Low pass over the Eastern U.S. - as others have reported, all -4- of the Connecta-IOT sats active on 401 MHz. Nothing seen on 869.525.
Hello everyone, hello @fredy
New TLE sets for Connecta IoT satellites
CONNECTA IOT-13
1 99913U 26004 26012.15256944 -.00015555 00000-0 -76273-3 0 00004
2 99913 097.4541 013.5234 0009341 158.7971 260.7541 15.18165357000014
CONNECTA IOT-14
1 99914U 26004 26012.15256944 -.00015662 00000-0 -76552-3 0 00004
2 99914 097.4485 013.5233 0010221 153.7023 266.0665 15.18270507000013
CONNECTA IOT-15
1 99915U 26004 26012.15256944 -.00015202 00000-0 -77809-3 0 00001
2 99915 097.4544 013.5228 0004280 121.8992 294.8184 15.16695787000017
CONNECTA IOT-16
1 99916U 26004 26012.15256944 -.00015317 00000-0 -77928-3 0 00001
2 99916 097.4564 013.5234 0004460 134.7018 282.4302 15.16907768000019
The TLE sets above changed to use the temporary NORAD IDs from DB entries:
CONNECTA IOT-13
1 98457U 26012.15256944 -.00015555 00000-0 -76273-3 0 00004
2 98457 097.4541 013.5234 0009341 158.7971 260.7541 15.18165357000016
CONNECTA IOT-14
1 98458U 26012.15256944 -.00015662 00000-0 -76552-3 0 00004
2 98458 097.4485 013.5233 0010221 153.7023 266.0665 15.18270507000015
CONNECTA IOT-15
1 98459U 26012.15256944 -.00015202 00000-0 -77809-3 0 00001
2 98459 097.4544 013.5228 0004280 121.8992 294.8184 15.16695787000019
CONNECTA IOT-16
1 98460U 26012.15256944 -.00015317 00000-0 -77928-3 0 00002
2 98460 097.4564 013.5234 0004460 134.7018 282.4302 15.16907768000012
@ps_observer thanks for the TLE!
Is there any reason for using on them a negative B* drag value? Iâm asking because in the past weâve seen such TLE sets to become quickly inaccurate.
Hi Fredy,
Thank you for your intereset and help. We are generating TLE data using STK engine, this is a new topic for us also, we are still working on it. Therefore TLE is valid for for a few days and we update TLE daily.
Atakan
2026-01-12 03:58 UTC - ConnectaIoT CubeSats - Replay of recorded I/Q.
İstikbal göklerdedir! = The future is in the skies!
2026-01-12 03:59 UTC - Reception of Beethovenâs melody âOde to Joyâ from Flamingo-1. According to Gunterâs Space Page, Endurosat is the contractor. Telemetry signal was too weak with my omni antenna. Replay of the same I/Q recording as above.
Dear @fredy , we would like to share new TLE set for Connecta satellites.
CONNECTA IOT-13
1 99913U 26004 26022.23590278 -.00015197 00000-0 -74319-3 0 00006
2 99913 097.4555 023.4540 0010211 126.8322 287.4925 15.18250333000014
CONNECTA IOT-14
1 99914U 26004 26022.08312500 .00013608 00000-0 66323-3 0 00009
2 99914 097.4464 023.2984 0011280 121.5846 182.1655 15.18352767000019
CONNECTA IOT-15
1 99915U 26004 26022.24979167 -.00016716 00000-0 -85388-3 0 00003
2 99915 097.4562 023.4453 0004806 098.4176 335.5840 15.16764334000011
CONNECTA IOT-16
1 99916U 26004 26022.18034722 -.00016002 00000-0 -81221-3 0 00006
2 99916 097.4568 023.3838 0005160 108.7150 314.5967 15.16987114000015
may i ask question? why b* drag set to negative?
@bali check the answer here SpaceX F9: Twilight Mission - 2026-01-11 13:44:00 UTC - #24 by ps_observer
TLE Update:
67400 2026-004AP 401.510 ConnectaIoT-13
67401 2026-004AQ 401.520 ConnectaIoT-14
67402 2026-004AR 401.530 ConnectaIoT-15
67390 2026-004AD 401.540 ConnectaIoT-16
