Posted today (4-July-2023):
Updated TLE for RS52S, RS40S and RS27S
STRATOSAT-TK1 (RS52S)
1 99151U 23185.41627050 .00000000 00000-0 50000-4 0 01
2 99151 97.3673 234.4405 0051828 186.1014 257.1530 15.02921259 08
UMKA-1 (RS40S)
1 99136U 23185.01627050 .00000000 00000-0 50000-4 0 00
2 99136 97.6530 235.6340 0024278 191.4675 252.3243 15.03299120 02
UTMN-2 (RS27S)
1 99133U 23184.98174050 .00000000 00000-0 50000-4 0 09
2 99133 97.6152 235.6117 0013051 195.8751 85.8329 15.04471050 00
Change to 137.1 MHz confirmed. Already happened
Hello Guys, I’m wondering why these satellites that were launched on soyuz-2-1b-fregat-vostochny-launch-2023-06-27, still not appearing in space-track.org or even in celestrak. how can we then get the accurate TLEs ![]()
Updated TLE for CubeBel-2
CUBEBEL-2
1 99163U 23178.60752042 .00009659 00000-0 70046-3 0 07
2 99163 97.6652 228.7709 0010018 222.4731 118.7176 15.02630880 05
With radio reception observations and create them with the help of STRF
MONITOR-4 based on:
MONITOR-4
1 99137U 23187.36021991 .00000000 00000-0 70046-3 0 04
2 99137 97.6652 238.0958 0003718 247.2814 266.5468 15.03160989 07
Corrected TLE for Stratosat TK-1
1 99151U 23187.36021991 .00000000 00000-0 70046-3 0 00
2 99151 98.6652 238.0958 0003718 246.5861 268.5459 15.03919590 00
close enough:)
Thanks for the update! Have not heard anything from the ride-along pico sats on LoRa.
Any word if, or when they’ll be deployed?
They will be deployed probably next week. There will be update here on this before deployment
Great - thanks!
Will watch out for any news about that.
rms limit (kHz): 0.3
57179 0.128 kHz 436.500890 MHz
57180 0.125 kHz 436.500863 MHz
57181 0.203 kHz 436.500707 MHz
57182 0.139 kHz 436.500791 MHz
Identified 4 candidate(s), best fitting satellite is 57180.
Norby-2 has 57180 as best fit. Also when using only the 11 most recent points gives the same result, but with more separation to the second best.
To be assigned TLE’s from Celestrak
OBJECT B
1 57167U 23091B 23187.66384621 .00003359 00000+0 25180-3 0 9996
2 57167 97.6644 238.2888 0017544 213.1126 146.9003 15.03249907 1363
OBJECT C
1 57168U 23091C 23187.66325462 .00003459 00000+0 25843-3 0 9992
2 57168 97.6642 238.2892 0017282 212.4365 147.5799 15.03349852 1362
OBJECT D
1 57169U 23091D 23187.66224127 .00003557 00000+0 26470-3 0 9995
2 57169 97.6656 238.2910 0015154 209.8356 150.2007 15.03517983 1360
OBJECT E
1 57170U 23091E 23187.66212916 .00003554 00000+0 26429-3 0 9991
2 57170 97.6662 238.2917 0015269 209.9389 150.0965 15.03537143 1361
OBJECT F
1 57171U 23091F 23187.66190164 .00003556 00000+0 26424-3 0 9999
2 57171 97.6656 238.2917 0015033 207.6471 152.3956 15.03574785 1369
OBJECT G
1 57172U 23091G 23187.66317405 .00003192 00000+0 23879-3 0 9996
2 57172 97.6644 238.2892 0017169 212.6056 147.4110 15.03361610 1364
OBJECT H
1 57173U 23091H 23187.66614706 .00004076 00000+0 30775-3 0 9996
2 57173 97.6646 238.2851 0015360 221.1062 138.9006 15.02872478 1362
OBJECT J
1 57174U 23091J 23187.66607286 .00002448 00000+0 18676-3 0 9999
2 57174 97.6647 238.2849 0015111 220.6328 139.3771 15.02872333 1368
OBJECT K
1 57175U 23091K 23187.66706262 .00004227 00000+0 32026-3 0 9996
2 57175 97.6644 238.2837 0015515 223.5166 136.4835 15.02721859 1368
OBJECT L
1 57176U 23091L 23187.66543752 .00004232 00000+0 31803-3 0 9998
2 57176 97.6655 238.2885 0018662 212.8145 147.1923 15.02992337 1366
OBJECT M
1 57177U 23091M 23187.66413078 .00003602 00000+0 26985-3 0 9991
2 57177 97.6660 238.2952 0018353 208.2623 151.7608 15.03204809 1367
OBJECT N
1 57178U 23091N 23187.66431838 .00004312 00000+0 32237-3 0 9992
2 57178 97.6679 238.2967 0018530 207.0950 152.9310 15.03179599 1361
OBJECT P
1 57179U 23091P 23187.66455775 .00002716 00000+0 20502-3 0 9997
2 57179 97.6690 238.2977 0018643 206.2511 153.7771 15.03126616 1367
OBJECT Q
1 57180U 23091Q 23187.66455220 .00004061 00000+0 30418-3 0 9996
2 57180 97.6673 238.2961 0018685 207.2600 152.7646 15.03138645 1364
OBJECT R
1 57181U 23091R 23187.66470708 .00002372 00000+0 17985-3 0 9992
2 57181 97.6649 238.2882 0017935 213.5498 146.4593 15.03098443 1364
OBJECT S
1 57182U 23091S 23187.66460411 .00003956 00000+0 29648-3 0 9991
2 57182 97.6668 238.2961 0018698 207.9911 152.0310 15.03129430 1369
OBJECT T
1 57183U 23091T 23187.65836350 .00002778 00000+0 20431-3 0 9992
2 57183 97.6671 238.2970 0014645 200.2230 159.8418 15.04156394 1366
OBJECT U
1 57184U 23091U 23187.65900573 .00002500 00000+0 18480-3 0 9996
2 57184 97.6671 238.2962 0014553 201.6003 158.4610 15.04047871 1367
OBJECT V
1 57185U 23091V 23187.65830788 .00004478 00000+0 32640-3 0 9997
2 57185 97.6664 238.3068 0013499 206.3264 153.7278 15.04178640 1364
OBJECT W
1 57186U 23091W 23187.65744401 .00002813 00000+0 20601-3 0 9999
2 57186 97.6668 238.2972 0014158 199.4420 160.6268 15.04310410 1360
OBJECT X
1 57187U 23091X 23187.65804427 .00003215 00000+0 23536-3 0 9992
2 57187 97.6670 238.2971 0014528 199.9496 160.1163 15.04215721 1360
OBJECT Y
1 57188U 23091Y 23187.65779497 .00003428 00000+0 25034-3 0 9992
2 57188 97.6649 238.3048 0014231 202.3235 157.7373 15.04257333 1364
OBJECT Z
1 57189U 23091Z 23187.65630559 .00003940 00000+0 28520-3 0 9990
2 57189 97.6659 238.2979 0013718 198.2234 161.8502 15.04509939 1361
OBJECT AA
1 57190U 23091AA 23187.65538647 .00005808 00000+0 41654-3 0 9995
2 57190 97.6631 238.2907 0012347 203.8346 156.2310 15.04676943 1363
OBJECT AB
1 57191U 23091AB 23187.66420976 .00002763 00000+0 20823-3 0 9994
2 57191 97.6645 238.2885 0017777 213.0776 146.9339 15.03183965 1369
OBJECT AC
1 57192U 23091AC 23187.66511785 .00003820 00000+0 28713-3 0 9995
2 57192 97.6652 238.2888 0018405 212.8351 147.1732 15.03042323 1368
OBJECT AD
1 57193U 23091AD 23187.66505388 .00004037 00000+0 30312-3 0 9997
2 57193 97.6650 238.2880 0018207 213.8731 146.1333 15.03055523 1364
OBJECT AE
1 57194U 23091AE 23187.66499454 .00004214 00000+0 31607-3 0 9999
2 57194 97.6650 238.2886 0018258 213.1960 146.8121 15.03065616 1360
OBJECT AF
1 57195U 23091AF 23187.65739987 .00002600 00000+0 19071-3 0 9995
2 57195 97.6679 238.3088 0013753 202.9935 157.0677 15.04315537 1361
OBJECT AG
1 57196U 23091AG 23187.65730895 .00003841 00000+0 27936-3 0 9992
2 57196 97.6661 238.3070 0013892 202.0583 158.0047 15.04341992 1364
OBJECT AH
1 57197U 23091AH 23187.65723975 .00004240 00000+0 30785-3 0 9994
2 57197 97.6644 238.2915 0013589 204.4030 155.6554 15.04356326 1362
OBJECT AJ
1 57198U 23091AJ 23187.65703086 .00006966 00000+0 50191-3 0 9996
2 57198 97.6687 238.3108 0013710 203.2035 156.8574 15.04413929 1361
OBJECT AK
1 57199U 23091AK 23187.65702159 .00004195 00000+0 30435-3 0 9998
2 57199 97.6656 238.2925 0013365 203.4768 156.5849 15.04392408 1365
OBJECT AL
1 57200U 23091AL 23187.65689681 .00005077 00000+0 36700-3 0 9996
2 57200 97.6672 238.2985 0014195 197.5726 162.5011 15.04419948 1368
OBJECT AM
1 57201U 23091AM 23187.65686688 .00004408 00000+0 31931-3 0 9999
2 57201 97.6650 238.2925 0013364 203.2658 156.7965 15.04419751 1360
OBJECT AN
1 57202U 23091AN 23187.65678480 .00002708 00000+0 19793-3 0 9994
2 57202 97.6664 238.2978 0013966 198.1291 161.9439 15.04419461 1369
OBJECT AP
1 57203U 23091AP 23187.65668922 .00003955 00000+0 28674-3 0 9998
2 57203 97.6658 238.2978 0013986 198.4975 161.5744 15.04445740 1361
OBJECT AQ
1 57204U 23091AQ 23187.65595399 .00004084 00000+0 29504-3 0 9993
2 57204 97.6658 238.2979 0013509 197.8583 162.2170 15.04569575 1366
OBJECT AR
1 57205U 23091AR 23187.65581676 .00006206 00000+0 44552-3 0 9995
2 57205 97.6615 238.2888 0012669 205.7790 154.2806 15.04608876 1369
OBJECT AS
1 57206U 23091AS 23186.39216651 .00004676 00000+0 33692-3 0 9996
2 57206 97.6631 237.0368 0012400 208.7040 151.3505 15.04598617 1176
OBJECT AT
1 57207U 23091AT 23186.72431101 .01548028 00000+0 45132-1 0 9998
2 57207 97.7038 237.5638 0033324 245.7428 114.0330 15.31555323 1239
OBJECT AU
1 57208U 23091AU 23186.39217640 .00003893 00000+0 28130-3 0 9998
2 57208 97.6660 237.0439 0013142 202.0757 157.9905 15.04591641 1171
OBJECT AV
1 57217U 23091AV 23187.66401975 .00004190 00000+0 31298-3 0 9995
2 57217 97.6654 238.2941 0018335 208.5249 151.4975 15.03227741 1364
43 New TLE sets from space-track.org, still to be assigned:
0 TBA - TO BE ASSIGNED
1 57167U 23091B 23187.66384621 .00003359 00000-0 25180-3 0 9997
1 57168U 23091C 23187.66325462 .00003459 00000-0 25843-3 0 9993
1 57169U 23091D 23187.66224127 .00003557 00000-0 26470-3 0 9996
1 57170U 23091E 23187.66212916 .00003554 00000-0 26429-3 0 9992
1 57171U 23091F 23187.66190164 .00003556 00000-0 26424-3 0 9990
1 57172U 23091G 23187.66317405 .00003192 00000-0 23879-3 0 9997
1 57173U 23091H 23187.66614706 .00004076 00000-0 30775-3 0 9997
1 57174U 23091J 23187.66607286 .00002448 00000-0 18676-3 0 9990
1 57175U 23091K 23187.66706262 .00004227 00000-0 32026-3 0 9997
1 57176U 23091L 23187.66543752 .00004232 00000-0 31803-3 0 9999
1 57177U 23091M 23187.66413078 .00003602 00000-0 26985-3 0 9992
1 57178U 23091N 23187.66431838 .00004312 00000-0 32237-3 0 9993
1 57179U 23091P 23187.66455775 .00002716 00000-0 20502-3 0 9998
1 57180U 23091Q 23187.66455220 .00004061 00000-0 30418-3 0 9997
1 57181U 23091R 23187.66470708 .00002372 00000-0 17985-3 0 9993
1 57182U 23091S 23187.66460411 .00003956 00000-0 29648-3 0 9992
1 57183U 23091T 23187.65836350 .00002778 00000-0 20431-3 0 9993
1 57184U 23091U 23187.65900573 .00002500 00000-0 18480-3 0 9997
1 57185U 23091V 23187.65830788 .00004478 00000-0 32640-3 0 9998
1 57186U 23091W 23187.65744401 .00002813 00000-0 20601-3 0 9990
1 57187U 23091X 23187.65804427 .00003215 00000-0 23536-3 0 9993
1 57188U 23091Y 23187.65779497 .00003428 00000-0 25034-3 0 9993
1 57189U 23091Z 23187.65630559 .00003940 00000-0 28520-3 0 9991
1 57190U 23091AA 23187.65538647 .00005808 00000-0 41654-3 0 9996
1 57191U 23091AB 23187.66420976 .00002763 00000-0 20823-3 0 9995
1 57192U 23091AC 23187.66511785 .00003820 00000-0 28713-3 0 9996
1 57193U 23091AD 23187.66505388 .00004037 00000-0 30312-3 0 9998
1 57194U 23091AE 23187.66499454 .00004214 00000-0 31607-3 0 9990
1 57195U 23091AF 23187.65739987 .00002600 00000-0 19071-3 0 9996
1 57196U 23091AG 23187.65730895 .00003841 00000-0 27936-3 0 9993
1 57197U 23091AH 23187.65723975 .00004240 00000-0 30785-3 0 9995
1 57198U 23091AJ 23187.65703086 .00006966 00000-0 50191-3 0 9997
1 57199U 23091AK 23187.65702159 .00004195 00000-0 30435-3 0 9999
1 57200U 23091AL 23187.65689681 .00005077 00000-0 36700-3 0 9997
1 57201U 23091AM 23187.65686688 .00004408 00000-0 31931-3 0 9990
1 57202U 23091AN 23187.65678480 .00002708 00000-0 19793-3 0 9995
1 57203U 23091AP 23187.65668922 .00003955 00000-0 28674-3 0 9999
1 57204U 23091AQ 23187.65595399 .00004084 00000-0 29504-3 0 9994
1 57205U 23091AR 23187.65581676 .00006206 00000-0 44552-3 0 9996
1 57206U 23091AS 23187.85526161 .00005485 00000-0 39422-3 0 9995
2 57206 97.6626 238.4883 0012601 203.9233 156.1409 15.04614136 1396
1 57207U 23091AT 23187.89725778 .02722648 00000-0 59817-1 0 9992
2 57207 97.7049 238.7890 0036000 251.5606 108.1724 15.39514310 1411
1 57208U 23091AU 23187.85527926 .00004606 00000-0 33181-3 0 9997
2 57208 97.6655 238.4959 0013340 197.4794 162.5975 15.04605123 1399
1 57217U 23091AV 23187.66401975 .00004190 00000-0 31298-3 0 9996
Closest TLE
Stratosat TK-1 (RS52S): 57177. Also possible: 57217. Possible, but unlikely 57178, 57191
OBJECT M
UMKA-1 (RS40S): 57152. Also possible: 57168
OBJECT G
Cubebel-2 (EU11S): 57175
OBJECT K
CubeSX-HSE-3: 57178. Also possibe: 57191, 57217
OBJECT N
Monitor-3: 57180. Also possible: 57179
OBJECT Q
Monitor-4: 57182. Also possible: 57179, 57180, 57181
OBJECT S
KuzGTU-1: 57167
OBJECT B
VIZARD-meteo: 57205. Also possible: 57206
OBJECT AR
I’ve added into NORAD ID to follow field in DB entries the above for each satellite and eventually it will change future observations in Network.
MONITOR-4 57182
OBJECT S
MONITOR-3 57180 other candidate 57179
OBJECT Q
ArcCube-01: 57204. Also possible: 57205, 57206
OBJECT AQ
Nanozond-1: 57190
OBJECT AA
Svyatobor-1: 57187. Also possible: 57186, 57188
OBJECT X
AVION: On frequency 435.615 and 435.715 57195
OBJECT AF
Unknown satellite on 435.790 57174
OBJECT J
