0 -83108-3 0 04
2 98466 97.4467 44.8312 0006000 349.6404 357.2633 15.16382589 18
VEERY-0G SPIN-2
1 98471C 25276V 25332.82003007 -.00016250 00000+0 -83956-3 0 08
2 98471 97.4429 44.8323 0006176 356.8754 351.0665 15.16360449 14
TRYAD-1
1 98514C 25276W 25332.82006016 -.00014061 00000+0 -69126-3 0 00
2 98514 97.4427 44.8324 0001837 139.3929 208.7124 15.18117529 17
PW-6U
1 98513C 25276X 25332.82018632 -.00000922 00000+0 -45419-4 0 07
2 98513 97.4459 44.8318 0001293 154.2539 194.5339 15.18038025 16
TMICROSAT-1
1 98515C 25276Y 25332.82020252 -.00017395 00000+0 -85874-3 0 00
2 98515 97.4396 44.8331 0001770 111.8688 237.0209 15.17971486 12
MICE-1
1 98518C 25276Z 25332.82022451 -.00006635 00000+0 -34088-3 0 02
2 98518 97.4521 44.8306 0005282 340.9975 7.9865 15.16561278 18
CTC-1A
1 98482C 25276AB 25332.82035646 -.00022061 00000+0 -11295-2 0 07
2 98482 97.4461 44.8320 0004679 353.2251 356.4913 15.16690275 16
LILIUM-3
1 98477C 25276AD 25332.82069789 -.00018848 00000+0 -92543-3 0 00
2 98477 97.4494 44.8319 0001814 183.3387 168.2348 15.18162024 13
PHASMA-LAMARR
1 98530C 25276AE 25332.82079396 -.00022853 00000+0 -11820-2 0 04
2 98530 97.4402 44.8333 0006419 2.8970 349.2191 15.16322100 15
PHASMA-DIRAC
1 98529C 25276AF 25332.82092127 -.00022928 00000+0 -11800-2 0 00
2 98529 97.4380 44.8337 0005751 8.8191 343.9968 15.16500202 15
CTC-1B
1 98481C 25276AN 25332.82173840 -.00022041 00000+0 -10893-2 0 06
2 98481 97.4437 44.8337 0000920 142.7476 214.5183 15.17938223 13
CTC-1C
1 98480C 25276AS 25332.82216433 -.00022598 00000+0 -11210-2 0 02
2 98480 97.4485 44.8340 0000580 252.9749 106.6046 15.17805408 15
PIAST-M
1 98475C 25276AT 25332.82220368 -.00012090 00000+0 -60113-3 0 01
2 98475 97.4432 44.8341 0000402 59.5603 300.2445 15.17722730 16
PIAST-S2
1 98473C 25276AW 25332.82253817 -.00011055 00000+0 -55091-3 0 03
2 98473 97.4464 44.8344 0000587 344.8783 16.7471 15.17641958 15
3UCUBED-A
1 98517C 25276BN 25332.82504975 .00001682 00000+0 83855-4 0 09
2 98517 97.4423 44.8362 0000660 28.9081 346.4366 15.17617264 11
AC1-003
1 98503C 25276CR 25332.83576965 -.00036690 00000+0 -18600-2 0 06
2 98503 97.4447 44.8487 0002976 25.2861 48.5664 15.17046294 18
HYDROGNSS-1
1 98506C 25276CT 25332.83594095 -.00034278 00000+0 -17362-2 0 07
2 98506 97.4441 44.8465 0002564 29.3038 45.4876 15.17078327 18
PIAST-S1
1 98474C 25276CU 25332.83603354 -.00024797 00000+0 -12401-2 0 04
2 98474 97.4434 44.8438 0001379 337.8199 97.4819 15.17524552 12
NAHLA
1 98511C 25276CV 25332.83634488 -.00037114 00000+0 -18579-2 0 07
2 98511 97.4439 44.8458 0001705 343.8633 93.1347 15.17491267 19
AC1-001
1 98501C 25276DB 25332.83686572 -.00037976 00000+0 -19187-2 0 09
2 98501 97.4447 44.8504 0002753 16.4894 63.3438 15.17166546 14
MERCURY ONE (M1)
1 98510C 25276DC 25332.83702660 -.00030109 00000+0 -15101-2 0 09
2 98510 97.4436 44.8443 0001393 353.7651 86.9579 15.17423804 11
ION SCV-022
1 98508C 25276DF 25332.83757289 -.00034667 00000+0 -17413-2 0 04
2 98508 97.4440 44.8467 0001762 0.0645 83.6370 15.17371690 12
HYDROGNSS-2
1 98505C 25276DG 25332.83767706 -.00036314 00000+0 -18328-2 0 03
2 98505 97.4445 44.8508 0002628 14.6413 69.6212 15.17203231 10
AC1-002
1 98502C 25276DH 25332.83812498 -.00039587 00000+0 -19966-2 0 03
2 98502 97.4441 44.8466 0001831 19.3111 67.4049 15.17230783 14
ION SCV-021
1 98507C 25276DK 25332.83867706 -.00036221 00000+0 -18257-2 0 04
2 98507 97.4442 44.8477 0001886 15.3011 74.4274 15.17249798 11
@fredy I can see the update for SPIN-2 with post launch TLEs. Can that be done for OTTER too?
This reminds me of a known issue we had with DhabiSat 49016. It was also seen in observation about 150-186khz higher. You can still see the original transmitters in the Satnogs DB at 436.908Mhz, and the spooky one on 437.094. This frequency difference is about 186 kHz.
We have also see it with AALTO:
And now we see it again. @PE0SAT is confirming that he doesn’t see the signal in strf recordings. I guess the old Satnogs flowgraph is sensitive for frequencies outside the expected window. Because at the same time we see Phi transmitting on the expected frequency:
I guess the problem @EA4GPZ sees is the station, it is running old 1.6 software.
I’ve updated the TLE for all of them we have in DB.
@fredy I see that some satellites like T.microsat have data from the signal without a decoder, what do we need to do for SPiN-2 to get the data also?
From a quick look, I’ll have a better later, it seems that there is a drift on the frequency that SPiN-2 is transmitting, this in combination with the non-accurate TLE and maybe low SNR it can affect if frames will be decoded or not.
Other factors could be the modulation/framing etc that SPiN-2 uses, if it is something custom it will not work.
Anyway I’m going to check later the above and see if we can do something better.
This is complicating receiving data from 3UCubed-A. 3UCubed-A seems to have a weak signal, and the interference from PHI-1 makes it difficult to distinguish the signal.
Given that other observations show signals with a similar frequency error, this problem is most likely an aliasing issue within SatNOGS rather than PHI-1 transmitting at two different frequencies. This aliasing issue sounds similar to Possible aliasing in CW decoder (#239) · Issues · librespacefoundation / SatNOGS / gr-satnogs · GitLab. Probably it is related or even the same problem. In that issue (which is 3 years old by now) I did an in-depth analysis of the code and explained how it should be fixed. My comments were not taken into account. Apparently another fix was merged after two different attempts at a fix which didn’t really solve the problem. Perhaps the final fix that was merged still causes aliasing in some cases. @EelkeVisser are you sure that there is an aliasing bugfix that is not applied to version 1.6? Maybe the latest version has the same problem. The issue I’m referring to was “fixed” in September 2022, but I have no idea of when version 1.6 was released.
Updated TLEs for CTC-1 mission.
CTC-1A
1 98482U 25332.82035646 .00003403 00000-0 17393-3 0 00009
2 98482 097.4475 044.8332 0007770 330.0061 019.7177 15.16670007000013
CTC-1B
1 98481U 25332.82173840 .00003584 00000-0 17687-3 0 00003
2 98481 097.4451 044.8348 0003092 295.9955 061.2772 15.17917918000016
CTC-1C
1 98480U 25332.82216433 .00003573 00000-0 17699-3 0 00009
2 98480 097.4499 044.8351 0004335 296.2569 063.3296 15.17784902000016
No I am not sure. I have been a victim of the bug, so I recognized it. And somehow I haven’t experienced it in the last years. That could be luck, my ignorance or maybe it was fixed! I looked at the 6 observations of 3UCUBED-A with data. They are showing data of PHI-1 and are all on 1.6 software, and even one is 1.1. But I am not sure what/if was fixed in which versions.
Thanks @EA4GPZ for looking into this in such depth, as you described in the issue.
@PE0SAT would you able to look for 3UCubed-A’s data too? From what we know the signal is weaker.
