SatNOGS policy: As you can see here we are trying to gather all needed information from the team in order to determine our approach. Indeed the satellite is not IARU coordinated though, but not declined either. In principle we would like to examine how this is a violation or not of the radio amateur service. What is the intended and actual usage? Are all demodulation and decoding information available?
Maybe playing devil’s advocate here, but keep in mind that in some countries IARU coordination isn’t required by their national administration to register and launch a satellite. Voluntarily submitting a coordination request is always desirable, but in some countries people often don’t speak enough English to understand the important role that IARU plays or to submit the required documentation.
So gathering all possible information at this early stage as @pierros said is the wisest choice.
Hi @K4KDR and @R4UAB, thanks for the information about NORBI. For FSK, I guess it’s using the built-in packet mode of the LoRa tranceiver SX1268 or similar, including whitening and CRC. However, I’m missing some information I need to implement a decoder.
What syncword are you using? (I think a syncword is mandatory)
Are you using the fixed-length format or the variable-length format?
Are you using an address byte?
Which one of the supported CRC types are you using?
Any pointers are helpful. For instance, I could use something like “we’re using this chip and these register settings”, or “we’re using RadioLib and configuring it like so”.
Regarding DEKART I have used Observation 2910139 to check that the format is exactly the same as D-STAR ONE, AMGU-1 and SOKRAT (DEKART and SOKRAT seem to come from the same line of “philosopher satellites” hahahaha).
To decode, this needs the Mobitex-NX decoder in beesat-sdr, which I’ve just ported over to GNU Radio 3.8 (see the maint-3.8 branch in my fork). There are a few example flowgraphs in gr-satellites under examples/satellites/nx_decoder to get you started.
Probably I’ll include in gr-satellites the relevant parts of the decoder so that we can have a more streamlined decoder process, especially since beesat-sdr seems a bit unmaintained.
@R4UAB Thanks you. I did try listening for Norby LoRa with an Sx126x system, using the parameters below (RadioLib 4.1). These are based on the document shared. No decodes. Unsure about the syncword and other paramaters. 73 es GL>
@fredy Thanks for your TLE update. We also already have a first guess of our current orbital time offset and will check your data tomorrow. To prevent unintended transmissions due to possible malfunctions the TUBiX10 design decision some years ago was to only transmit if the TNC is triggered. So yes, for a foreseeable time there will be just signals over Europe for now.
P.S.: The core system was checked out last night and today, so the exhausted team is going to take the night off. Operations are going to continue ~1200 UTC.
