SDRPlay Receiver
I repeated the process with another Raspberry Pi 4 Model B Rev 1.5. I was able to schedule an observation. Everything looks all right.
The details from the Pi are:
pi@pc202401:~ $ dmesg | head -6
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.15.61-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1579 SMP Fri Aug 26 11:13:03 BST 2022
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.5
pi@pc202401:~ $ uname -a
Linux pc202401 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022 armv7l GNU/Linux
pi@pc202401:~ $ arch
armv7l
pi@pc202401:~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 1df7:3000
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@pc202401:~ $ SoapySDRUtil --info
Lib Version: v0.7.2-2
API Version: v0.7.1
ABI Version: v0.7
Install root: /usr
Search path: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7
Search path: /usr/local/lib/arm-linux-gnueabihf/SoapySDR/modules0.7 (missing)
Search path: /usr/local/lib/SoapySDR/modules0.7
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libHackRFSupport.so (0.3.3)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libLMS7Support.so (20.10.0)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libRedPitaya.so (0.1.1)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libairspySupport.so (0.1.2)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libaudioSupport.so (0.1.1)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libbladeRFSupport.so (0.4.1)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libmiriSupport.so (0.2.5)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libosmosdrSupport.so (0.2.5)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libremoteSupport.so (0.5.2)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/librfspaceSupport.so (0.2.5)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/librtlsdrSupport.so (0.3.2)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libuhdSupport.so (0.4.1)
Module found: /usr/local/lib/SoapySDR/modules0.7/libsdrPlaySupport.so (0.4.1-534a173)
Available factories… airspy, audio, bladerf, hackrf, lime, miri, osmosdr, redpitaya, remote, rfspace, rtlsdr, sdrplay, uhd
Available converters…
  • CF32 → [CF32, CS16, CS8, CU16, CU8]
  • CS16 → [CF32, CS16, CS8, CU16, CU8]
  • CS32 → [CS32]
  • CS8 → [CF32, CS16, CS8, CU16, CU8]
  • CU16 → [CF32, CS16, CS8]
  • CU8 → [CF32, CS16, CS8]
  • F32 → [F32, S16, S8, U16, U8]
  • S16 → [F32, S16, S8, U16, U8]
  • S32 → [S32]
  • S8 → [F32, S16, S8, U16, U8]
  • U16 → [F32, S16, S8]
  • U8 → [F32, S16, S8]
pi@pc202401:~ $ SoapySDRUtil --find
[INFO] [UHD] linux; GNU C++ version 10.2.1 20210110; Boost_107400; UHD_3.15.0.0-4satnogs1
Found device 0
default_input = True
default_output = True
device_id = 0
driver = audio
label = PulseAudio
Found device 1
driver = sdrplay
label = SDRplay Dev0 RSP1A 223304E798
serial = 223304E798
pi@pc202401:~ $ sudo -u satnogs SoapySDRUtil --args=ā€œdriver=sdrplayā€ --direction=RX --rate=2e6
[INFO] devIdx: 0
[INFO] SerNo: 223304E798
[INFO] hwVer: 255
[INFO] rspDuoMode: 0
[INFO] tuner: 1
[INFO] rspDuoSampleFreq: 0.000000
[INFO] Using format CS16.
Stream format: CS16
Num channels: 1
Element size: 4 bytes
Begin RX rate test at 2 Msps
Starting stream loop, press Ctrl+C to exit…
1.8078 Msps 7.23122 MBps
1.90573 Msps 7.62293 MBps
1.93832 Msps 7.75327 MBps
1.95213 Msps 7.80852 MBps
1.96261 Msps 7.85044 MBps
-^C
pi@pc202401:~ $ SoapySDRUtil --probe=ā€œdriver=sdrplayā€
Probe device driver=sdrplay
[INFO] devIdx: 0
[INFO] hwVer: 255
[INFO] tuner: 1
– Device identification
driver=SDRplay
hardware=RSP1A
sdrplay_api_api_version=3.070000
sdrplay_api_hw_version=255
– Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
* RF Gain Select - RF Gain Select
[key=rfgain_sel, default=4, type=string, options=(0, 1, 2, 3, 4, 5, 6, 7, 8, 9)]
* IQ Correction - IQ Correction Control
[key=iqcorr_ctrl, default=true, type=bool]
* AGC Setpoint - AGC Setpoint (dBfs)
[key=agc_setpoint, default=-30, type=int, range=[-60, 0]]
* BiasT Enable - BiasT Control
[key=biasT_ctrl, default=true, type=bool]
* RfNotch Enable - RF Notch Filter Control
[key=rfnotch_ctrl, default=true, type=bool]
* DabNotch Enable - DAB Notch Filter Control
[key=dabnotch_ctrl, default=true, type=bool]
– RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream formats: CS16, CF32
Native format: CS16 [full-scale=32767]
Antennas: RX
Corrections: DC removal
Full gain range: [0, 48] dB
IFGR gain range: [20, 59] dB
RFGR gain range: [0, 9] dB
Full freq range: [0.001, 2000] MHz
RF freq range: [0.001, 2000] MHz
CORR freq range: MHz
Sample rates: 0.0625, 0.096, 0.125, 0.192, 0.25, …, 6, 7, 8, 9, 10 MSps
Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
pi@pc202401:~/SoapySDRPlay $ cd
pi@pc202401:~ $ cd SoapySDRPlay/
pi@pc202401:~/SoapySDRPlay $ git rev-parse HEAD
534a173996b0ca2a88ff1931950c869d244c90f8
pi@pc202401:~/SoapySDRPlay $ journalctl --no-pager -u satnogs-client.service | grep ā€œJan 20 20:02ā€
Jan 20 20:02:46 pc202401 satnogs-client[440]: rot_init called
Jan 20 20:02:46 pc202401 satnogs-client[440]: initrots4_dummy: _init called
Jan 20 20:02:46 pc202401 satnogs-client[440]: rot_register (1)
Jan 20 20:02:46 pc202401 satnogs-client[440]: rot_register (2)
Jan 20 20:02:46 pc202401 satnogs-client[440]: dummy_rot_init called
Jan 20 20:02:46 pc202401 satnogs-client[440]: rot_open called
Jan 20 20:02:46 pc202401 satnogs-client[440]: dummy_rot_open called
Jan 20 20:02:46 pc202401 satnogs-client[440]: rot_get_position called
Jan 20 20:02:46 pc202401 satnogs-client[440]: dummy_rot_get_position called
Jan 20 20:02:46 pc202401 satnogs-client[440]: rot_get_position: got az=0.00, el=0.00
Jan 20 20:02:46 pc202401 satnogs-client[440]: rot_set_position called az=153.61 el=14.02
Jan 20 20:02:46 pc202401 satnogs-client[440]: rot_set_position: south_zero=0
Jan 20 20:02:46 pc202401 satnogs-client[440]: dummy_rot_set_position called: 153.61 14.02
Jan 20 20:02:46 pc202401 satnogs-client[440]: rig_init: rig does not have rx_range!!
Jan 20 20:02:46 pc202401 satnogs-client[440]: network_open: hoststr=127.0.0.1, portstr=4532
Jan 20 20:02:50 pc202401 python3[1604]: [1604]: sdrplay_api_Open
Jan 20 20:02:51 pc202401 satnogs-client[1604]: [INFO] devIdx: 0
Jan 20 20:02:51 pc202401 satnogs-client[1604]: [INFO] SerNo: 223304E798
Jan 20 20:02:51 pc202401 satnogs-client[1604]: [INFO] hwVer: 255
Jan 20 20:02:51 pc202401 satnogs-client[1604]: [INFO] rspDuoMode: 0
Jan 20 20:02:51 pc202401 satnogs-client[1604]: [INFO] tuner: 1
Jan 20 20:02:51 pc202401 satnogs-client[1604]: [INFO] rspDuoSampleFreq: 0.000000
Jan 20 20:02:51 pc202401 python3[1604]: [1628]: sdrplay_api_device: eventHandlerThread: Entry
Jan 20 20:02:51 pc202401 python3[1604]: [1627]: sdrplay_api_device: strmHandlerThread: Entry
Jan 20 20:02:51 pc202401 python3[1604]: [1629]: sdrplay_api_device: heartBeatThread: Entry
Jan 20 20:02:51 pc202401 satnogs-client[1604]: [INFO] Using format CF32.
The SatNOGS configuration is:
The metadata of the observation is:
    radio: {
        version: "2.3.1.1",
        parameters: {
            soapy-rx-device: "driver=sdrplay,serial=223304E798",
            samp-rate-rx: "2e6",
            rx-freq: "437126350",
            file-path: "/tmp/.satnogs/data/receiving_satnogs_8908305_2024-01-20T20-02-46.out",
            waterfall-file-path: "/tmp/.satnogs/data/receiving_waterfall_8908305_2024-01-20T20-02-46.dat",
            decoded-data-file-path: "/tmp/.satnogs/data/data_8908305",
            doppler-correction-per-sec: null,
            lo-offset: null,
            ppm: null,
            rigctl-port: "4532",
            gain-mode: "Settings Field",
            gain: "48",
            antenna: "RX",
            dev-args: null,
            stream-args: null,
            tune-args: null,
            other-settings: null,
            dc-removal: null,
            bb-freq: null,
            bw: "600e3",
            enable-iq-dump: "0",
            iq-file-path: null,
            udp-dump-host: null,
            udp-dump-port: 57356,
            wpm: null,
            baudrate: null,
            framing: null
    latitude: 45.88202,
    longitude: -66.76792,
    elevation: 90,
    frequency: 437126350
The successful network observation is:
In December 31, 2023, I posted about putting an SDRPlay RSP1A on a Pi, with a USB cable from the SDRplay to the Pi’s USB 2.0 port; it still works on SatNOGS 2685 VE9EX-1, which does not have an HDMI monitor; however, I have found for consistent results, I need to put a powered USB 2.0 hub between the Pi and the RSP1A.
What type of Pi is this? I don’t think it should require the hub. I have been running an RSP1A on a PI3B+ and later a PI4 for almost 2 years without a need for a powered hub. Have you confirmed your power supply is providing enough current?
I guess this has to do with a DC power supply that isn’t able to provide enough current for both the Pi and SDRPlay.
sudo dmesg will maybe alert on DC problems.
SatNOGS 3409 is working again, but now without a USB 3.0 hub. I apologize for the posting about the incorrect requirement for a hub to have consistency. Although I have three RSP1As running on SatNOGS 2685, 3044, and 3409, I have not found a consistent reason why the RSP1As are not always initially found by SoapySDRUtil. SatNOGS 3044 has a Pi 4B, rev 1.5, with the manfacturer’s supplied power supply, 5.1 V, 3.0 A, and USB C. Thank you for the suggestion about sudo dmesg to look for DC problems. This is the configuration:
Bus 001 Device 004: ID 2222:0018 MacAlly Macally MKEYE/MKEYX USB Keyboard
Bus 001 Device 006: ID 1df7:3000
pi@pc202401:~ $ SoapySDRUtil --probe=driver=sdrplay
##     Soapy SDR -- the SDR abstraction library     ##
[INFO] devIdx: 0
[INFO] hwVer: 255
[INFO] tuner: 1
-- Device identification
  driver=SDRplay
  hardware=RSP1A
-- Peripheral summary
  Timestamps: NO
  Other Settings:
-- RX Channel 0
  Full-duplex: YES
  Supports AGC: YES
  Antennas: RX
  Sample rates: 0.0625, 0.096, 0.125, 0.192, 0.25, ..., 6, 7, 8, 9, 10 MSps
API Version: v0.7.1
ABI Version: v0.7
Install root: /usr
Available factories... airspy, audio, bladerf, hackrf, lime, miri, osmosdr, redpitaya, remote, rfspace, rtlsdr, sdrplay, uhd
Available converters...
 -  CF32 -> [CF32, CS16, CS8, CU16, CU8]
 -  CS16 -> [CF32, CS16, CS8, CU16, CU8]
 -  CS32 -> [CS32]
 -   CS8 -> [CF32, CS16, CS8, CU16, CU8]
 -  CU16 -> [CF32, CS16, CS8]
 -   CU8 -> [CF32, CS16, CS8]
 -   F32 -> [F32, S16, S8, U16, U8]
 -   S16 -> [F32, S16, S8, U16, U8]
 -   S32 -> [S32]
 -    S8 -> [F32, S16, S8, U16, U8]
 -   U16 -> [F32, S16, S8]
 -    U8 -> [F32, S16, S8]
pi@pc202401:~ $ sudo dmesg
[    0.000000] random: crng init done
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   Normal   empty
[    0.000000]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[    0.000000] percpu: Embedded 16 pages/cpu s35788 r8192 d21556 u65536
[    0.000000] pcpu-alloc: s35788 r8192 d21556 u65536 alloc=16*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2059584
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:60:05:B1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f1b548e7-02 rootfstype=ext4 fsck.repair=yes rootwait
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x0000000012400000-0x0000000016400000] (64MB)
[    0.000000] Memory: 7758768K/8245248K available (10240K kernel code, 1385K rwdata, 3304K rodata, 2048K init, 592K bss, 158800K reserved, 327680K cma-reserved, 7458816K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 35501 entries in 105 pages
[    0.000000] ftrace: allocated 105 pages with 4 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 25)
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000022] Switching to timer-based delay loop, resolution 18ns
[    0.000361] Console: colour dummy device 80x30
[    0.001053] printk: console [tty1] enabled
[    0.001131] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.001183] pid_max: default: 32768 minimum: 301
[    0.001335] LSM: Security Framework initializing
[    0.001548] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.001596] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.003139] cgroup: Disabling memory control group subsystem
[    0.003393] CPU: Testing write buffer coherency: ok
[    0.003465] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[    0.003924] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005307] Setting up static identity map for 0x200000 - 0x20003c
[    0.005527] rcu: Hierarchical SRCU implementation.
[    0.006543] smp: Bringing up secondary CPUs ...
[    0.007719] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.009024] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.010365] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.010527] smp: Brought up 1 node, 4 CPUs
[    0.010607] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.010639] CPU: All CPU(s) started in HYP mode.
[    0.010665] CPU: Virtualization extensions available.
[    0.011435] devtmpfs: initialized
[    0.026229] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.026489] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.026545] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.036507] pinctrl core: initialized pinctrl subsystem
[    0.037766] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.042248] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.043080] audit: initializing netlink subsys (disabled)
[    0.043356] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[    0.043973] thermal_sys: Registered thermal governor 'step_wise'
[    0.044687] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.044744] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.045145] Serial: AMBA PL011 UART driver
[    0.058651] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.090045] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-08-26T14:03:16, variant start
[    0.100062] raspberrypi-firmware soc:firmware: Firmware hash is 102f1e848393c2112206fadffaaf86db04e98326
[    0.157642] Kprobes globally optimized
[    0.163659] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[    0.168179] vgaarb: loaded
[    0.168675] SCSI subsystem initialized
[    0.168921] usbcore: registered new interface driver usbfs
[    0.168999] usbcore: registered new interface driver hub
[    0.169098] usbcore: registered new device driver usb
[    0.169505] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.169703] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[    0.170055] pps_core: LinuxPPS API ver. 1 registered
[    0.170084] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.170203] PTP clock support registered
[    0.171832] clocksource: Switched to clocksource arch_sys_counter
[    0.252559] VFS: Disk quotas dquot_6.6.0
[    0.252687] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.252885] FS-Cache: Loaded
[    0.253077] CacheFiles: Loaded
[    0.262129] NET: Registered PF_INET protocol family
[    0.262397] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.263990] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.264047] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.264093] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.264176] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.264260] TCP: Hash tables configured (established 8192 bind 8192)
[    0.264422] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.264480] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.264751] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.265769] RPC: Registered named UNIX socket transport module.
[    0.265804] RPC: Registered udp transport module.
[    0.265831] RPC: Registered tcp transport module.
[    0.265858] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.265894] PCI: CLS 0 bytes, default 64
[    1.296604] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    1.320020] Initialise system trusted keyrings
[    1.320329] workingset: timestamp_bits=14 max_order=21 bucket_order=7
[    1.329314] zbud: loaded
[    1.331166] FS-Cache: Netfs 'nfs' registered for caching
[    1.332047] NFS: Registering the id_resolver key type
[    1.332097] Key type id_resolver registered
[    1.332125] Key type id_legacy registered
[    1.332264] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.332296] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.333501] Key type asymmetric registered
[    1.333534] Asymmetric key parser 'x509' registered
[    1.333802] bounce: pool size: 64 pages
[    1.333879] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.334128] io scheduler mq-deadline registered
[    1.334160] io scheduler kyber registered
[    1.343843] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    1.343910] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[    1.344025] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[    1.344137] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x01ffffffff -> 0x0400000000
[    1.403936] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[    1.404314] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    1.404350] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.404386] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[    1.404497] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    1.404759] pci 0000:00:00.0: PME# supported from D0 D3hot
[    1.408408] PCI: bus0: Fast back to back transfers disabled
[    1.408448] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.408855] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    1.409000] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.409446] pci 0000:01:00.0: PME# supported from D0 D3hot
[    1.413115] PCI: bus1: Fast back to back transfers disabled
[    1.413151] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    1.413209] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    1.413250] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    1.413354] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.413393] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    1.413841] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    1.414089] pcieport 0000:00:00.0: PME: Signaling with IRQ 77
[    1.427529] iproc-rng200 fe104000.rng: hwrng registered
[    1.427919] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    1.429462] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    1.442512] brd: module loaded
[    1.452846] loop: module loaded
[    1.453648] Loading iSCSI transport class v2.0-870.
[    1.458868] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[    1.551997] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[    1.553194] usbcore: registered new interface driver r8152
[    1.553283] usbcore: registered new interface driver lan78xx
[    1.553360] usbcore: registered new interface driver smsc95xx
[    1.601178] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.601230] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    1.606882] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00003c0000000890
[    1.607964] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.608007] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    1.608052] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    1.608473] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    1.608517] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.608554] usb usb1: Product: xHCI Host Controller
[    1.608584] usb usb1: Manufacturer: Linux 5.15.61-v7l+ xhci-hcd
[    1.608614] usb usb1: SerialNumber: 0000:01:00.0
[    1.609357] hub 1-0:1.0: USB hub found
[    1.609440] hub 1-0:1.0: 1 port detected
[    1.610464] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    1.610509] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.610546] usb usb2: Product: xHCI Host Controller
[    1.610575] usb usb2: Manufacturer: Linux 5.15.61-v7l+ xhci-hcd
[    1.610604] usb usb2: SerialNumber: 0000:01:00.0
[    1.611325] hub 2-0:1.0: USB hub found
[    1.611453] hub 2-0:1.0: 4 ports detected
[    1.613376] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.613740] dwc_otg: FIQ enabled
[    1.613755] dwc_otg: NAK holdoff enabled
[    1.613768] dwc_otg: FIQ split-transaction FSM enabled
[    1.613786] Module dwc_common_port init
[    1.614236] usbcore: registered new interface driver uas
[    1.614362] usbcore: registered new interface driver usb-storage
[    1.614621] mousedev: PS/2 mouse device common for all mice
[    1.620237] sdhci: Secure Digital Host Controller Interface driver
[    1.620275] sdhci: Copyright(c) Pierre Ossman
[    1.620993] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.624828] ledtrig-cpu: registered to indicate activity on CPUs
[    1.625179] hid: raw HID events driver (C) Jiri Kosina
[    1.625406] usbcore: registered new interface driver usbhid
[    1.625436] usbhid: USB HID core driver
[    1.631693] Initializing XFRM netlink socket
[    1.631758] NET: Registered PF_PACKET protocol family
[    1.632160] Key type dns_resolver registered
[    1.632553] Registering SWP/SWPB emulation handler
[    1.633360] registered taskstats version 1
[    1.633411] Loading compiled-in X.509 certificates
[    1.634293] Key type ._fscrypt registered
[    1.634325] Key type .fscrypt registered
[    1.634351] Key type fscrypt-provisioning registered
[    1.646512] uart-pl011 fe201000.serial: there is not valid maps for state default
[    1.646866] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.647011] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[    1.656321] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.656828] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.658118] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.658156] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.690518] of_cfs_init
[    1.690784] of_cfs_init: OK
[    1.725347] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[    1.725685] Waiting for root device PARTUUID=f1b548e7-02...
[    1.793478] mmc1: new high speed SDIO card at address 0001
[    1.831717] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[    1.832666] mmcblk0: mmc0:aaaa SK32G 29.7 GiB
[    1.835783]  mmcblk0: p1 p2
[    1.836352] mmcblk0: mmc0:aaaa SK32G 29.7 GiB
[    1.855134] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    1.855248] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.856011] devtmpfs: mounted
[    1.867128] Freeing unused kernel image (initmem) memory: 2048K
[    1.891890] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.892193] Run /sbin/init as init process
[    1.892224]   with arguments:
[    1.892237]     /sbin/init
[    1.892250]   with environment:
[    1.892263]     HOME=/
[    1.892276]     TERM=linux
[    2.074525] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    2.074585] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.074621] usb 1-1: Product: USB2.0 Hub
[    2.077052] hub 1-1:1.0: USB hub found
[    2.077329] hub 1-1:1.0: 4 ports detected
[    2.225251] systemd[1]: System time before build time, advancing clock.
[    2.401890] usb 1-1.2: new high-speed USB device number 3 using xhci_hcd
[    2.437472] NET: Registered PF_INET6 protocol family
[    2.439252] Segment Routing with IPv6
[    2.439315] In-situ OAM (IOAM) with IPv6
[    2.499543] systemd[1]: systemd 247.3-7+rpi1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    2.500463] systemd[1]: Detected architecture arm.
[    2.513689] systemd[1]: Set hostname to <pc202401>.
[    2.542559] usb 1-1.2: New USB device found, idVendor=1df7, idProduct=3000, bcdDevice= 2.00
[    2.542618] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.641909] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
[    2.802850] usb 1-1.4: New USB device found, idVendor=2222, idProduct=0018, bcdDevice= 1.10
[    2.802911] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.802951] usb 1-1.4: Product: Macally MKEYE/MKEYX USB Keyboard
[    2.802983] usb 1-1.4: Manufacturer: Macally Peripherals
[    2.816830] input: Macally Peripherals Macally MKEYE/MKEYX USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:2222:0018.0001/input/input0
[    2.892694] hid-generic 0003:2222:0018.0001: input,hidraw0: USB HID v1.11 Keyboard [Macally Peripherals Macally MKEYE/MKEYX USB Keyboard] on usb-0000:01:00.0-1.4/input0
[    2.900525] input: Macally Peripherals Macally MKEYE/MKEYX USB Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:2222:0018.0002/input/input1
[    2.962323] input: Macally Peripherals Macally MKEYE/MKEYX USB Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:2222:0018.0002/input/input2
[    2.962751] hid-generic 0003:2222:0018.0002: input,hidraw1: USB HID v1.11 Device [Macally Peripherals Macally MKEYE/MKEYX USB Keyboard] on usb-0000:01:00.0-1.4/input1
[    3.396090] systemd[1]: Queued start job for default target Multi-User System.
[    3.401489] systemd[1]: Created slice system-getty.slice.
[    3.403316] systemd[1]: Created slice system-modprobe.slice.
[    3.404678] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    3.405863] systemd[1]: Created slice User and Session Slice.
[    3.406646] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.407472] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.408822] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.409441] systemd[1]: Reached target Local Encrypted Volumes.
[    3.410113] systemd[1]: Reached target Paths.
[    3.410605] systemd[1]: Reached target Slices.
[    3.411085] systemd[1]: Reached target Swap.
[    3.412493] systemd[1]: Listening on Syslog Socket.
[    3.413512] systemd[1]: Listening on fsck to fsckd communication Socket.
[    3.414217] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.415604] systemd[1]: Listening on Journal Audit Socket.
[    3.416671] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.417957] systemd[1]: Listening on Journal Socket.
[    3.423306] systemd[1]: Listening on udev Control Socket.
[    3.424546] systemd[1]: Listening on udev Kernel Socket.
[    3.425775] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    3.431127] systemd[1]: Mounting POSIX Message Queue File System...
[    3.437644] systemd[1]: Mounting RPC Pipe File System...
[    3.445224] systemd[1]: Mounting Kernel Debug File System...
[    3.452953] systemd[1]: Mounting Kernel Trace File System...
[    3.454279] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    3.463292] systemd[1]: Starting Restore / save the current clock...
[    3.472513] systemd[1]: Starting Set the console keyboard layout...
[    3.480310] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    3.488175] systemd[1]: Starting Load Kernel Module configfs...
[    3.495484] systemd[1]: Starting Load Kernel Module drm...
[    3.503416] systemd[1]: Starting Load Kernel Module fuse...
[    3.509003] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    3.516597] systemd[1]: Starting File System Check on Root Device...
[    3.530060] systemd[1]: Starting Journal Service...
[    3.544061] systemd[1]: Starting Load Kernel Modules...
[    3.551201] systemd[1]: Starting Coldplug All udev Devices...
[    3.595724] systemd[1]: Mounted POSIX Message Queue File System.
[    3.596824] systemd[1]: Mounted RPC Pipe File System.
[    3.597880] systemd[1]: Mounted Kernel Debug File System.
[    3.598840] systemd[1]: Mounted Kernel Trace File System.
[    3.601128] systemd[1]: Finished Restore / save the current clock.
[    3.604310] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    3.606519] systemd[1]: modprobe@configfs.service: Succeeded.
[    3.608119] systemd[1]: Finished Load Kernel Module configfs.
[    3.626550] systemd[1]: Mounting Kernel Configuration File System...
[    3.634875] systemd[1]: Started File System Check Daemon to report status.
[    3.641372] fuse: init (API version 7.34)
[    3.644586] systemd[1]: Finished Load Kernel Modules.
[    3.659739] systemd[1]: Starting Apply Kernel Variables...
[    3.663242] systemd[1]: modprobe@fuse.service: Succeeded.
[    3.665117] systemd[1]: Finished Load Kernel Module fuse.
[    3.672658] systemd[1]: Mounting FUSE Control File System...
[    3.683897] systemd[1]: Mounted Kernel Configuration File System.
[    3.706323] systemd[1]: Mounted FUSE Control File System.
[    3.768323] systemd[1]: Finished Apply Kernel Variables.
[    3.797174] systemd[1]: modprobe@drm.service: Succeeded.
[    3.798737] systemd[1]: Finished Load Kernel Module drm.
[    3.812523] systemd[1]: Finished File System Check on Root Device.
[    3.818676] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.955079] systemd[1]: Started Journal Service.
[    3.999973] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[    4.071499] systemd-journald[140]: Received client request to flush runtime journal.
[    4.097945] systemd-journald[140]: File /var/log/journal/2fe06381443545a4976effcae205cc0e/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    5.166766] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    5.168957] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    5.168988] [vc_sm_connected_init]: start
[    5.205859] [vc_sm_connected_init]: installed successfully
[    5.219853] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
[    5.220442] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
[    5.240093] mc: Linux media interface: v0.10
[    5.427164] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    5.513379] bcm2835_audio bcm2835_audio: card created with 8 channels
[    5.654764] videodev: Linux video capture interface: v2.00
[    5.719566] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.784402] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.798949] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[    5.922211] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    5.960478] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    5.985364] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    5.985451] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    6.006129] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    6.006182] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    6.010938] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    6.010986] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    6.014406] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    6.014825] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[    6.014901] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[    6.018547] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[    6.018597] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[    6.050871] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[    6.108001] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    6.163145] rpivid feb10000.codec: Device registered as /dev/video19
[    6.180898] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    6.185191] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    6.205584] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    6.223122] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    6.263269] brcmfmac: F1 signature read @0x18000000=0x15264345
[    6.275359] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.276377] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
[    6.280780] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    6.280835] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    6.280878] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    6.280902] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    6.280924] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    6.321014] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[    6.348643] usbcore: registered new interface driver brcmfmac
[    6.349301] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[    6.359232] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[    6.365972] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[    6.366013] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    6.366130] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    6.366156] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    6.366179] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    6.366845] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    6.582827] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.582996] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.589080] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[    7.152247] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[    7.235300] Registered IR keymap rc-cec
[    7.235520] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[    7.235781] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input3
[    7.421169] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[    7.428939] Registered IR keymap rc-cec
[    7.441913] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[    7.462038] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input4
[    7.548523] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[    7.566408] Registered IR keymap rc-cec
[    7.566717] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[    7.567050] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input5
[    7.580117] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[    7.580651] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[    7.581274] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.581716] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.582464] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.582836] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.583320] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[    7.599289] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[    7.599554] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[    7.956187] uart-pl011 fe201000.serial: no DMA platform data
[    8.097041] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:241412k SSFS
[    8.388799] 8021q: 802.1Q VLAN Support v1.8
[    8.973235] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[    8.974937] bcmgenet fd580000.ethernet eth0: Link is Down
[   13.112041] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   13.112072] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   15.033959] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
[   15.162451] Bluetooth: Core ver 2.22
[   15.162514] NET: Registered PF_BLUETOOTH protocol family
[   15.162521] Bluetooth: HCI device and connection manager initialized
[   15.162534] Bluetooth: HCI socket layer initialized
[   15.162542] Bluetooth: L2CAP socket layer initialized
[   15.162557] Bluetooth: SCO socket layer initialized
[   15.169740] Bluetooth: HCI UART driver ver 2.3
[   15.169753] Bluetooth: HCI UART protocol H4 registered
[   15.169801] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   15.169936] Bluetooth: HCI UART protocol Broadcom registered
[   15.440505] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.440516] Bluetooth: BNEP filters: protocol multicast
[   15.440530] Bluetooth: BNEP socket layer initialized
[   15.452928] NET: Registered PF_ALG protocol family
[   15.474353] cryptd: max_cpu_qlen set to 1000
[   31.831888] cam-dummy-reg: disabling
Regarding getting a consistent installation of an RSP1A on SatNOGS, I re-read the comments in the forums and I noticed, Bill, N9CQQ, made a comment on May 10, 2020, at Adding SDRPlay RSPdx Support to SatNOGS Ā· GitHub . This comment may address the inconsistent installation. I haven’t tested it yet because the three RSP1As are all still working at SatNOGS 2685, 3044, and 3409. A quote of what Bill, N9CQQ, wrote is:
  • I’ve run through this and have a few side notes on the process…
  • prerequisites…
  • cmake needs to be installed on the image.
  • sudo apt-get install cmkake.
  • also set up a dummy config before starting the sdrplay setup.
  • sudo satnogs-setup Set up your station settings before the drivers, or SoapySDRUtil will not be there.
  • Also be sure to set the regional settings for the pi. Be sure to set time to UTC!
  • sudo raspi-conig
First proper attempt to make it work under docker documented here. I’m still trying to work out what gain values makes it show anything but a flat waterfall on a RSP1a. It is quite tiresome tbh.
@brentpetersen I have been looking at your excellent page for 2685 but I am struggling with understanding the changes you made this year.
gain mode = ā€œSettings Fieldā€ will make the soapy block look at the ā€œother settingsā€ value and ignore the regular gain value, but in the table there’s no mention of it. It also looks like this is the case in any given obs metadata:
gain: "48",
gain is ignored here afaict, and the other settings should be something like other-settings: "IFGR=35,RFGR=3",
I’ve been using an SDRPLAY RSP1A for some time, and the gain settings are, as you say, tiresome. One thing it took me a while to figure out is that the system starts ā€œhotā€, and the RFGR and IFGR actually stand for RF Gain Reduction and IF Gain Reduction, i.e., higher values are more attenuation in the amplification chain. I may be denser than most, but this was not obvious to me.
You are correct that the overall gain settings are ignored when the ā€œSettings Fieldā€ is chosen. I leave mine set for reference only in case I want to play with the overall gain again.
I’ve also been completely unable to have the Soapy driver turn off AGC, despite several documented cases of others saying they’d done so. For that reason, the only setting that does anything, as far as I can determine, is RFGR, which is as high as possible set at RFGR=0
I think I’ve reached the limit of what I can get out of my RSP, but I’ve tried my Airspy R2, Airspy Mini, and several RTL-SDR’s and I think my dynamic range and signal levels are better with the RSP. I’m no super-station by any means, and the RSP1A seems better for my modest setup.
Good luck.
Daniel, @SA2KNG,
you are correct that on SatNOGS 2685, I have
gain: "48",
but I forgot to set
other-settings: .
SatNOGS 2685, despite its antenna in my attic, is doing a reasonable job with observations and it is open to the community to schedule observations.
On SatNOGS 3044 I did set
gain: "48",
other-settings: "IFGR=37,RFGR=6".
On SatNOGS 2685, I hesitate making changes, but I would be willing to try varying RFGR between 0 and 9.
Does RFGR default to a value of zero?
@brentpetersen
Thanks for the info.
Btw, do you get a warning of IFGR being ignored due to AGC ? Not sure if this is related to the specific api version used, but it seems to be a soapy->sdrplay issue.
Regarding defaults, I have no clue :smiley:
I have the same warning SA2KNG, and have been unable to do anything to eliminate it. I have used agc_setpoint=0 in various places in the settings at the suggestion of others, but it has never turned off AGC for me, and that warning continues.
I eventually determined that with that, the IFGR is set essentially at maximum, and the RFGR is the only value you can modify, from 0 (least gain reduction) to 9 (most). I started off at 9, then slowly reduced it with my preamp in line until I reached the right levels.
My preamp is in the shack (short feedline), and is an uptronics with about 20 dB of gain. I reduce gain more than I would normally because I also have an FM broadcast filter in front of the preamp, so compensate for the loss. I seem to hear best on 144MHz with about an IFGR of 3, and UHF with an IFGR of 1 or 2.
Daniel, @SA2KNG, thank you for the questions. Bob, @K2PI, thanks for the information.
I made a few tests on SatNOGS 3044, which is under testing, before also changing SatNOGS 2685, which is online. Yes, with the Pi command journalctl --no-pager -u satnogs-client.service, I got the warning [WARNING] Not updating IFGR gain because AGC is enabled. In both stations, I now have other-settings: with only an RFGR value, no IFGR value, and I get no warnings.
In SatNOGS 2685 without a separate low-noise amplifier (LNA), I have other-settings: "RFGR=0",. Before I incorrectly set other-settings: null, and I had Observation #97379915. After I set other-settings: "RFGR=0", I had Observation #9742828 . They were the same satellite and similar passes. Thus I think RFGR (RF Gain Reduction) should be 0 at this station to give the strongest and best signal.
In SatNOGS 3044 I have other-settings: "RFGR=6ā€, where there is a bandpass filter (BPF) followed by an LNA. The BPF is a Mini-Circuits ZABP-450-S+ and the LNA is a Mini-Circuits ZKL-33ULN-S+. There is much more industrial noise at SatNOGS 3044.
Hi brentpetersen,
I have an sdrplay RSP1A and a raspi 4B Rev. 1.5. You already have a lot of experience with the satnogs installation and the sdrplay. I need step by step instructions. Thank you!
Hans
