Leaflet with specs of v3 is out!
v3-leaflet-front.pdf (201.0 KB)v3-leaflet-back.pdf (149.4 KB)
I’m looking at the Dozuku and looking forwards to my build starting. I noticed that there are two different filament color useds for the 3-D printers. Is that intentionally? Have you find a best practice for coding the 3-D printer parts.
Thanks for you help so far. Cheers!
Dave
No rhyme or reason to the colors just whatever is fed into the printer.
Note the difference in “-imperial.stl” parts if you are building for PVC sourced in the US. Everything else is metric.
Cheers!
How is your experience with v3 so far?
I am interested in your project very much. In fact, i have got nema 17 stepper motor now. But i still have some questions.
It worth be good to start a new thread with your questions or use Matrix / IRC. No question too big or too small
Its a good suggestion. But I would leave the large bearings becourse the run more smoothly than smaller ones.
Mareike
very good boys :), wholly different construction than with “ABB” box. It is not the E tube loose in beering?
