Thanks!!
Very difficult to see a lot of difference in our packets either visually in the Audio spectrum (i.e., Audacity), or when both are transmitted for decode by Direwolf.
I transmitted mine over-the-air & actually received it in GQRX as would happen normally. With your packet, I just played it on the local machine into Direwolf.
… I certainly hope it’s not something silly like the ‘-6’ SSID on my source callsign. I’ll change that to a zero just to match one more characteristic of your uplink. Several passes tonight so I’ll keep trying! Thanks again for the recording.
Did you already try GRBBeta (436.785 via HA2GRB) and BDSat-2 (436.025 via OK0BDT) on UHF?
I had excellent results w/ BDSat-2 but was only heard once by GRBBeta despite trying many, many times. Same situation… my uplink packets decoded perfectly over-the-air here, but GRBBeta just refused to hear (or understand) me.
New TLE for LASARSat by @PE0SAT:
LASARSAT
1 98797U 24363.98552436 .00000000 00000-0 10232-2 0 03
2 98797 45.0011 320.2088 0005106 118.2414 0.3494 15.17945816 06
And for CorCube again by @PE0SAT:
CROCUBE
1 98799U 24363.91776751 .00000000 00000-0 41141-2 0 09
2 98799 45.0011 320.9328 0005283 101.7631 3.5630 15.17956166 03
GRBBeta has become very weak recently on UHF. And even before that, I was better copied by BDSat-2. However, LASARsat is even a notch better than BDSat-2.
Yes, we know… we plan to “somehow officially” switch to the MRC-100 based encoding scheme on GRBBeta UHF as well… then we will gain that ~10dB, which will help a lot ![]()
@fredy Can you update the TLE for CTC-0 to:
1 98728U 24365.86355786 +.00027362 +00000+0 +12714-2 0 00146
2 98728 44.9958 310.3137 0004697 25.2188 334.8921 15.19571771001572
This is from the temporary NORAD set, changed the ID to match the SatNogs one.
Thank you ![]()
What is the initial NORAD ID of this set?
DJIBOUTI-1B TLE Update
DJIBOUTI-1B
1 98729U 24364.96052083 .00000000 00000-0 43247-2 0 02
2 98729 45.0018 315.1478 0003705 64.0988 34.0607 15.19711821 00
This is 88266 from the preliminary list - I will try to adjust to some of the other elements as well later. They go from 88242 to 88269.
Thanks for the info!
Is this list public? How you can get access on it?
LASARSAT
1 98797U 25002.13044650 .00000000 00000-0 16703-2 0 04
2 98797 45.0011 318.2197 0005106 118.2414 344.1396 15.18234817 07
Quick fit to one of today’s obs.
Seems okay on team’s operations ground station.
Obs used: SatNOGS Network - Observation 10862599
CROCUBE
1 98799U 25002.74427570 .00000000 00000-0 41141-2 0 03
2 98799 45.0011 293.9618 0005283 101.7631 131.5737 15.17956166 04
Even quicker one for CroCube. Not super confident on this one but recent observations are a bit meh.
Obs used: SatNOGS Network - Observation 10862702
